    1.5k Posts 477 Posters 4.2m Views 477 Watching
      Two different plugin install problems?
        Dunno - it's very strange. Unless they where both installed at the same time - incorrectly. ...but VfS has an installer.
        Screenshot of the plugins folder?
        • E
          eshghe_2p
          @dave r said:
          Reread the first post of the thread and install LibFredo6 as it tells you. πŸ˜’
          thanks a lot! πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜›
            Does that mean installing LibFredo6 fixed your problem?
            • E
              eshghe_2p
              yes it does. but when i want to use this plugin recive this error :
              http://photos.uvs.ir/img/18ac3fe3df6f.jpg
              what i have to do ?
                First off it's Trimble now, so you have an older version of SketchUp 8...
                What are you trying to do when it splats ?
                  I recommend you update as they try to fix causes to BugSplats in every release.
                  • E
                    eshghe_2p
                    my sketchup is pro
                    does it mean i have to installing google sketchup 8 im my camputer again ?
                      No! Just install the current version. It hasn't been Google SketchUp since the middle of last year. Just update to the current release. Click on Help and Check for Updates.
                      • E
                        eshghe_2p
                        when i do this work give this massage :
                        Due to US Export Regulations, we are unable to process your request at this time.
                        what i have to do new ?
                          Contact SketchUp Customer Support on Monday.
                          • E
                            eshghe_2p
                            ok thanks
                            but how to do it?
                              Try this.
                              • E
                                eshghe_2p
                                @dave r said:
                                Try this.
                                thank you very much πŸ˜„
                                good luck
                                  mikedifilippo
                                  So I cant get the round corner plugin to work. I installed Fredo6 and then round corner, the 3 tool toolbar shows up but NOTHING ELSE. Here is a screen shot. Can anyone help?Screen Shot 2013-02-24 at 11.20.47 PM.png
                                  Sketchup version 8.0.16845
                                  and fredo and round corner are up to date according to the "check plugins for up to date"
                                  • fredo6F
                                    Can you open the Ruby console and tell if you see an error message when you click on a RoundCorner icon.
                                    Also check the dimension of the offset in the palette and the dimensions of your model.
                                    Finally, this type of problem may come from a conflict with other plugins.
                                    There is a list of plugins known to create some comaptibility problems at this post. This may clash with RoundCorner.
                                      mikedifilippo
                                      Thank you for the quick response. Yes, if I click the first tool this comes up in the ruby console, I have no other plugins installed.
                                      "Error: #<Errno::EACCES: Permission denied - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Fredo6Trace.txt>
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in open'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in trace6' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:314:in init_palette'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:127:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in launch_action'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in command_invoke'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1074:in build_config_commands' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in call'
                                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in add_command' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in call'
                                        mikedifilippo
                                        I think I got it, I went to my plugins folder and permissions were set to read only, i made it read and write and now it shows up
                                        • B
                                          burnedchicken
                                          Yes, I can confirm that this also fixed it for me on MacOX 10.7.5
                                          thanks for the cool plugin btw. This is life-saver....
                                            daviddeboer
                                            I just downloaded the Roundcorners Plugin, and it shows up when I open Sketchup under View<Tool Palettes<Round Corner, but once I open it up and try to use it, nothing happens. I can see the toolbar, and I can select any one of the three options, but from there...nothing.
                                            I'm not sure if I downloaded it wrong or what, but anyone have any ideas?
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 74
                                            • 75
                                            • 34 / 75
