    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 323.3k Views 57 Watching
    • OxerO Offline
      Oxer
      I have installed the last versions of Curvizard and LibFredo and an error appears now.
      I work on Mac.
      • fredo6F Offline
        Oxer,
        This is very strange that the value for angle max is written 40,0 (with a comma).
        I can't reproduce how this has been made possible, because even if comma may be the decimal separator in Spanish (like in French), the Ruby code only uses the notation with '.' as the separator.
        Just to be sure, could you type the following in the Ruby console:
        { :a => 40.0 }.inspect
        To fix it, you may start any Curvizard tool and click on the AngleMax value of the edge picker section and type another value. Tell me if this work.
        • OxerO Offline
          Oxer
          Hi Fredo,
          I typed in Ruby Console and I obtain this:
          %(#FF0000)[> { :a => 40.0 }.inspect
          {:a=>40.0}]
          I select a curve then I press an icon tool of Curvizard but I can't see the Tool Options Menu.
          EDIT:
          I deleted the sketchup preferences and for the moment it works fine again (it's possible that the preferences file was corrupt).
          • N Offline
            nesh70
            I just wanna say thanks for all your amazing SU tools!!!
            πŸ‘ πŸ‘ πŸ‘
            • utilerU Offline
              utiler
              Hi Fredo, when converting an arc / circle to construction lines a point is added to its segment end. Is there a way of not doing so?
              And once again, thank you for what you do for SU!!
              Just Curious...
              • utilerU Offline
                utiler
                Anyone? Here's a screenshot of what I'm referring too...
                Just Curious...
                  Select all
                  Right Click /Select Only Guide Points / Delete ?
                    πŸ˜‰
                    • massimoM Offline
                      massimo Moderator
                      Like this? πŸ˜„
                        Efectively more speedy than my basic method! πŸ’š
                        • utilerU Offline
                          utiler
                          I knew it had to be something simple.... Thanks guys! πŸ‘ πŸ‘
                          Just Curious...
                            dedmin
                            Date; 25-Aug-13 05;57;22
                            An error occured in Curvizard#edge_prop
                            The operation is aborted
                            undefined method `length' for nil;NilClass
                            CurvizardAlgo.rb; 451 -- execute_geometry
                            CurvizardTool.rb; 1596 -- geometry_generate
                            CurvizardTool.rb; 1496 -- top_execute
                            CurvizardTool.rb; 290 -- handle_initial_selection
                            CurvizardTool.rb; 267 -- activate
                            CurvizardTool.rb; 46 -- select_tool
                            CurvizardTool.rb; 46 -- launch_tool
                            CurvizardTool.rb; 41 -- action__mapping
                            Lib6Plugin.rb; 134 -- call
                            Lib6Plugin.rb; 134 -- launch_action
                            bootstrap_Curvizard.rb; 51 -- launch_action
                            bootstrap_Curvizard.rb; 81 -- declare_command
                            Lib6Plugin.rb; 1044 -- call
                            Lib6Plugin.rb; 1044 -- command_invoke
                            Lib6Plugin.rb; 1026 -- build_config_commands
                            Lib6Traductor.rb; 1074 -- call
                            Lib6Traductor.rb; 1074 -- add_command
                              dedmin
                              http://screencast.com/t/9JjK72VbWeCd
                                kein2006
                                very nice plugin. It's really useful, thank you so much
                                • fredo6F Offline
                                  NEW RELEASE: Curvizard v1.4a - 15 Sep 13
                                  Curvizard 1.4a is a release with the following updates
                                  • New naming conventions
                                  • Fixes a major bug in the Edge Prop tool (which was not working)
                                  • Include an alternate icon toolbar by CadFather
                                  Curvizard 1.4 requires an upgrade to LibFredo6 5.2 or higher.
                                  • fredo6F Offline
                                    I am not sure I see the problem.
                                    But in any case, Simplify is not the opposite of Smooth.
                                    Furthermore, Smooth can be used to simplify a curve by incresing the angle, whereas Simplify just remove vertices based on a minimum angle
                                    • fredo6F Offline
                                      @dedmin said:
                                      [attachment=0:wmnznkk8]<!-- ia0 -->2013-08-25_055853.jpg<!-- ia0 -->[/attachment:wmnznkk8]
                                      The bug in Edge Prop tool should be fixed in Curvizard 1.4a.
                                      • guanjinG Offline
                                        guanjin
                                        Thank you updates, always so timely! πŸ‘
                                          dedmin
                                          Excellent and invaluable tools!!!
                                          No problems so far!
                                          Thanks!!
                                          • utilerU Offline
                                            utiler
                                            Thank you Fredo from all that use your tools!!!
                                            Just Curious...
                                            • 5 / 10
