    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • guanjinG
      guanjin
      Thanks for update again, but the language translation problems still exist, thank you!
        Research of the perfect voluptuous inaccessible curves! ☀
        • pbacotP
          Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
          • cottyC
            cotty
            Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
            my SketchUp gallery
            • fredo6F
              [attachment=0:2dklo00h]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
              Thanks for signaling the bug. I fixed it and will republish.
              But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
              • guanjinG
                guanjin
                [attachment=0:22t88ozw]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
                Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
                • OxerO
                  Oxer
                  Thanks Fredo for the update it's very useful !! 👍
                  The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                  Thanks again Fredo.
                  Spanish Language (Spain)
                  • fredo6F
                    Oxer,
                    Thanks very much for the update.
                    Note that part of the transaltion is in LibFredo
                    The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                    • OxerO
                      Oxer
                      Thanks Fredo!!
                      • fredo6F
                        NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                        Minor release over 1.1a:
                        • fix a problem in Cleanup Contour which cannot be launched
                        • fix to a problem for translation for the Quick Launcher
                        • Integration of Chinese translation (guanjin)
                        • Update to the Spanish (Spain) translation (Oxer)
                        • ArcA
                          Arc
                          Translation into Chinese...
                          Chinese language
                            smicha
                            Fredo, You are genius!!! Thank you so much for fantastic update.
                            • V
                              victor hugo
                              Pretty useful plugin!!!
                              I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
                              Thanks.
                              • cottyC
                                cotty
                                1.1c or 1.1d?
                                my SketchUp gallery
                                • V
                                  victor hugo
                                  I had 1.1c and just did 1.1d and the attched is what is showing
                                  Thanks.
                                  • cottyC
                                    cotty
                                    You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
                                    my SketchUp gallery
                                    • guanjinG
                                      guanjin
                                      I am also, but does not affect use.
                                        small08
                                        Amazing work Fredo, Thank-you!
                                          matt.gordon320
                                          Hi Fredo,
                                          I was wondering if you might be able to take a look at my office's model to see what might be causing the error(s) I'm getting? I've attached both the model and the error report.
                                          Matt
                                          Master Topo Clean ERROR.skp
                                          Ruby Error - Curvizard#simplify_curve - 10-Dec-12 13_43_35.txt
                                            Matt
                                            What are you trying to do when you get the error message ?
                                            Your post is too scant. 😕
                                            • 3 / 10
