    New rendering plugin
    30 Posts 10 Posters 2.6k Views 10 Watching
    • KrisidiousK Offline
      Krisidious
      I downloaded and installed it... the toolbar and menu items show up but do nothing. 😞
      By: Kristoff Rand
        mics_54
        Getting Started with Brighter3D
        Learn how to get started with Brighter3D rendering plugin for SketchUp
        (www.brighter3d.com)
        I had to follow that short instructional.
        • dukejazzD Offline
          dukejazz
          Hey every one
          Use brightness material for lighting
          This is what I get when I move my mouse wheel durring rendering it works
          brightness
          Where you should go for help.
          http://www.brighter3d.com/start/
            Krisidious
            I could have sworn I had sketchup turned off when I installed. But apparently not as that seemed to do the trick.
            By: Kristoff Rand
              Krisidious
              Test run... Seems very powerful.
              By: Kristoff Rand
              • BoxB Offline
                It's nice and simple, very quick, but it has a few bugs.
                As a render virgin I didn't have much trouble getting the basics working.
                Certainly made it easy to give my Av a very different look.
                • mitcorbM Offline
                  mitcorb
                  Perhaps this new discovery should be added to this topic/ thread:
                  http://sketchucation.com/forums/viewtopic.php?f=81&t=3220#p15472
                  Just a thought...
                    Krisidious
                    I added a note to that thread.
                    By: Kristoff Rand
                      Krisidious
                      I guess they'll be charging later and thus the rather small renderings.
                      By: Kristoff Rand
                        mics_54
                        Maybe...but for now I can put lipstick on all my pigs.
                        I have been playing with kerkythea too....but I like working inside SUjust a doodle.not bad for 60 secondswith adaptive antialiasing  selected
                        • BoxB Offline
                          I couldn't resist the cube's cube.
                          In fact, resistance was futile.
                          • Didier BurD Offline
                            Didier Bur
                            @mics_54:Thanks for the head up.
                            But I cannot install it! When running setup.exe (with admin privileges) this message pops up:
                            I'm running Windows 7 ... 😲
                            Anyone else encountered this ?
                            DB
                              mics_54
                              no, sorry I didn't have that issue.
                              I didn't recall seeing any thing on his forum about it.
                                Krisidious
                                Didier... If you don't know what's going on then who the hell does?
                                this might help?
                                http://www.brighter3d.com/windows-xp-support/
                                By: Kristoff Rand
                                • BoxB Offline
                                  Ask in the brighter forum, they are very good at responding.
                                  I've had a long chat via email with them.
                                  • Mistro11M Offline
                                    Mistro11
                                    I only have Windows XP and hope they support it soon.
                                    i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                                    Structural Integrity is Not Just Physical...It's in the Design and Purpose
                                      Didier Bur
                                      I recommend everyone to test and use the plugin. The staff at Brighter3d sent me very quickly an installer which does not check the Win version, they are very aware of problems when you post at their forum.
                                      DB
                                        Does it exact that maxi is 800 x 450 pixels ?
                                          Didier Bur
                                          @Pilou: Yes 800x450 (16:9) is the max 😞
                                          Higher resolutions will be payware I guess.
                                          But the plugin is simple, easy to use, and quite fast at renderings
                                          DB
                                          • BoxB Offline
                                            From what I understand, the plugin is still being developed so max res is bound to change.
                                            But it is simple to use and blindingly fast and well worth helping to develop further, even at this stage it is a very useful tool for creating quick well rendered sketches totally within sketchup.
