    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 322.9k Views 57 Watching
      RICALBUR
      Thank you for this post
      • guanjinG Offline
        guanjin
        Hello๏ผšFredo6
        Translated language files, and can not be changed!
          blajnov
          Thanks for the plugin!!!
          Translation into Russian...
          Curvizard_RU.lang
          • cottyC Offline
            cotty
            I've seen the new features of V1.1 on youtube, can't wait to try ๐Ÿ˜‰
            my SketchUp gallery
            • JClementsJ Offline
              JClements
              I saw the You-Tube demo too. Very interesting!
                Wow....thanks Fredo
                • fredo6F Offline
                  NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                  Curvizard 1.1 is an interim version which introduces 3 new functions:
                  • Smooth Contour, with 2 methods and several options for adjustments
                  • Cleanup Contour, which just removes collinear edges and small spikes
                  • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                  There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                  There is a video for the Smooth Contours function
                  [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                  Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                  • utilerU Offline
                    utiler
                    Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    Just Curious...
                    • guanjinG Offline
                      guanjin
                      Thanks for update again, but the language translation problems still exist, thank you!
                        Research of the perfect voluptuous inaccessible curves! โ˜€
                        • pbacotP Offline
                          Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
                          • cottyC Offline
                            cotty
                            Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
                            my SketchUp gallery
                            • fredo6F Offline
                              [attachment=0:2dklo00h]<!-- ia0 -->ๆœชๅ‘ฝๅ.jpg<!-- ia0 -->[/attachment:2dklo00h]
                              Thanks for signaling the bug. I fixed it and will republish.
                              But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
                              • guanjinG Offline
                                guanjin
                                [attachment=0:22t88ozw]<!-- ia0 -->ๆœชๅ‘ฝๅ.jpg<!-- ia0 -->[/attachment:22t88ozw]
                                Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
                                • OxerO Offline
                                  Oxer
                                  Thanks Fredo for the update it's very useful !! ๐Ÿ‘
                                  The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                                  Thanks again Fredo.
                                  Spanish Language (Spain)
                                  • fredo6F Offline
                                    Oxer,
                                    Thanks very much for the update.
                                    Note that part of the transaltion is in LibFredo
                                    The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                                    • OxerO Offline
                                      Oxer
                                      Thanks Fredo!!
                                      • fredo6F Offline
                                        NEW RELEASE: Curvizard v1.1c - 29 Nov 12
                                        Minor release over 1.1a:
                                        • fix a problem in Cleanup Contour which cannot be launched
                                        • fix to a problem for translation for the Quick Launcher
                                        • Integration of Chinese translation (guanjin)
                                        • Update to the Spanish (Spain) translation (Oxer)
                                        • ArcA Offline
                                          Arc
                                          Translation into Chinese...
                                          Chinese language
                                            smicha
                                            Fredo, You are genius!!! Thank you so much for fantastic update.
                                            • 10 / 10
