    1.5k Posts 477 Posters 4.0m Views 477 Watching
      First off it's Trimble now, so you have an older version of SketchUp 8...
      What are you trying to do when it splats ?
        I recommend you update as they try to fix causes to BugSplats in every release.
        • E Offline
          eshghe_2p
          my sketchup is pro
          does it mean i have to installing google sketchup 8 im my camputer again ?
            No! Just install the current version. It hasn't been Google SketchUp since the middle of last year. Just update to the current release. Click on Help and Check for Updates.
            • E Offline
              eshghe_2p
              when i do this work give this massage :
              Due to US Export Regulations, we are unable to process your request at this time.
              what i have to do new ?
                Contact SketchUp Customer Support on Monday.
                • E Offline
                  eshghe_2p
                  ok thanks
                  but how to do it?
                    Try this.
                    • E Offline
                      eshghe_2p
                      @dave r said:
                      Try this.
                      thank you very much πŸ˜„
                      good luck
                        mikedifilippo
                        So I cant get the round corner plugin to work. I installed Fredo6 and then round corner, the 3 tool toolbar shows up but NOTHING ELSE. Here is a screen shot. Can anyone help?Screen Shot 2013-02-24 at 11.20.47 PM.png
                        Sketchup version 8.0.16845
                        and fredo and round corner are up to date according to the "check plugins for up to date"
                        • fredo6F Offline
                          Can you open the Ruby console and tell if you see an error message when you click on a RoundCorner icon.
                          Also check the dimension of the offset in the palette and the dimensions of your model.
                          Finally, this type of problem may come from a conflict with other plugins.
                          There is a list of plugins known to create some comaptibility problems at this post. This may clash with RoundCorner.
                            mikedifilippo
                            Thank you for the quick response. Yes, if I click the first tool this comes up in the ruby console, I have no other plugins installed.
                            "Error: #<Errno::EACCES: Permission denied - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Fredo6Trace.txt>
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in open'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in trace6' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:314:in init_palette'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:127:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in launch_action'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in command_invoke'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1074:in build_config_commands' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in call'
                            /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in add_command' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in call'
                              mikedifilippo
                              I think I got it, I went to my plugins folder and permissions were set to read only, i made it read and write and now it shows up
                                burnedchicken
                                Yes, I can confirm that this also fixed it for me on MacOX 10.7.5
                                thanks for the cool plugin btw. This is life-saver....
                                  daviddeboer
                                  I just downloaded the Roundcorners Plugin, and it shows up when I open Sketchup under View<Tool Palettes<Round Corner, but once I open it up and try to use it, nothing happens. I can see the toolbar, and I can select any one of the three options, but from there...nothing.
                                  I'm not sure if I downloaded it wrong or what, but anyone have any ideas?
                                    Most likely an installation error. Make sure you put all of the required files where they belong when you installed it. also make sure you installed LibFredo6 correctly as well. In both cases the info you need is in the first posts of the threads. Also, as indicated in the first post of this thread, make sure you've enabled full read and write permissions for the Plugins folder.
                                      If you open the Ruby Console (Under the Windows menu) and then try to activate the tool - do you get any error messages then?
                                      • E Offline
                                        Elucidesign
                                        Image should be self explanatory.
                                        The Info Area is Nearly Unusable... Although hovering over the areas ... I can kindof make out what they might do...
                                        I managed to enter the Chamfer Distance for example.
                                        Fredo: Is this within the arena of something you'd (like to) be able to address?
                                        Looks like a pretty necessary, and useful plugin.
                                        Mac Retina.
                                        SU Free.
                                        Fredo6 RoundCorners.
                                        Sincerely, Sef.
                                        • fredo6F Offline
                                          Unfortunately, it seems there is no control of the size of text characters from the Ruby API (and I don't have a Mac).
                                          Maybe you could try to go to the Preferences disalog box and see if you can change the size of text labels. May be this will influence the size of text drawn from the Ruby API.
                                            JGraf82
                                            Fredo;
                                            Just found Sketucation, and specifically this plugin... Have been doing this by hand as best I could for more than a month. So, I just wanted to stop in and say that after downloading the file, and trying it out on an incredibly complex shape (succeeding in seconds mind you)... You have officially blown my mindgrapes!
                                            Thank you sincerely,
                                            JGraf82
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 74
                                            • 75
                                            • 34 / 75
