    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 652.0k Views 135 Watching
    • GaieusG
      Flyashy, you linked a profile, not a post.
      • cottyC
        cotty
        A simple one, but helpful...
        (Model info -> components -> Show component axes)
        my SketchUp gallery
          rv1974
          The Tips&Tricks thread would be a better place for this, but anyway,
          In case you produce a lot of vistas:
          1. Export your scenes with 'anti-aliasing off' and X2 demanded size 6000 pix wide instead of 3000 (well I'm sure you knew it already)
          2. Create Photoshop droplet (File-Automate-Create Droplet; google some tutorials in your internets) from your typical actions.
            For example: resize to 3000> add soft light layer> tweak it's transparency> shadows & highlights> smart sharpen> close file.
            Dudes, this is HUGE time saver. Actually there's no need to manually open Photoshop anymore
            Just drag & drop the folder with your pictures upon the droplet's exe icon and enjoy ๐Ÿ˜‰
          • pbacotP
            Just discovered the System settings> Open GL > Use hardware acceleration. Suddenly Sketchup looks sharp and smooth to work with. How can I have missed this before? ๐Ÿ˜ณ
            It "creeped -up" on me that my visual quality sucked (sketchy and disappearing lines) and I was told to look at this. It really cleared things up. At some point I had turned it off because of other graphic anomalies. So I think I will be going back and forth... ๐Ÿ˜•
              MikeFJaguar
              @rv1974 said:
              The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
              Clicking it wont change visually its state (stupid bug!). To see it changed one should move
              the cursor off the button.
              This one got me very frustrated, until I discovered it's just a slooow button!
              In Windows 7 at least, click the Lock/Unlock button and WAIT for a couple of seconds. Lo and behold the button icon changes!
              EDIT
              Hmm. I'm wrong, you're right! The cursor does need to be moved off the button. As you say, stupid bug. Perhaps I'm a stupid bug..r ๐Ÿ˜ณ
              • cottyC
                cotty
                You can toggle the "active cut" setting of a section plane with a double click...
                my SketchUp gallery
                  d12dozr
                  !!! ๐Ÿ‘ ๐ŸŽ‰ ๐Ÿ˜„
                  http://goo.gl/f7ooYh
                  • panixiaP
                    panixia
                    just discovered a DOH feature of the selection tool..
                    if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. ๐Ÿ˜ฒ
                    • cottyC
                      cotty
                      How could you select without this? ๐Ÿ˜›
                      (See here for details)
                      For complex selections, the combination with the parallel view can help a lot...
                      my SketchUp gallery
                        And for some Selection / un-selection try some combinaisons of SHIFT and / Or CTRL ๐Ÿ˜‰
                        • panixiaP
                          panixia
                          i know how to use selection and modifier, the only DOH part is about the change of behaviour from left/right direction
                            rv1974
                            Say you worked in Untitled.skp and suddenly your PC crashed. To discover the unknown location of autosave file start the blank file and make 'Save': it will show the folder with autosave folder.
                            • ToboboT
                              Tobobo
                              I have just found by accident that you can drag nested groups and components in the outliner from one to another and it keeps its location. ๐Ÿ˜ฎ
                              Toby
                              Philippians 4:13
                                Ooh! That's nice! I've never used the Outliner much, but that's a nice observation.
                                +1 from me!
                                  Yes, highlighting and moving containers within the Outliner works very much like Cut+PasteInPlace when you move groups/instances between 'parents' - just MUCH easier...
                                  It's also a useful way to open a nested container for editing, just find it 'by name' in the Outliner [benefit of naming sensibly!] and then select it and double-click it; and it's also best if View > Component Edit > Hide Rest of Model is toggled ON so you can see what you are doing [a shortcut-key to toggle this is de riguer]...
                                  • brodieB
                                    brodie
                                    Just found a new one. You can copy a line over and type 10', then, after hitting enter you can type /10 to get 10 equally spaced lines.
                                    I have been doing that as two separate functions forever (copying the line 10' to get the spacing right then copying it back and snapping it to the other line 10' away and THEN hitting /10).
                                    -Brodie
                                      ... and if you are not satisfy you can continue "*" "/" with any unity even different than settings untill taking another tool! ๐Ÿ˜„
                                      • arail1A
                                        arail1
                                        This is important to know also because it's one of the few things that tends to be consistent across most 3D software applications.
                                          MikeFJaguar
                                          Ctrl (in Windows) while orbiting lets me turn my model every which way! Fairly useless as an architectural user but a boon for modellers who make widgets. Doh!
                                          • GaieusG
                                            That's a "designed feature": Suspending the gravity setting
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
