    New rendering plugin
    30 Posts 10 Posters 2.6k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      I added a note to that thread.
      By: Kristoff Rand
        Krisidious
        I guess they'll be charging later and thus the rather small renderings.
        By: Kristoff Rand
          mics_54
          Maybe...but for now I can put lipstick on all my pigs.
          I have been playing with kerkythea too....but I like working inside SUjust a doodle.not bad for 60 secondswith adaptive antialiasing  selected
          • BoxB Offline
            I couldn't resist the cube's cube.
            In fact, resistance was futile.
            • Didier BurD Offline
              Didier Bur
              @mics_54:Thanks for the head up.
              But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
              I'm running Windows 7 ... 😲
              Anyone else encountered this ?
              DB
                mics_54
                no, sorry I didn't have that issue.
                I didn't recall seeing any thing on his forum about it.
                  Krisidious
                  Didier... If you don't know what's going on then who the hell does?
                  this might help?
                  http://www.brighter3d.com/windows-xp-support/
                  By: Kristoff Rand
                  • BoxB Offline
                    Ask in the brighter forum, they are very good at responding.
                    I've had a long chat via email with them.
                    • Mistro11M Offline
                      Mistro11
                      I only have Windows XP and hope they support it soon.
                      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                        Didier Bur
                        I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
                        DB
                          Does it exact that maxi is 800 x 450 pixels ?
                            Didier Bur
                            @Pilou: Yes 800x450 (16:9) is the max 😞
                            Higher resolutions will be payware I guess.
                            But the plugin is simple, easy to use, and quite fast at renderings
                            DB
                            • BoxB Offline
                              From what I understand, the plugin is still being developed so max res is bound to change.
                              But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
                                Didier Bur
                                @Box: +1
                                It seems to have some problems with FaceMe components that use PNG images (see trees in the background). Pixels that are totally transparent are not rendered as such.
                                Be careful with smoothed faces too (see black areas at the roof top). But maybe it's just my render settings that must be fine tuned.
                                DB
                                  Could it be that you where running in Compatibility Mode?
                                    Didier Bur
                                    @thomthom: Good point. Stupid me...
                                    DB
                                    • BoxB Offline
                                      Just posting this to show how a very quick sketch can look without any fiddling about.
                                      And I'm a total novice at rendering.
                                      Model took about 30min (already had the cello), and render time about a minute.
                                        mics_54
                                        do you have glass in the window?
                                        I haven't been able to get any transparencies to work..yet
                                        • BoxB Offline
                                          No, no glass, he's still working on transparent and translucent.
                                            mics_54
                                            it doesn't support layers either... hide what you do want visible
