    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 27.8k Views 18 Watching
      For comparison here is a TIN (picture of it) provided in the same project. I think the engineers set the parameters for their needs. A SB skin made from the contours "looks better" than one from the TIN and shows some site features better (such as the dirt road winding down the slope). Still they must be from the same dataset.
      • F Offline
        @pbacot
        Here is a first result. Actually, considering that the terrain is rather regular and there are many contours closely spaced, I don't think it is necessary to have a very detailed grid (50 x 22 in the attached file).
        Note that I had to simplify the contours with Curvizard to keep an acceptable calculation time (here over 30 seconds, mostly related to the computation of the concave hull).
        DN house contours - pbacot - 6 Jan 13 - results.skp
        @Mac1
        I am not familiar with TIN algorithms, but it seems the one posted by pbacot does not reflect the fine granularity of the contours.
          Yes, I noticed the TIN was pretty simple. I am not sure I have the subset of readings they had for this project (would be interesting to compare to the output). Without having studied the process, I am guessing that more advanced extrapolation goes into creating contours. The civil engineer may have created the TIN for some soils or drainage analysis--and it may be just sufficient for those purposes.
          Those terrains look great for OUR general purpose: showing the new construction in a simulation of the site. I would be curious to see it at a higher resolution of quads. I don't think 30 sec is that long, though I imagine the time goes up exponentially when you try to add a little more detail. As I noted there is a rough road on the slope, which can be made out in the contours, but not sure it registers on the final topo. Also there is part of a drainage ditch on the right. Such an area might want more detail, if ever a way is worked out for selective resolution in adjoining parts--or a way go back in a redo an area such that it can be joined to the rest....
          But this definitely is giving a clean looking (without the oil-canning) surface with good geometry. Thanks for the effort and sharing the great results!
          • F Offline
            Here is a more detailed reconstruction of the terrain, with a grid 120 x 53. This one takes less than a minute.
            Indeed, the best would be to adjust the granularity of the mesh based on the resulting terrain shape itself (more than the density of the contours actually).
            • U Offline
              utiler
              Sorry to sound a little dumb but Fredo what is the process you're doing here?
              1. Start with imported contours
              2. run through Curviloft
              Just Curious...
                Yes, that's looking quite muscular. that's worth a minute, depending if you can handle the number of polygons in the end. Thanks for posting! Looks like progress is good.
                • F Offline
                  Toposhaper uses a different algorithm which is more adapted to terrains and can cope with connection of more than two contours (for example when you have a saddle). It also works on a quad mesh.
                  So it is a very different approach compared with Curviloft
                  • U Offline
                    utiler
                    Thanks Fredo, so if I triangulated points with your triangulate plugin then ran toposhaper I'd get this result!!!!???
                    Just Curious...
                      Panga
                      Nice evolution Fredo, I'm still waiting for this magical tool !! Keep up the good work and I'll hit the donate button again !! πŸ˜‰
                      • F Offline
                        Here is the terrain with a much higher definition 200 x 88, so around 35,000 triangles generated. Takes longer of course, but does not bring a lot more details compared with the low and medium definitions terrains.
                        DN house contours - pbacot - High Def.skp
                        • F Offline
                          With TopoShaper you really need to have contours as curves, not a set of altitude points. This is because the Terrain construction uses contours to delimit the zone of influence on points comprised between contours.
                          With a set of altitude points, the algorithm would be more based on Skinning, with Bezier or Nurbs methods, which is another kind of script (I can do it, but it would definitely not be very fast with Ruby only).
                          So, all you need is the contours and then run Toposhaper, as shown in previous videos and the video below
                          PS: As far as I remember, I have not written (yet) a "triangulate plugin".
                            Panga
                            Fredo,
                            During my works I found a workaround with altitude points. I draw a high vertical line on each point (as they're usually components, it's a very fast operation), this way the sandbox is using contours instead of points, ignoring the bottom point of each line. Will this method work with your plugin ?
                            • F Offline
                              Unfortunately, it won't work. TopoShaper really needs contours to drive the interpolation. Keep in maind that with only altitude points, there are multiple solutions because you cannot isolate zones just with scarced points.
                              • U Offline
                                utiler
                                Fredo, I assume Toposhaper is a work in progress and hasn't been released yet? I can't find it for download...
                                Cheers,
                                Just Curious...
                                • F Offline
                                  Cheers,
                                  Correct, it is work in progress. However, I think I have done most of the algorithmics now and should be able to release a first simple version soon.
                                  In the meantime, I am still interested in getting models of contours to test the plugin.
                                  • U Offline
                                    utiler
                                    OK, do you want them in DWG or SU? I'll send a few through....
                                    Just Curious...
                                      I'm "cooking" one up in Sandbox right now. I'll send the file when it gets done. Taking about 10 min. to do "from contours". It's a nice one with hills and saddles.
                                        twestover
                                        Will the plugin work with an already triangulated surface?
                                        Say I have imported and triangulated a set of XYZ data, and wish to turn it into a solid group like your final product, with vertical sides and a horizontal bottom. Is that possible?
                                        • U Offline
                                          utiler
                                          Fredo, would you like contours in DWG or SU?
                                          Just Curious...
                                          • F Offline
                                            I prefer SU as I am not familiar with CAD and Archi software (I don't know DWG format).
                                            Thanks in advance
                                            • 4 / 5
