    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      @jgb said:
      Any progress on implementing a contour error check and reporting ❓ ❓ ❓
      I provided some elements of cleansing in Curvizard::Clean up. Part of it is integrated into Curviloft as well (you may get a message).
      • jgbJ Offline
        jgb
        I really need to spend some time to learn some new tricks. Curvizard is in my update SU list, like a bunch of other stuff. 😒
        jgb
          Mra
          @thomthom said:
          That's due to a limitation in the SketchUp API. Screen text take on the colour of your edges. You'd have to temporarily use a different style that doesn't have a white edges.
          D'oh! Thank you for the help.
            awkonradi
            Would someone please direct me to a "Donate" button for this plug-in?
                awkonradi
                EDIT: Sorry, I just found the Fredo6 at PayPal menu item in Curviloft. All set here.
                Thank you Dave R.
                Do you recommend I install this plug-in, in order to follow your instructions?
                http://sketchucation.com/forums/viewtopic.php?t=42089
                That would be fine. I just want to do this right.
                  trion
                  Hello, i really like this script, but i have 1 little thing i cant seem to get it right.
                  Its a airfoil of a wing and 2 path, with the sweep function i only can select 1 path.
                  How can i make this work that the airfoil stays between the 2 path??
                  Best ragards,
                  Trion
                  • fredo6F Offline
                    Best ragards,
                    Trion
                    You cannot do it in one pass, because there are 2 surfaces to generate.
                    So Use Skinning and select the 4 contours on the top side, and again the 4 contours on the bottom side.
                      trion
                      Got it, thank you so much !!
                        trion
                        Hello Fredo6
                        I made a small donation to your account, because of the great scripts and support.
                        Thank you so much.
                        Trion
                        • AlomphegaA Offline
                          Alomphega
                          Hello Fredo,
                          I have almost the same thing to do : a wing - but this time curved like a kitesurf wing.
                          I have yet done this with a triangular half wing and CurviLoft worked fine for this with 3 edges, but since I have added some right tips to do a trapezoidal half wing, I'm not able to re-do the miracle.
                          The problem : I would like to make a skin on the upper face following the tailing and the leading edges as rails, with the upper half of a foil as upper skin shape, then end flat to the tip.
                          In attachment you will find the half of the wing I talk about :
                          The purple is the upper half foil shape, the dark red is the tailing edge, the dark green is the leading edge and the green is the tip.
                          This happen after I select Tailing and leading edges as 1 & 2, then clic, then select upper foil shape and tip as 3 & 4, then "skinning" : nothing happens.
                          The same trying almost all other selecting orders.
                          Could you take a look and tell me were I'm wrong please ?
                          Best Regards,
                          Guy
                          Test CurviLoft 'skin'
                          Guy Capra, http://www.nauticaerium.com
                          Non je ne suis pas un "Géo Trouvetou", juste un "Géo... Zéchercher" ! ;)
                          • pbacotP Offline
                            I mocked-up something similar to your picture and can't get it to fail. Seeing as I can make a number of things fail, perhaps you should post your SU file, to see what it is exactly. But the way I am doing it is: I just select all of it and pick the skinning tool.
                              Alomphega
                              Thank you very much for your try to help pbacot,
                              here in attachment you will find a SKP file with the half kite wing a talk about to test it.
                              HalfKiteWing (SkinningTest).skp
                              • cottyC Offline
                                cotty
                                Something like this? I used TIGs Extrude Edges by Rails (EEbyR)...
                                HalfKiteWing (SkinningTest)_2.skp
                                my SketchUp gallery
                                • jeff hammondJ Offline
                                  Best Regards,
                                  Guy
                                  you have a tiny line in there at an angle too steep to be picked up by curviloft's autoselection.. (it's in between the red and purple selected lines of your screenshot)
                                  either a) zoom in real close and select that tiny line manually or b) fix the curve so it's continous..
                                  (option b being the best.)
                                  [EDIT] actually, you have more errors going on than just the one i mentioned.. i'm out the door..
                                  someone else can pinpoint them for you 😉
                                    Alomphega
                                    Just amazing and awesome ! Many thanks cotty ! 😄
                                    Jeff, I tought this, but very difficult to fix and CurviLoft auto-fix function does not seems to work on my so dirty design. I have to re-draw the stuff but I'm not able to do more fine within SU.
                                    Anyway, I have now some material to test and work on.
                                    Best Regards to all, and best wishes !
                                    Guy
                                    • jgbJ Offline
                                      jgb
                                      Trion
                                      I concur with Fredo.
                                      What you need to do is take a copy of the chord at the root and scale it to (at least) 1 other rib location near the tip, but just before the tip curve starts.
                                      Then CL skin individually the inner top and outer (tip) top airfoil, then do the bottom in 2 goes as well. Only explode the surfaces after all curves are satisfactory.
                                      Should take all of 5 minutes.
                                      If you have a problem, come back here with your SKP file and I will do a detailed explanation.
                                      jgb
                                        trion
                                        Hello,
                                        Well, it didnt work for me, so here is that file im trying.
                                        Hope you can find out why its not working.
                                        Trion
                                        wing.skp
                                        • cottyC Offline
                                          cotty
                                          I've welded some lines and Curviloft asked me if it should repair some issues ...
                                          wing_2.skp
                                          my SketchUp gallery
                                            trion
                                            Thank you for checking and fixing the wing.
                                            would like to know what you did and where i need to look for the next time.
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 65
                                            • 66
                                            • 58 / 66
