    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 543.0k Views 135 Watching
    • Epix3DE Offline
      Epix3D
      Just discovered the System settings> Open GL > Use hardware acceleration. Suddenly Sketchup looks sharp and smooth to work with. How can I have missed this before? ๐Ÿ˜ณ
      • F Offline
        flyashy
        I have found this thread to be the MOST instructional of them all! So thanks to http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=15244 for starting it!
        I've done a lot of these and found some great tips in here.
        I thought I'd add one of mine that may help someone.
        Although with the save toolbars position, a lot of toolbar mayham has been solved, but I still get it sometimes when even restore toolbars won't work.
        I'd accidentally discovered this trick a while back when somehow all my toolbars had decided to go vertical or something!:
        So, if you get toolbar chaos, don't do anything to sketchup to restore position etc...just call up taskmanager-windows (or force quit-mac) and kill the sketchup process, immediately if you can. if the process is killed sketchup will revert back to the earlier 'saved toolbars' position and no more chaos.
        Cheers!
          Flyashy, you linked a profile, not a post.
          • cottyC Offline
            cotty
            A simple one, but helpful...
            (Model info -> components -> Show component axes)
            my SketchUp gallery
              rv1974
              The Tips&Tricks thread would be a better place for this, but anyway,
              In case you produce a lot of vistas:
              1. Export your scenes with 'anti-aliasing off' and X2 demanded size 6000 pix wide instead of 3000 (well I'm sure you knew it already)
              2. Create Photoshop droplet (File-Automate-Create Droplet; google some tutorials in your internets) from your typical actions.
                For example: resize to 3000> add soft light layer> tweak it's transparency> shadows & highlights> smart sharpen> close file.
                Dudes, this is HUGE time saver. Actually there's no need to manually open Photoshop anymore
                Just drag & drop the folder with your pictures upon the droplet's exe icon and enjoy ๐Ÿ˜‰
              • pbacotP Offline
                It "creeped -up" on me that my visual quality sucked (sketchy and disappearing lines) and I was told to look at this. It really cleared things up. At some point I had turned it off because of other graphic anomalies. So I think I will be going back and forth... ๐Ÿ˜•
                  MikeFJaguar
                  @rv1974 said:
                  The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
                  Clicking it wont change visually its state (stupid bug!). To see it changed one should move
                  the cursor off the button.
                  This one got me very frustrated, until I discovered it's just a slooow button!
                  In Windows 7 at least, click the Lock/Unlock button and WAIT for a couple of seconds. Lo and behold the button icon changes!
                  EDIT
                  Hmm. I'm wrong, you're right! The cursor does need to be moved off the button. As you say, stupid bug. Perhaps I'm a stupid bug..r ๐Ÿ˜ณ
                  • cottyC Offline
                    cotty
                    You can toggle the "active cut" setting of a section plane with a double click...
                    my SketchUp gallery
                      d12dozr
                      !!! ๐Ÿ‘ ๐ŸŽ‰ ๐Ÿ˜„
                      http://goo.gl/f7ooYh
                      • panixiaP Offline
                        panixia
                        just discovered a DOH feature of the selection tool..
                        if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. ๐Ÿ˜ฒ
                        • cottyC Offline
                          cotty
                          How could you select without this? ๐Ÿ˜›
                          (See here for details)
                          For complex selections, the combination with the parallel view can help a lot...
                          my SketchUp gallery
                            And for some Selection / un-selection try some combinaisons of SHIFT and / Or CTRL ๐Ÿ˜‰
                            • panixiaP Offline
                              panixia
                              i know how to use selection and modifier, the only DOH part is about the change of behaviour from left/right direction
                                rv1974
                                Say you worked in Untitled.skp and suddenly your PC crashed. To discover the unknown location of autosave file start the blank file and make 'Save': it will show the folder with autosave folder.
                                • ToboboT Offline
                                  Tobobo
                                  I have just found by accident that you can drag nested groups and components in the outliner from one to another and it keeps its location. ๐Ÿ˜ฎ
                                  Toby
                                  Philippians 4:13
                                    Ooh! That's nice! I've never used the Outliner much, but that's a nice observation.
                                    +1 from me!
                                      Yes, highlighting and moving containers within the Outliner works very much like Cut+PasteInPlace when you move groups/instances between 'parents' - just MUCH easier...
                                      It's also a useful way to open a nested container for editing, just find it 'by name' in the Outliner [benefit of naming sensibly!] and then select it and double-click it; and it's also best if View > Component Edit > Hide Rest of Model is toggled ON so you can see what you are doing [a shortcut-key to toggle this is de riguer]...
                                      • brodieB Offline
                                        brodie
                                        Just found a new one. You can copy a line over and type 10', then, after hitting enter you can type /10 to get 10 equally spaced lines.
                                        I have been doing that as two separate functions forever (copying the line 10' to get the spacing right then copying it back and snapping it to the other line 10' away and THEN hitting /10).
                                        -Brodie
                                          ... and if you are not satisfy you can continue "*" "/" with any unity even different than settings untill taking another tool! ๐Ÿ˜„
                                          • arail1A Offline
                                            arail1
                                            This is important to know also because it's one of the few things that tends to be consistent across most 3D software applications.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
