    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 242.5k Views 61 Watching
      DIEGO-RODRIGUEZ
      a question.
      How can extrude line and get the result of this image?
      http://forums.sketchucation.com/download/file.php?id=29592&t=1
        TIG's extrudeEdgesByRails.rb... NOT yet on general release...
          dylan
          Look forward to it's release TIG πŸ‘
          http://dmdarchitecture.co.uk/
          • H
            Heven7_floor
            Thanks for your wonderful created things β˜€
            and kindly sharing for helpfully used in SU πŸ’š
            Cheer πŸ‘ πŸ‘
            • EdsonE
              Edson
              hi didier,
              would it be possible to include something in the code of PROJECTIONS that would remember the state of the tool bar (open or closed) when sketchup is opened, much like you did for Layer Manager? ok, you suggested we do it but it works the same way.
              thanks.
              http://www.mahfuz.arq.br
              • K
                K-TEE
                the best mission
                • Didier BurD
                  Didier Bur
                  mission
                  DB
                  • aadbuildA
                    aadbuild
                    Well done Didier, I dont know if any one else uses this for dimensioning but it saves so much time. I use guides to dimension so that the leader does not go through the model. It takes hours to dimension this way and now it takes minutes.
                    One question I read on the sketchucation forum that this plugin lets you assign attributes to faces . I did not see this... Must be a miss print
                    Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                    https://www.plusspec.com
                    • K
                      kenc3dan
                      Hi Didier,
                      It doesn't work at all in 7.1 for me on Windows XP.
                      I've read this entire thread and I can confirm that I have...
                      -projection_extension.rb in the Plugins folder
                      -All the PNGs and projection.rbs in the Projection folder inside the Plugins folder.
                      I can't wait to check this thing out! Such a cool set of tools!
                      Please let me know if there is some more recent version.
                      I've tried the version in your first post...
                      Re: [plugin] Projections version 2 UPDATED 03.07.09
                      and I've tried the patch in that same post.
                      Thanks so much!
                      • K
                        kenc3dan
                        Cancel that. πŸ˜•
                        Oops, forgot to activate the Projections toolbar under View > Toolbars.
                        Maybe this is happening to others?
                        Thanks again!
                          @didier bur said:
                          Developpers note: anyone knows how to smooth surfaces ? entity.smooth=true doesn't seem to work as expected.
                          You must soft and smooth
                          Smooth only hides the edge and makes the adjacent faces be treated as one surface.
                          To blend the shading of the adjacent faces you must also apply soft. Soft alone does not hide the edge - it only affects the face's shading.
                          Example in this thread:
                          http://forums.sketchucation.com/viewtopic.php?f=15&t=23239#p196744
                          • EdsonE
                            Edson
                            unfortunately, projections ceased to work for me on mac after i installed sketchup 7.1.
                              AcesHigh
                              Hi Didier... is it my umpression (maybe an old version?) or when projecting lines on a surface... it projects in only ONE SURFACE at a time? Meaning that if I have lets say a cube... and I want to project its lines over a sphere... I will then select only ONE surface from that sphere to project the cube, but the lines of the projection will keep on that surface plane...
                              If thats so, I wonder if you could somehow "join" TOOLS ON SURFACE with PROJECTIONS... so lets say I have a long winding road and I want to project it over a terrain... along ALL the terrain, not only a single face of the terrain...
                              • B
                                Borkur
                                This is one of the best plugins ever! Your a lifesafer. Many thanks for sharing it and all the work you put in.
                                Cheers
                                • EdsonE
                                  Edson
                                  for that you do not need either of these plugins. good old drape (one of the sandbox tools) will do it for you easily.
                                    dedmin
                                    Latest SketchUP:
                                    Error; #<NameError; uninitialized constant XLinesThrougLinesTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;26
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;26;in `call'
                                    Error; #<NameError; uninitialized constant XLineNormalThrougFaceTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;32
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;32;in `call'
                                    Error; #<NoMethodError; undefined method `xLineThrougIntersectionsFaces' for main;Object>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;38
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;38;in `call'
                                    Error; #<NameError; uninitialized constant XLinesAtIntervalsTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;44
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;44;in `call'
                                    Error; #<NameError; uninitialized constant XLinesAtDivisionsTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;50
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;50;in `call'
                                    Error; #<NameError; uninitialized constant XLinesAtRadialsTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;56
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;56;in `call'
                                    Error; #<NameError; uninitialized constant ProjectCpointTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;68
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;68;in `call'
                                    Error; #<NoMethodError; undefined method `cpointAtLineFaceIntersection' for main;Object>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;74
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;74;in `call'
                                    Error; #<NameError; uninitialized constant ProjectLinesOnPlaneTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;80
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;80;in `call'
                                    Error; #<NameError; uninitialized constant ProjectFacesOnPlaneTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;86
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;86;in `call'
                                    Error; #<NameError; uninitialized constant ProjectFacesAlongVectorTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;92
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;92;in `call'
                                    Error; #<NameError; uninitialized constant PushpullFacesAlongVectorTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;98
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;98;in `call'
                                    Error; #<NameError; uninitialized constant ProjectPushpullFacesAlongNormalsTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;104
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;104;in `call'
                                    Error; #<NameError; uninitialized constant ExtrudeLinesTool>
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;110
                                    C;/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb;110;in `call'
                                    • Didier BurD
                                      Didier Bur
                                      @dedmin: What do you think I can do with such a post ❓
                                      Please precise, whe n it occurs, doing what, never works, sometimes, OS, etc.
                                      DB
                                        dedmin
                                        Updated to the new version today and only the Add Guide point is working. This is what I get when trying to run the plugins:
                                        Video_2010-06-23_173314.wmv
                                          dedmin
                                          Ooops! Got it - didn't remove the old files! Everything is working now! Sorry and thanks! 😳 😳
                                          • Y
                                            Yvanou
                                            Hi evrebody!
                                            I've got a problem with Projection v2 plug in and Google SketchUp 7.1.
                                            I extracted all files in the Google SketchUp Plugins folder (as it explained in the PDF file: Projection_extension.rb and the Projection folder) but nothing appears in the tools bar while SketchUp runs.
                                            Do I forget something? Does somebody experiment the same problem?
                                            Thanx for your answers.
                                            • 5 / 8
