    [Plugin] CleanUp
    974 Posts 217 Posters 833.4k Views 217 Watching
    • BurkhardB Offline
      Burkhard
      @thomthom said:
      You haven't installed TT_Lib2. Listed as a requirement near the Download button - with a link.
      Maybe a button for automatic answers?
      [http://www.ia-plus.de(http://www.ia-plus.de)]
        That's a good idea. Of course the answers to the most common questions regarding plugin errors have already been answered in the first post of the thread. πŸ˜‰
          I'm changing my template for plugins - in the future they will bring up a messagebox and direct link to download the missing file. No amount of description will every catch all.
            penumbra
            Thomas
            Thanks for another great one. One question. See my attached screengrab. When i run Clean3 the window turns grey (like your other plugin vray tools). When the screen greys out i can still see the model, is almost like a preview window. Is that right? is there a preview feature that I am not seeing.
            I am using SU 8 Pro on Windows 7 machine if that helps.
            @N02/8183395292/" alt="http://www.flickr.com/photos/63538437@N02/8183395292/" class=" img-fluid img-markdown" />
            Curtain Wall
              There is no preview. It's just dimming the viewport to indicate that you should not interact with the model.
                pocahontas
                ->thomthom I LOVE YOU πŸ˜„)))) and your plugins. u saved my life and my master degree everything works great πŸ˜„ now.
                  πŸ˜„
                  Ah, the deadline panic. Glad it helped.
                    penumbra
                    Couldn't agree more. Thomas is an all around cool guy!
                    • bsintzelB Offline
                      bsintzel
                      jPeg Screenshot of Bitdefender alertThis is probably nothing...but, Bitdefender Internet Security 2013 has identified TT-Lib - 2.6.0\TT_Lib2\libraries\win32\tt_api.so as a Trojan.Generic.KD.811184
                      Either the signature recognized by Bitdefender is in error, or TT_api.so has been compromised. Just to be sure, would you please post the checksum of your original tt-cleanup plugin.
                      warm regards
                      p.s.
                      I use every script you've produced and had amazing results. A tip of my hat to you sir.
                      I've taken obfuscating to a whole new level!
                        I had a round with an update of Kaspersky that did the same thing. They've since correct it. Same thing here. Report it to Bitdefender as a false positive.
                        You mean the tt_api.so file of TT_Lib2, right? Because that's what is flagged here - not CleanUp.
                        • bsintzelB Offline
                          bsintzel
                          Thomas,
                          You are indeed correct in that I 'should have' referred to the tt_api.so file. Thanks for catching that.
                          warm regards
                            I suspect why occasionally it gets flagged is that it's a wrapper to the Win32API in Ruby - which include many system calls that causes the AV software to freak out.
                            • bsintzelB Offline
                              bsintzel
                              tt_api.so Hash ChecksumThomas,
                              Before I advise Bitdefender that tt_api.so is not a Trojan, could you please confirm the hash checksum of your tt_api.so against mine? At least that way, I can back up my assertion to the Bitdefender folks.
                              I've attached my tt_api.so specifics.
                              Thanks again
                                Jim
                                Here's mine - seems to concur:
                                  Snap! 😲
                                    File; tt_api.so
                                    Size; 28672 bytes
                                    MD5; 029CFD69417000AAEAFA35AD22223D6B
                                    SHA1; 34CC57D297C130523086FC2047F0812038A4E8AD
                                    SHA256; 2AC9C5B620B7BA7E10264466DA4C1AF8975AA49C8BED99195077518D0F40D2C4
                                    SHA384; A3D0A690D523FB90E60E3709600FC3E30997915B8EDAE95F1C455A8EAB6692121A36CB1003E24FD1602844DD325AD547
                                    SHA512; EB1D8A702390FA124346C11353CA9B4DB7455C42119B91A6DDE927BADE80A8327802859BED5E7C2E6F53B48E2F9CDD0D600B06FC614F4367298CAAFFBD68307C
                                      Does this inside Clean Up ?
                                      something similar than "Shift + eraser tool" for quasi coplanar segment on a face ?
                                        Sorry, but what?
                                          Pilou, have you been into the egg nog? πŸ˜† That's nothing like the way you usually write. πŸ˜‰
                                            aslansie
                                            que hago con ese archivo no se donde meterlo y no se ejecuta
                                            • 48
                                            • 49
                                            • 2 / 49
