    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 34.0k Views 18 Watching
    • utilerU
      utiler
      Fredo, I assume Toposhaper is a work in progress and hasn't been released yet? I can't find it for download...
      Cheers,
      Just Curious...
      • fredo6F
        Cheers,
        Correct, it is work in progress. However, I think I have done most of the algorithmics now and should be able to release a first simple version soon.
        In the meantime, I am still interested in getting models of contours to test the plugin.
        • utilerU
          utiler
          OK, do you want them in DWG or SU? I'll send a few through....
          Just Curious...
          • pbacotP
            I'm "cooking" one up in Sandbox right now. I'll send the file when it gets done. Taking about 10 min. to do "from contours". It's a nice one with hills and saddles.
            • T
              twestover
              Will the plugin work with an already triangulated surface?
              Say I have imported and triangulated a set of XYZ data, and wish to turn it into a solid group like your final product, with vertical sides and a horizontal bottom. Is that possible?
              • utilerU
                utiler
                Fredo, would you like contours in DWG or SU?
                Just Curious...
                • fredo6F
                  I prefer SU as I am not familiar with CAD and Archi software (I don't know DWG format).
                  Thanks in advance
                    Except one! SU Itself πŸ˜‰
                    • utilerU
                      utiler
                      Here's a few contour Skippy's, Fredo.
                      Survey01 - contours or a regular residential site of about 800sqm with a 15m fall. Contours at 250mm....
                      survey01.skp
                      Survey02 - contours over a commercial development site of about 2800sqm. Contours at 200mm increments with minimum grad.
                      survey02.skp
                      Just Curious...
                      • fredo6F
                        Andrew
                        First of all, thanks very much for posting these 2 samples. They are extremely useful for fine tuning the algorithms.
                        I have problem about the calculation of the concave hull for the first one, but here is the second one, in 2 flavors:
                        • the original altitude (which are very flattish)
                        • the exaggerated altitudes which help me to better check the calculations
                        utiler_survey02.skp
                        • KrisidiousK
                          Krisidious
                          subscribed... 😲
                          By: Kristoff Rand
                          • utilerU
                            utiler
                            No problem, Fredo, I'm not surprised at issues with the first one as it was a survey of a site with an existing residence on it which prevented a uniform data to be taken...
                            What you've done with the other one looks good! Can't wait to see how this plugin ends up. I'll see if I can dig out some other survey plans off file and convert them for you.
                            πŸ‘
                            Just Curious...
                            • fredo6F
                              I evolved the algorithm for calculating the concave hull on your complex model and could obtain a result on your model, without any change, here attached.
                              A lot of the problem come from the small terminations hooks in several contours, like illustrated on the picture below
                              The issue with terrain construction is that you need to have a correct hull in order to determine the spatial distribution of the influence of the contours.
                              utiler_survey01.skp
                              PS: I hope to finish a first version in 2-3 weeks time, as I have actually very few moment available currently
                              • EarthMoverE
                                EarthMover
                                Can't wait! Thanks Fredo!
                                Content Creator at Skapeup
                                • utilerU
                                  utiler
                                  that is looking very sweet, Fredo!!!! Can't wait as well!!!
                                  Just Curious...
                                  • KrisidiousK
                                    Krisidious
                                    here's a topo I just got from a survey company... if you need tests.
                                    HANNA-TOPO.dwg
                                    By: Kristoff Rand
                                    • EarthMoverE
                                      EarthMover
                                      Here's another set of contour lines from my current project. All welded up.
                                      Coleman Topo.skp
                                      • pbacotP
                                        I've gone ahead and started using one of the tests you made of my contour set, Fredo. I don't have a lot to do as yet but it was really clean leveling some areas and "filling" others with Artisan. Maybe we can illustrate the cut and fill on the project with before and AFTER terrains. Thanks!
                                        • fredo6F
                                          Adam,
                                          Here is what I obtain on the original file. I think however that the contour should be simplified a little bit because there are a lot of edges and it slows down the calculation.
                                          Earthmover Coleman Topo.skp
                                          • EarthMoverE
                                            EarthMover
                                            A quick play with the contours. Simplified the curves using Thom's Edge Tools. Then did a From Contours terrain. Then a Drape Cpoints / Triangulate method to retopo. Then opened the high res contour lines in 3ds Max and used the free Populate Terrain plugin to generate a similar terrain. Then brought it back into sketchup and compared the two.
                                            Earthmover Coleman Topo (1).skp
                                            • 4 / 5
