    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      deyvidpreato
      OMG!!! I just cant live without this plugin anymore!! thank you so much! the repair edges function is just perfect!
      Someone from Brazil is truly thankful for your work!
      You are awesome dude!
        matsuo_lano
        Works like a charm! My model went from 8,5 MB to a mere 2,3 MB!
        You try to rearrange me 'till I'm sane
          alexmarsh85
          Hey Thom Thom,
          Installing the tt_cleanup.rb on sketch up 8. I keep getting a,
          Error Loading File tt_cleanup.rb
          no such file to load -- TT_Lib2/core.rb
          Am I placing it in the wrong Windows/Program(x86)/..extension?
          Thanks Alex (Sefaira)
            You haven't installed TT_Lib2. Listed as a requirement near the Download button - with a link.
              alexmarsh85
              Thanks. Works a treat!
              • BurkhardB
                Burkhard
                Maybe a button for automatic answers?
                http://www.ia-plus.de
                  That's a good idea. Of course the answers to the most common questions regarding plugin errors have already been answered in the first post of the thread. πŸ˜‰
                    I'm changing my template for plugins - in the future they will bring up a messagebox and direct link to download the missing file. No amount of description will every catch all.
                    • P
                      penumbra
                      Thomas
                      Thanks for another great one. One question. See my attached screengrab. When i run Clean3 the window turns grey (like your other plugin vray tools). When the screen greys out i can still see the model, is almost like a preview window. Is that right? is there a preview feature that I am not seeing.
                      I am using SU 8 Pro on Windows 7 machine if that helps.
                      @N02/8183395292/" alt="http://www.flickr.com/photos/63538437@N02/8183395292/" class="img-markdown img-fluid" />
                      Curtain Wall
                        There is no preview. It's just dimming the viewport to indicate that you should not interact with the model.
                        • P
                          pocahontas
                          ->thomthom I LOVE YOU πŸ˜„)))) and your plugins. u saved my life and my master degree everything works great πŸ˜„ now.
                            πŸ˜„
                            Ah, the deadline panic. Glad it helped.
                            • P
                              penumbra
                              Couldn't agree more. Thomas is an all around cool guy!
                              • bsintzelB
                                bsintzel
                                jPeg Screenshot of Bitdefender alertThis is probably nothing...but, Bitdefender Internet Security 2013 has identified TT-Lib - 2.6.0\TT_Lib2\libraries\win32\tt_api.so as a Trojan.Generic.KD.811184
                                Either the signature recognized by Bitdefender is in error, or TT_api.so has been compromised. Just to be sure, would you please post the checksum of your original tt-cleanup plugin.
                                warm regards
                                p.s.
                                I use every script you've produced and had amazing results. A tip of my hat to you sir.
                                I've taken obfuscating to a whole new level!
                                  I had a round with an update of Kaspersky that did the same thing. They've since correct it. Same thing here. Report it to Bitdefender as a false positive.
                                  You mean the tt_api.so file of TT_Lib2, right? Because that's what is flagged here - not CleanUp.
                                  • bsintzelB
                                    bsintzel
                                    Thomas,
                                    You are indeed correct in that I 'should have' referred to the tt_api.so file. Thanks for catching that.
                                    warm regards
                                      I suspect why occasionally it gets flagged is that it's a wrapper to the Win32API in Ruby - which include many system calls that causes the AV software to freak out.
                                      • bsintzelB
                                        bsintzel
                                        tt_api.so Hash ChecksumThomas,
                                        Before I advise Bitdefender that tt_api.so is not a Trojan, could you please confirm the hash checksum of your tt_api.so against mine? At least that way, I can back up my assertion to the Bitdefender folks.
                                        I've attached my tt_api.so specifics.
                                        Thanks again
                                          Jim
                                          Here's mine - seems to concur:
                                            Snap! 😲
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 48
                                            • 49
                                            • 32 / 49
