    [Plugin] CleanUp
    974 Posts 217 Posters 984.3k Views 217 Watching
    • malchikM Offline
      malchik
      Hello,
      Please help solve the problem. I use the latest version
      CleanUp Β³ 3.1.9 update on 06 Oct 11
      The essence of the problem is that using a CleanUp report about remote
      is listed: Edges Reduced - 8. I shake OK, save, close the model.
      Open it again and apply CleanUp and again the same situation:
      Edges Reduced - 8
      It turns out that the removal of produced, but not saved. Anyone
      know the cause of this?
      Sometimes, after the first use CleanUp removes 8 Edges and if
      then apply a second time CleanUp, then the report would mean
      have 2 remote Edges.
      • pietervP Offline
        pieterv
        I just wanted to say thanks for this magnificent tool!! πŸ‘ πŸ‘ πŸ‘ πŸ˜„
        This is my website:
        Citypixels - 3d Visualisatie Architectuur
          deyvidpreato
          OMG!!! I just cant live without this plugin anymore!! thank you so much! the repair edges function is just perfect!
          Someone from Brazil is truly thankful for your work!
          You are awesome dude!
            matsuo_lano
            Works like a charm! My model went from 8,5 MB to a mere 2,3 MB!
            You try to rearrange me 'till I'm sane
              alexmarsh85
              Hey Thom Thom,
              Installing the tt_cleanup.rb on sketch up 8. I keep getting a,
              Error Loading File tt_cleanup.rb
              no such file to load -- TT_Lib2/core.rb
              Am I placing it in the wrong Windows/Program(x86)/..extension?
              Thanks Alex (Sefaira)
                You haven't installed TT_Lib2. Listed as a requirement near the Download button - with a link.
                  alexmarsh85
                  Thanks. Works a treat!
                  • BurkhardB Offline
                    Burkhard
                    Maybe a button for automatic answers?
                    http://www.ia-plus.de
                      That's a good idea. Of course the answers to the most common questions regarding plugin errors have already been answered in the first post of the thread. πŸ˜‰
                        I'm changing my template for plugins - in the future they will bring up a messagebox and direct link to download the missing file. No amount of description will every catch all.
                          penumbra
                          Thomas
                          Thanks for another great one. One question. See my attached screengrab. When i run Clean3 the window turns grey (like your other plugin vray tools). When the screen greys out i can still see the model, is almost like a preview window. Is that right? is there a preview feature that I am not seeing.
                          I am using SU 8 Pro on Windows 7 machine if that helps.
                          @N02/8183395292/" alt="http://www.flickr.com/photos/63538437@N02/8183395292/" class=" img-fluid img-markdown" />
                          Curtain Wall
                            There is no preview. It's just dimming the viewport to indicate that you should not interact with the model.
                              pocahontas
                              ->thomthom I LOVE YOU πŸ˜„)))) and your plugins. u saved my life and my master degree everything works great πŸ˜„ now.
                                πŸ˜„
                                Ah, the deadline panic. Glad it helped.
                                  penumbra
                                  Couldn't agree more. Thomas is an all around cool guy!
                                  • bsintzelB Offline
                                    bsintzel
                                    jPeg Screenshot of Bitdefender alertThis is probably nothing...but, Bitdefender Internet Security 2013 has identified TT-Lib - 2.6.0\TT_Lib2\libraries\win32\tt_api.so as a Trojan.Generic.KD.811184
                                    Either the signature recognized by Bitdefender is in error, or TT_api.so has been compromised. Just to be sure, would you please post the checksum of your original tt-cleanup plugin.
                                    warm regards
                                    p.s.
                                    I use every script you've produced and had amazing results. A tip of my hat to you sir.
                                    I've taken obfuscating to a whole new level!
                                      I had a round with an update of Kaspersky that did the same thing. They've since correct it. Same thing here. Report it to Bitdefender as a false positive.
                                      You mean the tt_api.so file of TT_Lib2, right? Because that's what is flagged here - not CleanUp.
                                      • bsintzelB Offline
                                        bsintzel
                                        Thomas,
                                        You are indeed correct in that I 'should have' referred to the tt_api.so file. Thanks for catching that.
                                        warm regards
                                          I suspect why occasionally it gets flagged is that it's a wrapper to the Win32API in Ruby - which include many system calls that causes the AV software to freak out.
                                          • bsintzelB Offline
                                            bsintzel
                                            tt_api.so Hash ChecksumThomas,
                                            Before I advise Bitdefender that tt_api.so is not a Trojan, could you please confirm the hash checksum of your tt_api.so against mine? At least that way, I can back up my assertion to the Bitdefender folks.
                                            I've attached my tt_api.so specifics.
                                            Thanks again
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 48
                                            • 49
                                            • 32 / 49
