    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 32.7k Views 18 Watching
    • fredo6F
      @pbacot said:
      Here's a house site set of contours anyone can experiment with
      On another layer there is TIN provided by the civil, if useful for comparison
      I welded the contours with Curvizard. I hope that's helpful.
      Peter
      Peter,
      Thanks very much for this model, which is very helpful for me to progress on the script.
      Toposhaper samples the contours on a grid, and therefore it is not necessary to have extra-smoothed contours. On the contrary, when there is less segments in contours, the calculation is much faster.
      In the attached SKP file, you'll have the resulting terrains
      • for your original model, with high-definition contours
      • for the same model after simplification of contours by Curvizard simplify (17 degerees).
        You can see that the generated terrains are almost identical. The simplified model takes 3 seconds (see video) whereas the original one takes over 30 seconds.
      TopoShaper pbacot model - 01 Jan 13.skp
      PS: There is still some work on the algorithms, for calculation of concave hull and extrapolating on the borders, and also some work to package a decent GUI.
      • pbacotP
        Fredo,
        Very good looking models! I suppose one can judge how it follows the contours by how much is buried or floating... and these look quite accurate, especially given that contours themselves are a more or less rough approximation of field conditions from point readings. (a further angle of the tool might be using other data like depth maps).
        I like that the created model uses all the extent of the contours and doesn't cut corners. The skirt is very nice. Have you got anywhere with adjusting complexity of the grid?
        All methods have trouble with the drainage ditches (the v-shaped contours). Perhaps these need to handled separately if one is in need of detail there. (this brings up something that I have experimented with a bit--how to "regrade" a portion of the mesh and join it to the original--or join two meshes). At least this tool gives a smooth result, whereas Sandbox can look all creased in the tight spots.
        I realized the first set of contours was quite fine. Surprising to me. This is from a civil in an old project. So it might be a good example of the definition created by some programs (the segments were tiny, a few inches long). I think your result is much more detailed than the TIN that came with the file.
        Happy New Year and THANKS for the fine contributions!
        Peter
          mac1
          IMHO there is a lesson to be learned.
          One cannot grab data and try to use without first understanding its quality.
          The OP info ,as I previously noted, was drastically under sampled in some areas. The sample interval( Both x , y and z) must be related to the gradients in that area
          As an experiment I used a xy plane with a small grid( one dimensional), set that at each level of the contours and intersected to get additional points( just at the several elevation levels). The results look very similar to Pabcots. Would not want to do this in a production sense. It is too labor intensive and prone to errors.
          The question I keep asking myself is: If it looks better is it?
          I could not find anything in the quick net search to answer that ❓
          • fredo6F
            @pbacot and mac1
            Grid refinement (both densify and undensify) is possible, though complex to handle, but with a quad mesh structure, it means that it will break the regularity of cells, i.e. one cell will be split into 4 smaller quads, or 4 quads will be replaced by one bigger quad.
            At this stage, I am trying to obtain a decent geometry with a regular grid in an acceptable time.
            pbacot: thanks for the model. If you have others, they will be welcome to perform further tests and validation.
            • simon le bonS
              simon le bon
              (From first page)
              http://sketchucation.com/forums/viewtopic.php?f=15&t=44282#p400386
              You probably need to use some external software (I have seen one some time ago, but I don't remember the name. It has export capability to Sketchup, can handle crests and is fully specialized on this problem of terrain shaping)./...
              Hi Fredo πŸ˜„
              your Toposhaper looks very promizing πŸ‘ πŸ‘ β˜€
              You were probably talking about Terragen
              ( Terragen 2.4 Free Version Now Available)
              Here a model made by Google Guy (G.G.):
              http://sketchup.google.com/3dwarehouse/details?mid=f4350227d1c9debd6623100010a93a06
              some really nice models by TaffGoch:
              http://sketchup.google.com/3dwarehouse/search?tags=Terragen
              http://i.snag.gy/NSHXP.jpg
              Here from [url=http://wetbanana.deviantart.com/:6upgx29j]Wetbanana terragen gallery[/url:6upgx29j]
              http://th05.deviantart.net/fs71/PRE/f/2012/347/d/e/rocky_cliffs_2_by_wetbanana-d5nxfwx.png
              picked up into Terragen forums:
              [url=http://www.planetside.co.uk/forums/index.php?topic=5763.msg59956#msg59956:6upgx29j]Re: Terrains For Google SketchUp?[/url:6upgx29j]
              For minimal effort your best bet would be to forget all about generating your own terrains and import real world elevation data instead. If I recall correctly you can directly import .dem files into sketchup. Try downloading some files from here and see if they work out for you.
              [url:6upgx29j]http://seamless.usgs.gov[/url:6upgx29j]
              The link appears to don't work πŸ˜•
              but this one is ok (free topo download in pdf)
              Illustrates available US Topos
              [url:6upgx29j]http://viewer.nationalmap.gov/viewer/[/url:6upgx29j]
              Historical Topographic Map Collection
              http://nationalmap.gov/historical/
              etc..
              ++simon.
              • fredo6F
                Simon,
                That was not Terragen. I really need to find this software.
                • PixeroP
                  Pixero
                  Was it this one: http://www.geocontrol2.com/e_index.htm
                  Or maybe one of these: http://vterrain.org/Packages/Artificial/
                  Or Leveller here: http://www.daylongraphics.com/
                  Or Grome: http://www.quadsoftware.com/index.php?m=section&sec=product&subsec=editor
                    Does this program was a "free" program ?
                    A plug or a complet program ? (MojoWorld, World Machine, Bryce 7...)
                    here maybe some little things? (in French and not aespecially for MAC! πŸ˜‰
                    http://www.igeomac.fr/igeomac/Applications_Mac.html
                    Scroll and see LandSerf ? Maybe not direct SU export but...
                    • fredo6F
                      I think I found it, this is SimuTerra by COMPUneering.
                      See link there: http://www.compuneering.com/simuterra.php;
                      It costs 200$ in Pro version and 100$ for an entry-level version.
                      It has some capability to export / import with Sketchup.
                      Fred
                      PS: there are interesting [url=http://www.compuneering.com/simuterraMovies.php:3g8iku5m]videos[/url:3g8iku5m] showing the capabilities of the software, including to draw roads and other landscaping decorations
                        mac1
                        Fredo:
                        Excellent as usual πŸ‘
                        Looks like a great program. πŸ‘ I Wonder how it compares to others like Arcgis. Would take a lots of testing to find out.
                        I also like their emphasis on model preprocessing. Think that is where novices like myself get in big trouble trying to use questionable data. Ran into this in some searching;
                        • Contours should always point upstream in valleys
                          Contours should always point downridge along ridges
                          Adjacent contours should always be sequential or equivalent
                          Contours should never split into two
                          Contours should never cross or loop
                          Contours should never spiral
                          Contours should never stop in the middle of a map
                          Liking to hit my finger with a hammer I tried this;
                          Used you ploy segmenter to get more consistent points on the contour lines, ignored some info ref above. In most cases used 80 segs , but during process kept eye on entity info and for some short segs keep count down close to orginal. Needs to be redone to remove warts but looks more reasonable to me vs like orginal.
                        contours simplified-post._mac1skp.skp
                        • pbacotP
                          Thank you Fred et al.
                          Here is another set of contours for testing from a civil engineer's file. I had to set the heights in my CAD drawing. I think I got it all right. In some of the twisted minor contours, I had to use what logic I have at my disposal...
                          I have not recurved these, and again they are higly segmented--and this seems to be a norm one would need to account for. So simplify (I can do this if there is a problem) and recurve as desired.
                          Sandbox creates over 42,000 faces.
                          Peter
                          DN house contours.skp
                            mac1
                            I have been trying to understand what the general accepted criteria is for "TINs". One site I have found ,which seems credible to me, states the segment length should be > then contour seperation. The rational for that is to avoid " flat triangles ".
                            Here are the links I found of interest. . Note the Harvard school link has good press for SU'
                            http://www.ian-ko.com/ Under resources check out the solution center
                            http://www.gsd.harvard.edu/gis/manual/contours/
                            Note these are more GIS centric and thus not one to one applicable to the limited SU intent for their TIN implementation.
                            • pbacotP
                              For comparison here is a TIN (picture of it) provided in the same project. I think the engineers set the parameters for their needs. A SB skin made from the contours "looks better" than one from the TIN and shows some site features better (such as the dirt road winding down the slope). Still they must be from the same dataset.
                              • fredo6F
                                @pbacot
                                Here is a first result. Actually, considering that the terrain is rather regular and there are many contours closely spaced, I don't think it is necessary to have a very detailed grid (50 x 22 in the attached file).
                                Note that I had to simplify the contours with Curvizard to keep an acceptable calculation time (here over 30 seconds, mostly related to the computation of the concave hull).
                                DN house contours - pbacot - 6 Jan 13 - results.skp
                                @Mac1
                                I am not familiar with TIN algorithms, but it seems the one posted by pbacot does not reflect the fine granularity of the contours.
                                • pbacotP
                                  Yes, I noticed the TIN was pretty simple. I am not sure I have the subset of readings they had for this project (would be interesting to compare to the output). Without having studied the process, I am guessing that more advanced extrapolation goes into creating contours. The civil engineer may have created the TIN for some soils or drainage analysis--and it may be just sufficient for those purposes.
                                  Those terrains look great for OUR general purpose: showing the new construction in a simulation of the site. I would be curious to see it at a higher resolution of quads. I don't think 30 sec is that long, though I imagine the time goes up exponentially when you try to add a little more detail. As I noted there is a rough road on the slope, which can be made out in the contours, but not sure it registers on the final topo. Also there is part of a drainage ditch on the right. Such an area might want more detail, if ever a way is worked out for selective resolution in adjoining parts--or a way go back in a redo an area such that it can be joined to the rest....
                                  But this definitely is giving a clean looking (without the oil-canning) surface with good geometry. Thanks for the effort and sharing the great results!
                                  • fredo6F
                                    Here is a more detailed reconstruction of the terrain, with a grid 120 x 53. This one takes less than a minute.
                                    Indeed, the best would be to adjust the granularity of the mesh based on the resulting terrain shape itself (more than the density of the contours actually).
                                    • utilerU
                                      utiler
                                      Sorry to sound a little dumb but Fredo what is the process you're doing here?
                                      1. Start with imported contours
                                      2. run through Curviloft
                                      Just Curious...
                                      • pbacotP
                                        Yes, that's looking quite muscular. that's worth a minute, depending if you can handle the number of polygons in the end. Thanks for posting! Looks like progress is good.
                                        • fredo6F
                                          Toposhaper uses a different algorithm which is more adapted to terrains and can cope with connection of more than two contours (for example when you have a saddle). It also works on a quad mesh.
                                          So it is a very different approach compared with Curviloft
                                          • utilerU
                                            utiler
                                            Thanks Fredo, so if I triangulated points with your triangulate plugin then ran toposhaper I'd get this result!!!!???
                                            Just Curious...
                                            • 3 / 5
