    [Plugin] Architect Tools
    119 Posts 32 Posters 176.9k Views 32 Watching
      Could it be some 'Compatibility Files' mess up in tandem with Rick Wilson's 'Organizer.rb' [which I spy in the list] which is stupidly loading files from subfolders 'out of turn' [which incidentally seems to have been removed from Smustard.com πŸ˜• ]
      If he has to use that tool, he must understand the current onus it places on him to add files into every tool's subfolder to prevent the contents auto-loading 'support' files, either out of turn, or when not needed...
        Nice catch! Organizer sneaks up upon me again! (Where's that update Rick??)
        Yes, that explains all these loading errors!
        • H
          hygicell
          I deleted organiser.rb
          lo and behold !
          problem solved ! 😍
          thanks to all !
          Frank
          PS so finally, it had nothing to do with security permissions
          • yitzharY
            yitzhar
            same error after installing and work with its suddenly start showing error
            this is what the ruby con' ...
            ps - have tt_lib2 2.6 latest and this 1.22
            su - latest and win7 64
            and one more thing - its still working
            load 'tt_plan_tools.rb'
            C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:37: warning: already initialized constant VERSION
            C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:38: warning: already initialized constant PREF_KEY
            Error: #<SyntaxError: (eval):38:in read_default': (eval):38:in read_default': compile error
            (eval):38: unterminated string meets end of file>
            (eval):155
            C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:50:in []' C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:90:in set_default'
            C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:45
            (eval):155:in `load'
            (eval):155
            look for us on facebook : creatioIL
              There's some strange errors here. Already initialized constants seem to indicate it's being loaded twice. Maybe your're running into VirtualStore problems.
              Have a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453 You can use that tool to quickly check if you have some files that have ended up in the VirtualStore.
              • yitzharY
                yitzhar
                i have just chacked with the store plugin ... doesnt have it in it.
                still the same error apears.
                  Do you have the 'organiser.rb' file in the Plugins folder ?
                  If so, then remove it and restart/retry...
                  • yitzharY
                    yitzhar
                    no dont have organiser.rb ? 😞
                      When you manually use load 'tt_plan_tools.rb' you will get some warnings about Constants already set, because the tool has already set them when it auto-loaded as Sketchup started, and you are warned about resetting constants [although you are allowed to do so anyway!].
                      Then it seems to be having issues reading/setting 'defaults' ?
                      Have you tried running Sketchup as an Admin ?
                      Have you double-checked that you/ALL have FULL security permissions to the Plugins folder and all of its contents including subfolders and their contents ??
                      No 'Compatibility Files...' button/links at all ?
                      Have you edited the scripts .rb file and then saved it? Perhaps corrupting the encoding ?
                      Next: Screenshots of Plugins and relevant Lib subfolder showing all of the contents and the folder's paths in top-bar.
                      πŸ˜•
                      • yitzharY
                        yitzhar
                        I didnt change the script at all, and i have full admin access to everything...
                        and didnt understand what you ment in the screen shot ? what do you need ?
                          Can you try what TIG suggested? Typing load 'tt_plan_tools.rb' in the Ruby Console.
                          That should give a better error message that includes line and position number which might give us a clue.
                          Btw, what version of TT_Lib2 do you have?
                          • yitzharY
                            yitzhar
                            the massage is the one i wrote in the page i copy paste it in the error question.
                            the tt_lib2 is the latest i think its 2.6
                              See my PM reply and see if the next version of TT_Lib helps.
                              • yitzharY
                                yitzhar
                                That would be posible in 5 hours from now when i finish working at the office
                                but thank you i got the test and i would write you later on.
                                • yitzharY
                                  yitzhar
                                  wow - good job !!!
                                  the problem solved with the new tt_lib2 ...
                                  thank you very much.
                                    Excellent! πŸ˜„
                                      Version 2.0.0
                                      See first post for more info.
                                      I don't expect people to immediately work out how to use these tools. They are very specific to my workflow with modelling site plans.
                                      This release has been done for a long time, but I've not had time to create the videos and description for it yet. Still haven't, but it should come soon. ("Soon" is as precise as I can be.)
                                      • utilerU
                                        utiler
                                        Gee, that got my attention!!!! Can't wait for the videos, Thom!!!!
                                        Just Curious...
                                          matt.gordon320
                                          Thanks thomthom!
                                          • L
                                            leot
                                            Thanks but not working on SketchUp Mac version
                                            • 5 / 6
