    [Plugin] Architect Tools
    119 Posts 32 Posters 163.2k Views 32 Watching
    • H Offline
      hygicell
      I deleted organiser.rb
      lo and behold !
      problem solved ! 😍
      thanks to all !
      Frank
      PS so finally, it had nothing to do with security permissions
      • yitzharY Offline
        yitzhar
        same error after installing and work with its suddenly start showing error
        this is what the ruby con' ...
        ps - have tt_lib2 2.6 latest and this 1.22
        su - latest and win7 64
        and one more thing - its still working
        load 'tt_plan_tools.rb'
        C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:37: warning: already initialized constant VERSION
        C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:38: warning: already initialized constant PREF_KEY
        Error: #<SyntaxError: (eval):38:in read_default': (eval):38:in read_default': compile error
        (eval):38: unterminated string meets end of file>
        (eval):155
        C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:50:in []' C:/PROGRA~2/Google/GOOGLE~1/Plugins/TT_Lib2/settings.rb:90:in set_default'
        C:/PROGRA~2/Google/GOOGLE~1/Plugins/tt_plan_tools.rb:45
        (eval):155:in `load'
        (eval):155
        look for us on facebook : creatioIL
          There's some strange errors here. Already initialized constants seem to indicate it's being loaded twice. Maybe your're running into VirtualStore problems.
          Have a look at this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399#p434453 You can use that tool to quickly check if you have some files that have ended up in the VirtualStore.
          • yitzharY Offline
            yitzhar
            i have just chacked with the store plugin ... doesnt have it in it.
            still the same error apears.
              Do you have the 'organiser.rb' file in the Plugins folder ?
              If so, then remove it and restart/retry...
              • yitzharY Offline
                yitzhar
                no dont have organiser.rb ? 😞
                  When you manually use load 'tt_plan_tools.rb' you will get some warnings about Constants already set, because the tool has already set them when it auto-loaded as Sketchup started, and you are warned about resetting constants [although you are allowed to do so anyway!].
                  Then it seems to be having issues reading/setting 'defaults' ?
                  Have you tried running Sketchup as an Admin ?
                  Have you double-checked that you/ALL have FULL security permissions to the Plugins folder and all of its contents including subfolders and their contents ??
                  No 'Compatibility Files...' button/links at all ?
                  Have you edited the scripts .rb file and then saved it? Perhaps corrupting the encoding ?
                  Next: Screenshots of Plugins and relevant Lib subfolder showing all of the contents and the folder's paths in top-bar.
                  πŸ˜•
                  • yitzharY Offline
                    yitzhar
                    I didnt change the script at all, and i have full admin access to everything...
                    and didnt understand what you ment in the screen shot ? what do you need ?
                      Can you try what TIG suggested? Typing load 'tt_plan_tools.rb' in the Ruby Console.
                      That should give a better error message that includes line and position number which might give us a clue.
                      Btw, what version of TT_Lib2 do you have?
                      • yitzharY Offline
                        yitzhar
                        the massage is the one i wrote in the page i copy paste it in the error question.
                        the tt_lib2 is the latest i think its 2.6
                          See my PM reply and see if the next version of TT_Lib helps.
                          • yitzharY Offline
                            yitzhar
                            That would be posible in 5 hours from now when i finish working at the office
                            but thank you i got the test and i would write you later on.
                            • yitzharY Offline
                              yitzhar
                              wow - good job !!!
                              the problem solved with the new tt_lib2 ...
                              thank you very much.
                                Excellent! πŸ˜„
                                  Version 2.0.0
                                  See first post for more info.
                                  I don't expect people to immediately work out how to use these tools. They are very specific to my workflow with modelling site plans.
                                  This release has been done for a long time, but I've not had time to create the videos and description for it yet. Still haven't, but it should come soon. ("Soon" is as precise as I can be.)
                                  • utilerU Offline
                                    utiler
                                    Gee, that got my attention!!!! Can't wait for the videos, Thom!!!!
                                    Just Curious...
                                      matt.gordon320
                                      Thanks thomthom!
                                        leot
                                        Thanks but not working on SketchUp Mac version
                                          tulacong
                                          thank you very much
                                            rv1974
                                            Thomthom, I love the stylish look of your scripts (both toolbars and execution).
                                            P.S. May I request 'split face by grid' feature please?
                                            • 5 / 6
