    Barley Twist Spirals
    119 Posts 12 Posters 22.0k Views 12 Watching
      Gilles, yours shows a nice spiral or screw but that's not a barley twist. The barley twist consists of multiple starts. It is possible to make the barley twist with Screw, though.
      This is a three-start barley twist.
        the new classic πŸ˜‰
        • gillesG
          gilles
          Sorry Dave, there are two starts and I could have done n starts in one shot.
          OFF TOPIC
          components plus profiles in one shot:
            Pilou, you trot that video out every time someone asks how to draw anything. πŸ˜’ πŸ˜†
            That's not a barley twist either.
              Show the setup. And which version of Screw are you using.
              • gillesG
                gilles
                screw1_5.rb.
                select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
                  Thanks. that should help the OP.
                  Isn't it great there are usually multiple ways to arrive at the same point in SketchUp?
                  And you finally drew a barley twist. πŸ˜‰ Here's a cutter profile for that.
                  http://ecx.images-amazon.com/images/I/31uqkUSlwNL.jpg
                  • GaieusG
                    True but otherwise a brilliant solution!
                    (I could imagine Kito Raupp is Pilou himself in a humble disguise)
                    πŸ˜†
                    • gillesG
                      gilles
                      Here is a step by step.
                      profile
                      follow me around the circle
                      erase unwanted
                      intersect
                      erase unwanted
                      select the two profiles (center must be on blue axis at origin) run screw plugin
                      cut  unwanted whit zorro plugin
                      intersect
                      erase unwanted
                        archturn
                        @gilles said:
                        Made in one shot with screw1_5.rb.
                        AND it works also with components.
                        This is what we call a rope twist not a barley twist. The barley twist has another (interior) radius. The rope twist looks like rope - though your method may work for a barley twist as well. David R's is definitely a barley
                          Nice rope twist. πŸ˜‰
                            archturn
                            Love your solution but I need to fit it to the other part of my newel. Gilles method looks like it will work. In CAD I'll usually do a sweep of the newel profile then draw my barley twist profile - sweep the barley profile with the correct pitch then subtract it from my newel sweep. I wish I could do it this way (specifically the subtract function) in SU since this yields the most realistic geometry - though again Gilles looks pretty right (just needs more interior radius to be classified as a true barley twist). Thanks
                            • gillesG
                              gilles
                              Its up to you to create the good profile. πŸ’š
                              You can also do this with screw:
                                archturn, you could use the method I showed and create the transitions when you've finished. There isn't any reason you couldn't fit it to the rest of the turning. I did on the table legs. The transitions are similar to creating the pommels which I've showed in several other blog posts so I didn't bother with them in that one. The Screw plugin is nice, too. although you can do multiple starts the way Gilles shows, I would still make a single turn as a component and copy it as I did in the blog to keep file size down and make it easier to adjust the length.
                                • gillesG
                                  gilles
                                  Totally agree with this. πŸ‘
                                  • charly2008C
                                    charly2008
                                    here are two more options
                                      archturn
                                      I can see that I should have been visiting the forum more frequently instead of pulling my hair out. Awesome!!!
                                        Yes. You should have. πŸ˜‰ And as I wrote before, there's more than one way to arrive at the final result in SketchUp. This is a great example.
                                          archturn
                                          @charly2008 said:
                                          Charly
                                          I'm wondering how to use the "follow me keep" plugin". I installed it and though it shows up in my plugin menu nothing seems to happen when I click it.
                                          • massimoM
                                            massimo Moderator
                                            You have first to select both the path and the face and then run the plugin.
                                            • 1 / 6
