    1.3k Posts 300 Posters 3.3m Views 298 Watching
      davidee
      Hello everybody,
      When I installed this plugin on my MacBook Pro with Retina it worked great but it did not look like it is suppose to look. It would be very great if this wil be fixed! 😄
      I put an image of how it looks in the attachments.
        I don't see any images.
        • xiombargX
          xiombarg
          Hey thanks for this plugin Fredo. It's by far my favorite surface generating plugin. Great work.
            Mra
            While using this tool there seems to be white text? I can't read the instrucctions 😞
              That's due to a limitation in the SketchUp API. Screen text take on the colour of your edges. You'd have to temporarily use a different style that doesn't have a white edges.
              @Fredo: one workaround for you could be to detect the edge colour setting and swap between light and dark background.
                RaySteve
                Thank you my friend! this tool is AMAZING!!!!!!
                I appreciate your hard work very very much. tools like these make sketchup do crazy stuff man!!
                once again thanksssssssssssssssss to the developers and any one else
                • jgbJ
                  jgb
                  Any progress on implementing a contour error check and reporting ❓ ❓ ❓
                  I just spent an hour redrawing almost the entire contour, endpoint to endpoint to eliminate a single totally invisible .001 inch extra line fragment error. Yet when I first selected the lines using Skinning, I got solid yellow all around. Hitting the Checkmark either gave me a red perimeter, or nothing at all.
                  I also noticed that if I am selecting edges using the Skinner, and zoom in past seeing the edges selected, when I pan or zoom out the selection (yellow) sometimes get lost and the next line selected is red or purple. If I reselect the lines they are okay, and the previous selections reappear.
                  jgb
                  • fredo6F
                    @jgb said:
                    I provided some elements of cleansing in Curvizard::Clean up. Part of it is integrated into Curviloft as well (you may get a message).
                    • jgbJ
                      jgb
                      I really need to spend some time to learn some new tricks. Curvizard is in my update SU list, like a bunch of other stuff. 😒
                      jgb
                        Mra
                        D'oh! Thank you for the help.
                          awkonradi
                          Would someone please direct me to a "Donate" button for this plug-in?
                              awkonradi
                              EDIT: Sorry, I just found the Fredo6 at PayPal menu item in Curviloft. All set here.
                              Thank you Dave R.
                              Do you recommend I install this plug-in, in order to follow your instructions?
                              404 Not Found
                              (sketchucation.com)
                              That would be fine. I just want to do this right.
                              • T
                                trion
                                Hello, i really like this script, but i have 1 little thing i cant seem to get it right.
                                Its a airfoil of a wing and 2 path, with the sweep function i only can select 1 path.
                                How can i make this work that the airfoil stays between the 2 path??
                                Best ragards,
                                Trion
                                • fredo6F
                                  Best ragards,
                                  Trion
                                  You cannot do it in one pass, because there are 2 surfaces to generate.
                                  So Use Skinning and select the 4 contours on the top side, and again the 4 contours on the bottom side.
                                  • T
                                    trion
                                    Got it, thank you so much !!
                                    • T
                                      trion
                                      Hello Fredo6
                                      I made a small donation to your account, because of the great scripts and support.
                                      Thank you so much.
                                      Trion
                                      • AlomphegaA
                                        Alomphega
                                        Hello Fredo,
                                        I have almost the same thing to do : a wing - but this time curved like a kitesurf wing.
                                        I have yet done this with a triangular half wing and CurviLoft worked fine for this with 3 edges, but since I have added some right tips to do a trapezoidal half wing, I'm not able to re-do the miracle.
                                        The problem : I would like to make a skin on the upper face following the tailing and the leading edges as rails, with the upper half of a foil as upper skin shape, then end flat to the tip.
                                        In attachment you will find the half of the wing I talk about :
                                        The purple is the upper half foil shape, the dark red is the tailing edge, the dark green is the leading edge and the green is the tip.
                                        This happen after I select Tailing and leading edges as 1 & 2, then clic, then select upper foil shape and tip as 3 & 4, then "skinning" : nothing happens.
                                        The same trying almost all other selecting orders.
                                        Could you take a look and tell me were I'm wrong please ?
                                        Best Regards,
                                        Guy
                                        Test CurviLoft 'skin'
                                        Guy Capra, http://www.nauticaerium.com
                                        Non je ne suis pas un "Géo Trouvetou", juste un "Géo... Zéchercher" ! ;)
                                        • pbacotP
                                          I mocked-up something similar to your picture and can't get it to fail. Seeing as I can make a number of things fail, perhaps you should post your SU file, to see what it is exactly. But the way I am doing it is: I just select all of it and pick the skinning tool.
                                          • AlomphegaA
                                            Alomphega
                                            Thank you very much for your try to help pbacot,
                                            here in attachment you will find a SKP file with the half kite wing a talk about to test it.
                                            HalfKiteWing (SkinningTest).skp
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 65
                                            • 66
                                            • 42 / 66
