    [Plugin] Architect Tools
    119 Posts 32 Posters 171.1k Views 32 Watching
      @tig said:
      Click that link-button to see the mess you have unleashed...
      To be fair, if he used the Simple Installer to install RB or RBS files they would have ended up there without his knowledge. I added a warning before the download. RBZ or ZIP should install correctly though.
      But there's something else going on there. The loading errors almost indicate that the subfolders are loaded directly, before the root files are. I wonder if it's a plugin loader messing about - compounded with VirtualStore we got a nice big soup.
        Could it be some 'Compatibility Files' mess up in tandem with Rick Wilson's 'Organizer.rb' [which I spy in the list] which is stupidly loading files from subfolders 'out of turn' [which incidentally seems to have been removed from Smustard.com πŸ˜• ]
        If he has to use that tool, he must understand the current onus it places on him to add files into every tool's subfolder to prevent the contents auto-loading 'support' files, either out of turn, or when not needed...
          Nice catch! Organizer sneaks up upon me again! (Where's that update Rick??)
          Yes, that explains all these loading errors!
          • H Offline
            hygicell
            I deleted organiser.rb
            lo and behold !
            problem solved ! 😍
            thanks to all !
            Frank
            PS so finally, it had nothing to do with security permissions
            • yitzharY Offline
              yitzhar
              same error after installing and work with its suddenly start showing error
              this is what the ruby con' ...
              ps - have tt_lib2 2.6 latest and this 1.22
              su - latest and win7 64
              and one more thing - its still working
              load 'tt_plan_tools.rb'
              C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:37: warning: already initialized constant VERSION
              C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:38: warning: already initialized constant PREF_KEY
              Error: #<SyntaxError: (eval):38:in read_default': (eval):38:in read_default': compile error
              (eval):38: unterminated string meets end of file>
              (eval):155
              C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:50:in []' C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:90:in set_default'
              C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:45
              (eval):155:in `load'
              (eval):155
              look for us on facebook : creatioIL
                There's some strange errors here. Already initialized constants seem to indicate it's being loaded twice. Maybe your're running into VirtualStore problems.
                Have a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453 You can use that tool to quickly check if you have some files that have ended up in the VirtualStore.
                • yitzharY Offline
                  yitzhar
                  i have just chacked with the store plugin ... doesnt have it in it.
                  still the same error apears.
                    Do you have the 'organiser.rb' file in the Plugins folder ?
                    If so, then remove it and restart/retry...
                    • yitzharY Offline
                      yitzhar
                      no dont have organiser.rb ? 😞
                        When you manually use load 'tt_plan_tools.rb' you will get some warnings about Constants already set, because the tool has already set them when it auto-loaded as Sketchup started, and you are warned about resetting constants [although you are allowed to do so anyway!].
                        Then it seems to be having issues reading/setting 'defaults' ?
                        Have you tried running Sketchup as an Admin ?
                        Have you double-checked that you/ALL have FULL security permissions to the Plugins folder and all of its contents including subfolders and their contents ??
                        No 'Compatibility Files...' button/links at all ?
                        Have you edited the scripts .rb file and then saved it? Perhaps corrupting the encoding ?
                        Next: Screenshots of Plugins and relevant Lib subfolder showing all of the contents and the folder's paths in top-bar.
                        πŸ˜•
                        • yitzharY Offline
                          yitzhar
                          I didnt change the script at all, and i have full admin access to everything...
                          and didnt understand what you ment in the screen shot ? what do you need ?
                            Can you try what TIG suggested? Typing load 'tt_plan_tools.rb' in the Ruby Console.
                            That should give a better error message that includes line and position number which might give us a clue.
                            Btw, what version of TT_Lib2 do you have?
                            • yitzharY Offline
                              yitzhar
                              the massage is the one i wrote in the page i copy paste it in the error question.
                              the tt_lib2 is the latest i think its 2.6
                                See my PM reply and see if the next version of TT_Lib helps.
                                • yitzharY Offline
                                  yitzhar
                                  That would be posible in 5 hours from now when i finish working at the office
                                  but thank you i got the test and i would write you later on.
                                  • yitzharY Offline
                                    yitzhar
                                    wow - good job !!!
                                    the problem solved with the new tt_lib2 ...
                                    thank you very much.
                                      Excellent! πŸ˜„
                                        Version 2.0.0
                                        See first post for more info.
                                        I don't expect people to immediately work out how to use these tools. They are very specific to my workflow with modelling site plans.
                                        This release has been done for a long time, but I've not had time to create the videos and description for it yet. Still haven't, but it should come soon. ("Soon" is as precise as I can be.)
                                        • utilerU Offline
                                          utiler
                                          Gee, that got my attention!!!! Can't wait for the videos, Thom!!!!
                                          Just Curious...
                                            matt.gordon320
                                            Thanks thomthom!
                                            • 4 / 6
