    Barley Twist Spirals
    119 Posts 12 Posters 17.6k Views 12 Watching
    • jeff hammondJ Offline
      do you mind giving a little background first? what's your current sketchup level? are you ok with using plugins or would you prefer to do it using native sketchup tools?
        archturn
        I'm probably an intermediate user. I'm fine with using plugins. I've looked in vain though to find one that will help
          This shows how I do them. And a couple of examples.
          http://farm4.staticflickr.com/3400/4632041011_06f915b614.jpg
          http://farm5.staticflickr.com/4020/4653175758_1c8f0707f8.jpg
          • pbacotP Offline
            screw.rb can make this pretty well and fast. But I bet the geometry created by Dave's method would be nicer.
            • gillesG Offline
              gilles
              There is no reason, it depends of how many steps you type in the prompt window.
              • gillesG Offline
                gilles
                Made in one shot with screw1_5.rb.
                AND it works also with components.
                  Gilles, yours shows a nice spiral or screw but that's not a barley twist. The barley twist consists of multiple starts. It is possible to make the barley twist with Screw, though.
                  This is a three-start barley twist.
                    the new classic πŸ˜‰
                    • gillesG Offline
                      gilles
                      Sorry Dave, there are two starts and I could have done n starts in one shot.
                      OFF TOPIC
                      components plus profiles in one shot:
                        Pilou, you trot that video out every time someone asks how to draw anything. πŸ˜’ πŸ˜†
                        That's not a barley twist either.
                          Show the setup. And which version of Screw are you using.
                          • gillesG Offline
                            gilles
                            screw1_5.rb.
                            select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
                              Thanks. that should help the OP.
                              Isn't it great there are usually multiple ways to arrive at the same point in SketchUp?
                              And you finally drew a barley twist. πŸ˜‰ Here's a cutter profile for that.
                              http://ecx.images-amazon.com/images/I/31uqkUSlwNL.jpg
                                True but otherwise a brilliant solution!
                                (I could imagine Kito Raupp is Pilou himself in a humble disguise)
                                πŸ˜†
                                • gillesG Offline
                                  gilles
                                  Here is a step by step.
                                  profile
                                  follow me around the circle
                                  erase unwanted
                                  intersect
                                  erase unwanted
                                  select the two profiles (center must be on blue axis at origin) run screw plugin
                                  cut  unwanted whit zorro plugin
                                  intersect
                                  erase unwanted
                                    archturn
                                    This is what we call a rope twist not a barley twist. The barley twist has another (interior) radius. The rope twist looks like rope - though your method may work for a barley twist as well. David R's is definitely a barley
                                      Nice rope twist. πŸ˜‰
                                        archturn
                                        Love your solution but I need to fit it to the other part of my newel. Gilles method looks like it will work. In CAD I'll usually do a sweep of the newel profile then draw my barley twist profile - sweep the barley profile with the correct pitch then subtract it from my newel sweep. I wish I could do it this way (specifically the subtract function) in SU since this yields the most realistic geometry - though again Gilles looks pretty right (just needs more interior radius to be classified as a true barley twist). Thanks
                                        • gillesG Offline
                                          gilles
                                          Its up to you to create the good profile. πŸ’š
                                          You can also do this with screw:
                                            archturn, you could use the method I showed and create the transitions when you've finished. There isn't any reason you couldn't fit it to the rest of the turning. I did on the table legs. The transitions are similar to creating the pommels which I've showed in several other blog posts so I didn't bother with them in that one. The Screw plugin is nice, too. although you can do multiple starts the way Gilles shows, I would still make a single turn as a component and copy it as I did in the blog to keep file size down and make it easier to adjust the length.
                                            • 1 / 6
