    1.5k Posts 471 Posters 3.3m Views 470 Watching
      You have spotted an issue that many MAC users [and some PC users too] fall over on...
      You must have FULL access-rights to the 'Plugins' folder to correctly install files and subfolders of files into it - either manually or using the new automated installer tool[s]. Also some scripts need to access the 'Plugins' folder to write log-files, make/access temporary directories etc. If you don't have FULL access-rights you'll get failures when these operations are blocked...
      The same access-rights apply to the main Components, Materials and Styles folders - where from time to time you will want to add files either directly out of your SKP or adding them manually...
      • fredo6F Offline
        This problem of permission is a real issue.
        Sketchup should allow installing plugins in private drives, including network drives (for instance when shared in schools among a group of students). This will avoid a lot of problems when installing, reinstalling or working with several machines.
        That's what I have tried to address with my utility 000_AdditionalPluginFolders but I hope Trimble will find a more native solution.
          From hints at Basecamp they are considering where Plugins get stored on a per user basis for the next big update... which should then fix these issues... πŸ˜’
            jean1979
            thx been looking for this plugin
              theibel
              Thank you! Incredible plugin. Very powerful and it's so easy to use, I feel like I'm doing something wrong.
              Tom
              God gave you a brain, it's what you do with it that counts.
                design54
                i did that, the other plugins those need libredo6 work, but the round corner doesnot, only the small tool bar appear when click.; no action
                also when i install the libfredo and lunch the sketchup; a massage told me that the libfredo cannot create the file
                (defoaram_dir) and ask me to do it manually
                (my computer is mac not windows)
                  Now we have an answer. πŸ’­
                  You have limited permissions to 'read/write' to your Plugins folder.
                  Change these permissions to FULL for you/ALL.
                  Do you know how to [re]set a folder's permissions?
                  Then you and/or the tool can write its temporary folder/files with impunity.
                  Fixed ! πŸ˜„
                    design54
                    thank you very much, its worked πŸ˜„
                      steve69
                      I installed the plugins into the plugin folder and set the FULL PERMISSION TO THE PLUGIN folder (including the enclosed folders, files).
                      I set up a test case: a simple 12x12x12 inch cube with , after all edges highlighted, and offset set at 1inch, the green check mark appears. Then once I click outsid the object, it processes to 61 then bam! sketchup crashes.
                      Any help would be appreciated. Im using SU7.1 on Mac OSX 10.6.8
                      • fredo6F Offline
                        If this is systematic, i.e; whatever the model, simple or complex, then it might come from a conflict with another plugin like Podium (some versions), Matchbox, SketchupBIM (which I see you have installed)
                          SketchyPhysics makes many uncompatibilities with somes plugins!
                          rename just SketchyPhysics.rb in SketchyPhysics.rb1 and see what happen πŸ˜‰
                          Of course if you want to use it erase the "1" πŸ˜‰
                            steve69
                            Fredo6, Pilou
                            Thanks for the suggestions: mark this solved. Rather than go through and deactivate my other plugins until I found the incompatibilty, I installed a new copy of Sketchup (version 😎 and the plugin works.
                              pro saudi
                              hi Fredo6...
                              sorry that my English is bad... 😳
                              i would appreciate that you can make this plugin to not blend the faces together so i can select one face without the other face
                              i usually draw 2 lines to separate Between the 3 faces (my 1 face, my 2 face and the generated corner)
                              if you can make it as a settings window or option menu (so no one complain because the new changes)
                              i hope that you understand what i mean
                              and thanks for the awesome plugin πŸ’š
                              • massimoM Offline
                                massimo Moderator
                                If you mean something like the picture below, just untick "soft" in "borders" and "inner edges". Anyway you can always do view-->hidden geometry in order to select single faces also with smooth/hidden edges.
                                  Sohaib_78
                                  I am using Sketchup pro 8 and I just want to know if this round corner plugin will work for Sketchup pro 8.
                                  I hand downloaded the plugin but while unzipping it gives an error.
                                  Can you help me?
                                    Of course it works in SketchUp 8. πŸ˜’
                                    Are we supposed to just guess at what the error message is? Or would you like to tell us?
                                      The unzipping process gives you error? Or after unzipping and placing the files in the plugins folder you get an error from SketchUp?
                                        Sohaib_78
                                        Thanks you for replying. I have attached an error message I am getting while unzipping the plugin. Please check it and let me know if I am doing thing wrong?
                                        Thanks,
                                        Sohaib Khan
                                        Error message
                                          You didn't install it correctly into the Plugins folder. The correct installation has been covered repeatedly in this thread. Please go back to the first post and make sure you follow the installation instructions.
                                            It's a WinRAR error. He's not even getting to the part of placing the files.
                                            I have no idea why that error occurs. That's an issue with WinRAR and your machine.
                                            I don't really use WinRAR so I can't say much about it. I just open ZIP files with Windows Explorer.
                                            You can use this utility though, let you install RBZ and ZIP files from within SU - and it will do the work for you.
                                            http://sketchucation.com/forums/viewtopic.php?t=42315
                                            • 11
                                            • 12
                                            • 73
                                            • 74
                                            • 10 / 74
