    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 312.0k Views 57 Watching
    • guanjinG Offline
      guanjin
      Hello:Fredo6
      Translated language files, and can not be changed!
        blajnov
        Thanks for the plugin!!!
        Translation into Russian...
        Curvizard_RU.lang
        • cottyC Offline
          cotty
          I've seen the new features of V1.1 on youtube, can't wait to try 😉
          my SketchUp gallery
          • JClementsJ Offline
            JClements
            I saw the You-Tube demo too. Very interesting!
            • Rich O BrienR Online
              Wow....thanks Fredo
              • fredo6F Offline
                NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                Curvizard 1.1 is an interim version which introduces 3 new functions:
                • Smooth Contour, with 2 methods and several options for adjustments
                • Cleanup Contour, which just removes collinear edges and small spikes
                • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                There is a video for the Smooth Contours function
                [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                • utilerU Offline
                  utiler
                  Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                  purpose/expression/purpose/....
                  • guanjinG Offline
                    guanjin
                    Thanks for update again, but the language translation problems still exist, thank you!
                      Research of the perfect voluptuous inaccessible curves! ☀
                      • pbacotP Offline
                        Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
                        • cottyC Offline
                          cotty
                          Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
                          my SketchUp gallery
                          • fredo6F Offline
                            [attachment=0:2dklo00h]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
                            Thanks for signaling the bug. I fixed it and will republish.
                            But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
                            • guanjinG Offline
                              guanjin
                              [attachment=0:22t88ozw]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
                              Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
                              • OxerO Offline
                                Oxer
                                Thanks Fredo for the update it's very useful !! 👍
                                The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                                Thanks again Fredo.
                                Spanish Language (Spain)
                                • fredo6F Offline
                                  Oxer,
                                  Thanks very much for the update.
                                  Note that part of the transaltion is in LibFredo
                                  The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                                  • OxerO Offline
                                    Oxer
                                    Thanks Fredo!!
                                    • fredo6F Offline
                                      NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                                      Minor release over 1.1a:
                                      • fix a problem in Cleanup Contour which cannot be launched
                                      • fix to a problem for translation for the Quick Launcher
                                      • Integration of Chinese translation (guanjin)
                                      • Update to the Spanish (Spain) translation (Oxer)
                                      • ArcA Offline
                                        Arc
                                        Translation into Chinese...
                                        Chinese language
                                          smicha
                                          Fredo, You are genius!!! Thank you so much for fantastic update.
                                          • V Offline
                                            victor hugo
                                            Pretty useful plugin!!!
                                            I've downloaded the update 1.1c and installed per instructions and when I go to "Fredo tools" to "Check the Plugin Update"; Curvizard still shows in pink/red. I re-downloaded the file and it keeps saying I need to do update!!!??
                                            Thanks.
                                            • 4 / 10
