    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 30.7k Views 18 Watching
    • fredo6F Offline
      @utiler said:
      Thanks Fredo, so if I triangulated points with your triangulate plugin then ran toposhaper I'd get this result!!!!???
      With TopoShaper you really need to have contours as curves, not a set of altitude points. This is because the Terrain construction uses contours to delimit the zone of influence on points comprised between contours.
      With a set of altitude points, the algorithm would be more based on Skinning, with Bezier or Nurbs methods, which is another kind of script (I can do it, but it would definitely not be very fast with Ruby only).
      So, all you need is the contours and then run Toposhaper, as shown in previous videos and the video below
      PS: As far as I remember, I have not written (yet) a "triangulate plugin".
        Panga
        Fredo,
        During my works I found a workaround with altitude points. I draw a high vertical line on each point (as they're usually components, it's a very fast operation), this way the sandbox is using contours instead of points, ignoring the bottom point of each line. Will this method work with your plugin ?
        • fredo6F Offline
          Unfortunately, it won't work. TopoShaper really needs contours to drive the interpolation. Keep in maind that with only altitude points, there are multiple solutions because you cannot isolate zones just with scarced points.
          • utilerU Offline
            utiler
            Fredo, I assume Toposhaper is a work in progress and hasn't been released yet? I can't find it for download...
            Cheers,
            Just Curious...
            • fredo6F Offline
              Cheers,
              Correct, it is work in progress. However, I think I have done most of the algorithmics now and should be able to release a first simple version soon.
              In the meantime, I am still interested in getting models of contours to test the plugin.
              • utilerU Offline
                utiler
                OK, do you want them in DWG or SU? I'll send a few through....
                Just Curious...
                • pbacotP Offline
                  I'm "cooking" one up in Sandbox right now. I'll send the file when it gets done. Taking about 10 min. to do "from contours". It's a nice one with hills and saddles.
                    twestover
                    Will the plugin work with an already triangulated surface?
                    Say I have imported and triangulated a set of XYZ data, and wish to turn it into a solid group like your final product, with vertical sides and a horizontal bottom. Is that possible?
                    • utilerU Offline
                      utiler
                      Fredo, would you like contours in DWG or SU?
                      Just Curious...
                      • fredo6F Offline
                        I prefer SU as I am not familiar with CAD and Archi software (I don't know DWG format).
                        Thanks in advance
                          Except one! SU Itself πŸ˜‰
                          • utilerU Offline
                            utiler
                            Here's a few contour Skippy's, Fredo.
                            Survey01 - contours or a regular residential site of about 800sqm with a 15m fall. Contours at 250mm....
                            survey01.skp
                            Survey02 - contours over a commercial development site of about 2800sqm. Contours at 200mm increments with minimum grad.
                            survey02.skp
                            Just Curious...
                            • fredo6F Offline
                              Andrew
                              First of all, thanks very much for posting these 2 samples. They are extremely useful for fine tuning the algorithms.
                              I have problem about the calculation of the concave hull for the first one, but here is the second one, in 2 flavors:
                              • the original altitude (which are very flattish)
                              • the exaggerated altitudes which help me to better check the calculations
                              utiler_survey02.skp
                              • KrisidiousK Offline
                                Krisidious
                                subscribed... 😲
                                By: Kristoff Rand
                                • utilerU Offline
                                  utiler
                                  No problem, Fredo, I'm not surprised at issues with the first one as it was a survey of a site with an existing residence on it which prevented a uniform data to be taken...
                                  What you've done with the other one looks good! Can't wait to see how this plugin ends up. I'll see if I can dig out some other survey plans off file and convert them for you.
                                  πŸ‘
                                  Just Curious...
                                  • fredo6F Offline
                                    I evolved the algorithm for calculating the concave hull on your complex model and could obtain a result on your model, without any change, here attached.
                                    A lot of the problem come from the small terminations hooks in several contours, like illustrated on the picture below
                                    The issue with terrain construction is that you need to have a correct hull in order to determine the spatial distribution of the influence of the contours.
                                    utiler_survey01.skp
                                    PS: I hope to finish a first version in 2-3 weeks time, as I have actually very few moment available currently
                                    • EarthMoverE Offline
                                      EarthMover
                                      Can't wait! Thanks Fredo!
                                      Content Creator at Skapeup
                                      • utilerU Offline
                                        utiler
                                        that is looking very sweet, Fredo!!!! Can't wait as well!!!
                                        Just Curious...
                                          Krisidious
                                          here's a topo I just got from a survey company... if you need tests.
                                          HANNA-TOPO.dwg
                                          By: Kristoff Rand
                                            EarthMover
                                            Here's another set of contour lines from my current project. All welded up.
                                            Coleman Topo.skp
                                            • 4 / 5
