    1.5k Posts 470 Posters 3.3m Views 469 Watching
      @dave r said:
      Reread the first post of the thread and install LibFredo6 as it tells you. πŸ˜’
      it also returns some V-Ray for SkechUp related errors.... it's a strange error...
        Two different plugin install problems?
          Dunno - it's very strange. Unless they where both installed at the same time - incorrectly. ...but VfS has an installer.
          Screenshot of the plugins folder?
          • E Offline
            eshghe_2p
            thanks a lot! πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜›
              Does that mean installing LibFredo6 fixed your problem?
              • E Offline
                eshghe_2p
                yes it does. but when i want to use this plugin recive this error :
                http://photos.uvs.ir/img/18ac3fe3df6f.jpg
                what i have to do ?
                  First off it's Trimble now, so you have an older version of SketchUp 8...
                  What are you trying to do when it splats ?
                    I recommend you update as they try to fix causes to BugSplats in every release.
                    • E Offline
                      eshghe_2p
                      my sketchup is pro
                      does it mean i have to installing google sketchup 8 im my camputer again ?
                        No! Just install the current version. It hasn't been Google SketchUp since the middle of last year. Just update to the current release. Click on Help and Check for Updates.
                        • E Offline
                          eshghe_2p
                          when i do this work give this massage :
                          Due to US Export Regulations, we are unable to process your request at this time.
                          what i have to do new ?
                            Contact SketchUp Customer Support on Monday.
                            • E Offline
                              eshghe_2p
                              ok thanks
                              but how to do it?
                                Try this.
                                • E Offline
                                  eshghe_2p
                                  @dave r said:
                                  Try this.
                                  thank you very much πŸ˜„
                                  good luck
                                    mikedifilippo
                                    So I cant get the round corner plugin to work. I installed Fredo6 and then round corner, the 3 tool toolbar shows up but NOTHING ELSE. Here is a screen shot. Can anyone help?Screen Shot 2013-02-24 at 11.20.47 PM.png
                                    Sketchup version 8.0.16845
                                    and fredo and round corner are up to date according to the "check plugins for up to date"
                                    • fredo6F Offline
                                      Can you open the Ruby console and tell if you see an error message when you click on a RoundCorner icon.
                                      Also check the dimension of the offset in the palette and the dimensions of your model.
                                      Finally, this type of problem may come from a conflict with other plugins.
                                      There is a list of plugins known to create some comaptibility problems at this post. This may clash with RoundCorner.
                                        mikedifilippo
                                        Thank you for the quick response. Yes, if I click the first tool this comes up in the ruby console, I have no other plugins installed.
                                        "Error: #<Errno::EACCES: Permission denied - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Fredo6Trace.txt>
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in open'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in trace6' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:314:in init_palette'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:127:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in launch_action'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in command_invoke'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1074:in build_config_commands' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in call'
                                        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in add_command' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in call'
                                          mikedifilippo
                                          I think I got it, I went to my plugins folder and permissions were set to read only, i made it read and write and now it shows up
                                            burnedchicken
                                            Yes, I can confirm that this also fixed it for me on MacOX 10.7.5
                                            thanks for the cool plugin btw. This is life-saver....
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 73
                                            • 74
                                            • 13 / 74
