    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
    • bsintzelB Offline
      bsintzel
      jPeg Screenshot of Bitdefender alertThis is probably nothing...but, Bitdefender Internet Security 2013 has identified TT-Lib - 2.6.0\TT_Lib2\libraries\win32\tt_api.so as a Trojan.Generic.KD.811184
      Either the signature recognized by Bitdefender is in error, or TT_api.so has been compromised. Just to be sure, would you please post the checksum of your original tt-cleanup plugin.
      warm regards
      p.s.
      I use every script you've produced and had amazing results. A tip of my hat to you sir.
      I've taken obfuscating to a whole new level!
        I had a round with an update of Kaspersky that did the same thing. They've since correct it. Same thing here. Report it to Bitdefender as a false positive.
        You mean the tt_api.so file of TT_Lib2, right? Because that's what is flagged here - not CleanUp.
        • bsintzelB Offline
          bsintzel
          Thomas,
          You are indeed correct in that I 'should have' referred to the tt_api.so file. Thanks for catching that.
          warm regards
            I suspect why occasionally it gets flagged is that it's a wrapper to the Win32API in Ruby - which include many system calls that causes the AV software to freak out.
            • bsintzelB Offline
              bsintzel
              tt_api.so Hash ChecksumThomas,
              Before I advise Bitdefender that tt_api.so is not a Trojan, could you please confirm the hash checksum of your tt_api.so against mine? At least that way, I can back up my assertion to the Bitdefender folks.
              I've attached my tt_api.so specifics.
              Thanks again
                Jim
                Here's mine - seems to concur:
                  Snap! ๐Ÿ˜ฒ
                    File; tt_api.so
                    Size; 28672 bytes
                    MD5; 029CFD69417000AAEAFA35AD22223D6B
                    SHA1; 34CC57D297C130523086FC2047F0812038A4E8AD
                    SHA256; 2AC9C5B620B7BA7E10264466DA4C1AF8975AA49C8BED99195077518D0F40D2C4
                    SHA384; A3D0A690D523FB90E60E3709600FC3E30997915B8EDAE95F1C455A8EAB6692121A36CB1003E24FD1602844DD325AD547
                    SHA512; EB1D8A702390FA124346C11353CA9B4DB7455C42119B91A6DDE927BADE80A8327802859BED5E7C2E6F53B48E2F9CDD0D600B06FC614F4367298CAAFFBD68307C
                      Does this inside Clean Up ?
                      something similar than "Shift + eraser tool" for quasi coplanar segment on a face ?
                        Sorry, but what?
                          Pilou, have you been into the egg nog? ๐Ÿ˜† That's nothing like the way you usually write. ๐Ÿ˜‰
                            aslansie
                            que hago con ese archivo no se donde meterlo y no se ejecuta
                              Sorry, but what?
                              For Simfonia ๐Ÿ˜‰ (Sorry in French but very visual! ๐Ÿ’š
                              See my little animation ๐Ÿ˜„ (you can make the same with the fre version that I use ๐Ÿ˜‰
                              Minute 1.16 for lines apparition and the "Shift erase" for hide them minute 3.00
                              The normal Clean Up don't works, (the lines come back as soon as the animation restarts) ๐Ÿ˜ฒ
                              only the "Shift + erase" works! ๐Ÿ˜ฎ
                                Did you also install TT_Lib? Read the requirements in the first post.
                                  Sorry, but what?
                                  So, you want to smooth+soften the edges instead of erasing them?
                                  In this particular example, since the faces are quads, you can use QuadFace Tools to create soft+smooth triangulation edge.
                                    Yes something like that but all in one clic! On my animation I had made one by one! ๐Ÿ˜ž
                                    And you say all are quads , in this example yes, but in general case that can be be any thing!
                                    I will try your QuadFace Tools
                                      cm1963
                                      Thom, excellent work. I downloaded and tried to install the plugin the usual manner (downloading directly to Plugins file), but it is still not appearing in the Plugins menue after I restart SU. It also did not work after I dragged and ropped the plugin in the Plugins file after an SU re-start. Please help, I am eager to try this plugin.
                                      Charle
                                      • massimoM Offline
                                        massimo Moderator
                                        Any error message in the Ruby console? Do you have also installed the required TT_lib2 as stated in the very first post under "Requirements"?
                                          Any error messages?
                                          Can you post screenshots of the files in the Plugins folder?
                                          • john2J Offline
                                            john2
                                            Alrighty
                                            Returned to working to SketchUp after a long time. Iโ€™ve been using this great plugin for years, I would like to resolve one doubt, the coplanar line doesnโ€™t get deleted using the cleanup command. This happens a lot of time during SketchUp. Iโ€™ve faced this issue. Can anyone tell me when does this conflict happen?
                                            My cleanup tool is otherwise RRRRROCKING. ๐Ÿ˜„ ๐Ÿ‘
                                            sample for doubt.skp
                                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 48
                                            • 49
                                            • 33 / 49
