[Plugin Library] LibFredo6 - v14.4d - 20 May 24
Thanks for these plugins!
NEW RELEASE: LibFredo6 v4.7a - 28 Nov 12
LibFredo6 4.7a is a major release dedicated to Curvizard 1.1.
update translation...
Chinese language -
Hi Fredo,
This is the new translation for LibFredo6 Spanish (Spain) Language.
LibFredo6 Spanish Language (Spain) -
I just updated the LibFredo, FredoScale, and FredoTools. Looks like I did something wrong. I saw in br51 post at page 34 the same issue, I tried to fix it, following his post but It didn't work...
Any help
I'm a Mac user OSX 10.8.2 (Mountain Lion)
You seem to have resinstalled over a fresh SU version.
At least, you need to create the folder DEFPARAM_Dir manually (as indicated) because it cannot be done from the Ruby script for some security reasons.
Adjust your main 'plugins' folder security permissions to FULL [read/write] for ALL and have it trickle down to all contents, subfolders too...
Otherwise, you will forever be having issues installing tools into there, and also with some tools that need to write temp/log files, or to make their own subfolders etc in there... -
Yes I had expecting some SU issues, and the SU support advice me to reinstall.
After that I became to have installations problem that I hadn't before, but I follow all Fredo's and TIG advice and looks like it works...Thanks for all your support...
good plugin!!!! thank you !!! but it doesn't work in milimeters DDDD
What are you talking about? What doesn't work with millimeters? The LibFredo06 files are, as described in the first post of this thread, just a shared library used by other plugins. Is it one of those plugins that you are having trouble with? I'll bet any money all of Fredo's plugins work in millimeters.
yep now i ve changed settings instead of 50 cm 0.5mm. anyway thanks
@slocraftus
What are you talking about ?
This is a 'Lib' thread which does nothing but help other tools work.
If you have an issue with one of the related tools post in that thread.
This is nonsense otherwise... -
I think you refer to the offset value in RoundCorner.
As mentioned by TIG, this is not related to LibFredo6 itself.Fredo
This is not actually a comment on the latest LibFredo6, but more of a huge THANK YOU to Fredo6 and all of the people engaged in making the RB:s that are affiliated to Fredo6! You can tell there is a lot of work put into them.
These plugins are GREAT.
I think intermediate and advanced users of SU really have a lot of use for these plugins. Not only are the basic ideas for the functions very good but the code is also well written and the user friendliness is high.I work with architectural design and more free-form stuff and today I almost addicted to many of these RB:s by Fredo6.
(sorry for posting this here, I couldnยดt figure out how to send a message directly. Hope you see this)
/ KJS
its good thing and works very well
one question my eraser tool with ctrl also rounds corners is it because of this plugin?
It doesn't round corners, it just softens edges. This is native behavior and has nothing to do with LibFredo6 or the Round Corners plugin.
It sounds as if you would find this link a good thing. This, too.
please help me, i install the latest release of libfredo and round corner, but the round corner did not work.the small toolbar that contains 3 icons appears but when i want to use it the the tallbar that contain the measurement does not appear
Incorrectly installed. Go back to the first post of each thread and make sure you've installed both plugins correctly. The footprints of the plugins are given. Make sure they match in your Plugins folder.
thx Dave
Help.....I've tried numerous times to install LibFredo6 with no success. I've followed the instructions. I can see the folder and .rb file in my plugins folder but I can find nothing in the windows setting of SU. I've also attempted to install FredoScale and RoundCorner with no luck at all.
I'm running SU 8 on a Mac.
I'm new to the forum and am just delving into the world of plugins (which I am VERY excited about).
I appreciate any help. I know it's probably just one little thing I'm doing wrong.Thanks,
HT
