    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 233.5k Views 61 Watching
      dedmin
      Ooops! Got it - didn't remove the old files! Everything is working now! Sorry and thanks! ๐Ÿ˜ณ ๐Ÿ˜ณ
      • Y Offline
        Yvanou
        Hi evrebody!
        I've got a problem with Projection v2 plug in and Google SketchUp 7.1.
        I extracted all files in the Google SketchUp Plugins folder (as it explained in the PDF file: Projection_extension.rb and the Projection folder) but nothing appears in the tools bar while SketchUp runs.
        Do I forget something? Does somebody experiment the same problem?
        Thanx for your answers.
        • Didier BurD Offline
          Didier Bur
          Not of I know of. Weird ๐Ÿ˜ฒ
          DB
          • halroachH Offline
            halroach
            In the latest version when I run extrude lines along vector I encounter two problems:
            1. In many cases the extrusion direction doesn't lock onto red,green,blue axis unless I am in a certain viewpoint which I am not sure which it is supposed to be.
            2. When I extrude a simple arc or curve, the extruded curve's EDGES come out soft, yet the surface normals are not smooth. When there are combined curves and lines connected to each other, the smoothing makes things quite confusing on the eyes, and makes selection difficult.
            You mentioned in this thread having trouble with the smoothing, until it is solved, I believe it would be better if it worked like the previous versions of the plugin, where it would extrude all the lines and leave them them simple and clean - it eases on viewing and selecting them. let the user decide if to soften/smooth them later.
            Did I mention your plugins are great!? ๐Ÿ˜„
            rather confusing output...
            FlexTools - Super Quick Windows, Doors, Slats...
              alexandrepiacsek
              excellent!! thanks !
              • V Offline
                voxdei_999
                hi, i think it's only me (i've seen the forum & ruby depot), but the only thing i can do is insert guide points, the another 16 options does'nt work, what i'm doing wrong? thanks fou your suggest.
                  boostabeats
                  Hi All,
                  Sorry if this has been mentioned before, I just skimmed through the pages.
                  The accompanying literature states that for a mac to install the plugin in the user library not the main library.
                  Since I didn't have a plugin folder in my user library, I tried it in the normal location and everything seems to be working fine. Just thought I'd mention.
                  OSX 10.6.8 and SU8
                  Fantastic plugin by the way, I've only played a few minutes and it seems really useful!
                  Cheers.
                    You are correct. ๐Ÿ˜ฒ
                    The tool's documents contain an error.
                    You should install all Plugins into the root [hd] Library path Plugins folder... NEVER the 'user' one !
                    Hopefully Didier will read this and update his tool's docs - it is quite an old toolset...
                      De Marco
                      I have an qestion if someone could create connect this plugin with shortcuts it was only one demage of this fantastic plugin
                        You can make you own Shortcut ๐Ÿ˜‰
                        See Menu Window / Preferences / Shortcuts / View / Toolbars / Projections ๐Ÿ˜‰
                        • unclebimU Offline
                          unclebim
                          Unfortunately it is me too and I also wonder what is the problem?
                          • E Offline
                            ephi
                            cool!thanks a lot.
                            • jo-keJ Offline
                              jo-ke
                              can't find this one in the pluginstore...
                              is it possible to install it on SU2013?
                              http://www.zz7.de
                              • jo-keJ Offline
                                jo-ke
                                solved!
                                http://www.zz7.de
                                  JPC2j3
                                  I'm cluless how to use this extension. I'm trying the most simple thin I can imagine: to draw parallel and perpendicular lines. This seems to be the only plugin/extensiopn I can find that might do these opoerations.
                                  1. Is the right plugin?
                                  2. Is there a usaers manual?
                                  John
                                  • BoxB Offline
                                    John
                                    Seriously! Have you not read the other thread you started?
                                    • E Offline
                                      expresso405
                                      GREAT plugin! many thanks for it. Just wish it was easier to find in the "new" system!
                                        PluginStore Search...PluginStore_Search.PNGResult...Capture.PNG How much easier do you want it ?
                                        There's a Download button in the first post in this thread to take you to the PluginStore entry directly...Download.PNG
                                        • H Offline
                                          HirokaMatsuiko
                                          is it possible to add shortcut tried pilous method but seems cant figure it out how
                                          it doesnt appear in shortcut
                                          this is much powerful than SU default divide tool and i use this tool often .. because the knife tool artisan + dbur projection is much easier to use in parallel projection it snap easily
                                          • H Offline
                                            Hastalasnarices
                                            I've installed the Plugin Store and downloaded this plugin through it in Sketchup 2013. However, I'm not getting the toolbar and so I can't use it. I've tried manually installing the plugin but still no results. The plugin appears correctly installed under the Plugin Store's plugin manager. When I right-click on Sketchup and select "Toolbars", there's one named "Projections", but checking it or un-cheking it doesn't produce any results. No toolbars appear or disappear. Help, please!
                                            • 5 / 8
