    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
    • cottyC Offline
      cotty
      @tig said:
      but try renaming skindigo.rb to skindigo.rb! and restarting SketchUp; see if TOS appears then... Sometimes uncommon scripts have unexpected results on 3rd party tools...
      I don't think that Skindigo by Whaat have to do with this, I use both without any problems ...
      my SketchUp gallery
        @cotty said:
        ...I don't think that Skindigo by Whaat have to do with this, I use both without any problems ...
        I agree that it's probably completely innocent, it was a last ditch attempt to see if there was some unexpected clash...
          galinette
          Damned...
          Could it be incompatibility with the newer version of LibFredo (4.6)?
          By the way, I just upgraded Sketchup to 8.0.15158
          Etienne
            No known issues with the latest Lib - indeed it fixed an issue...
            Let's backtrack...
            TOS is an Extension.
            Have you treble checked that it is not listed under Preferences > Extensions
            called 'Tools On Surface'.
            If it is then activate it by 'ticking' it.
            Once it's activated then you might also have to activate its toolbar from the View > Toolbars menu - called 'Tools On Surface'
              galinette
              Nothing like Tools on Surface in extensions. I just noticed that roundcorners is not listed as well.
              I used RoundCorners by the past with sketchup 7, with no issues. Recently, I reinstalled to Sketchup 8, added LibFredo, JoinPushPull, RoundCorners and Tools on Surface. Only JoinPushPull is listed and works.
              And of course I looked in the toolbars menu! I use plugins from quite a while, but this time it is a mess...
              I will try on another computer with a fresh sketchup install just in case.
                galinette
                Well, I deleted all plugins, re-downloaded all, everything works...
                Sorry for the mess
                Etienne
                  Weird! 😲
                  But at least it's fixed.
                  Although we don't know how exactly... 😕
                    Perhaps the problem has to do with the order of events? I've assisted several users who have Win7 and had problems getting plugins to work. They tried installing the plugin prior to setting the admin privileges for the Plugins folder correctly. Removing the .rb file from the folder and installing it anew allowed it to work.
                    • sicksickisckS Offline
                      sicksickisck
                      great plugin 😍 but I need more shapes maybe shape editor [in commercial version ]
                        Drape or intersect?
                          No. Intersect isn't difficult and it is a fundamental thing to know how to use in SketchUp.
                            sicksickisck
                            Intersect 😎 [difficult ?].
                            edit : ...or both... I like how "tools on surface" works 😉
                              metagamer
                              I've been playing around with this tool for a day, and I really like its potential. But I'm having a really hard time getting the shapes I draw to turn into surfaces to use with the Joint Push Pull tool. For example, I extrude a simple cylinder (using built-in tools), and then draw a rect, a circle and a hexagon on the side using ToS. Sometimes it creates a face that I can use with JPP, sometimes it doesn't, and I can't figure out why. Any clues?
                                It works for me. How large is the cylinder?
                                Or are you getting a result something like this?
                                In this case the left edge of the rectangle falls on one of the natural softened edges of the cylinder. You can see that edge if you turn on Hidden Geometry under the View menu. You'll have to unsoften that edge to separate the rectangle from the rest of the surface. You can do that with the native Line tool or the Line tool in ToS and just connect the ends of the adjacent edges of the rectangle. Or you can display Hidden Geometry, select that edge and unsoften it.
                                • jgbJ Offline
                                  jgb
                                  Faster; easier ..... Shift+Ctrl Erase (tool) Just click on the soft "missing" line segment.
                                  jgb
                                    dakenyon27
                                    I can't seem to get this fantastic plugin working on sketchup 2013. Can anyone help?
                                    David.
                                      Sure. But we need some useful information. What do you mean you can't get it working? What happens when you start SketchUp? Do you get an error message related to the plugin?
                                      Did you install the required LibFredo6 files as spelled out in the first post in the thread? How did you install the files? Do you have Administrative privileges for the Plugins folder?
                                        Can you please describe the problem?
                                        Installation problems? Operation problems? Errors?
                                          martosurf
                                          FRedo thanks a lot for all good plugins
                                          You a great thanks a lot
                                            alek_mc
                                            hi... I have a problem with this plugin... I installed the sketchup pro 2013 and when I started the program, one message said that the plugin can't been uploaded... what can I do?
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
