    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • fredo6F
      NEW RELEASE: Curvizard v1.1a - 28 Nov 12
      Curvizard 1.1 is an interim version which introduces 3 new functions:
      • Smooth Contour, with 2 methods and several options for adjustments
      • Cleanup Contour, which just removes collinear edges and small spikes
      • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
      There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
      There is a video for the Smooth Contours function
      [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
      Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
      • utilerU
        utiler
        Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! πŸ‘ πŸ‘ πŸ‘
        Just Curious...
        • guanjinG
          guanjin
          Thanks for update again, but the language translation problems still exist, thank you!
            Research of the perfect voluptuous inaccessible curves! β˜€
            • pbacotP
              Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
              • cottyC
                cotty
                Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
                my SketchUp gallery
                • fredo6F
                  [attachment=0:2dklo00h]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
                  Thanks for signaling the bug. I fixed it and will republish.
                  But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
                  • guanjinG
                    guanjin
                    [attachment=0:22t88ozw]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
                    Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
                    • OxerO
                      Oxer
                      Thanks Fredo for the update it's very useful !! πŸ‘
                      The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                      Thanks again Fredo.
                      Spanish Language (Spain)
                      • fredo6F
                        Oxer,
                        Thanks very much for the update.
                        Note that part of the transaltion is in LibFredo
                        The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                        • OxerO
                          Oxer
                          Thanks Fredo!!
                          • fredo6F
                            NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                            Minor release over 1.1a:
                            • fix a problem in Cleanup Contour which cannot be launched
                            • fix to a problem for translation for the Quick Launcher
                            • Integration of Chinese translation (guanjin)
                            • Update to the Spanish (Spain) translation (Oxer)
                            • ArcA
                              Arc
                              Translation into Chinese...
                              Chinese language
                                smicha
                                Fredo, You are genius!!! Thank you so much for fantastic update.
                                • V
                                  victor hugo
                                  Pretty useful plugin!!!
                                  I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
                                  Thanks.
                                  • cottyC
                                    cotty
                                    1.1c or 1.1d?
                                    my SketchUp gallery
                                    • V
                                      victor hugo
                                      I had 1.1c and just did 1.1d and the attched is what is showing
                                      Thanks.
                                      • cottyC
                                        cotty
                                        You are right, it seems that in the 1.1d file "Curvizard.plugin" the version is still 1.1c ...
                                        my SketchUp gallery
                                        • guanjinG
                                          guanjin
                                          I am also, but does not affect use.
                                            small08
                                            Amazing work Fredo, Thank-you!
                                            • 3 / 10
