    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.8k Views 92 Watching
    • Bob JamesB
      Bob James
      @thomthom said:
      Once you where in quick-select mode (the little circle) did you then have to switch back and forth?
      I'm just trying to work out how the extra buttons you proposed end up with less clicks.
      Some times I wanted to start out using the "little circle". If there were a "little circle" icon I wouldn't have to [right click, set "select none", click the move icon] to get it.
      Sometimes I wanted to start out with the gizmo. If there were a gizmo icon I wouldn't have to right-click and unhide the gizmo. And then hide it again.
      Then, of course, there were the times that I'd start out with one and want to switch to the other in the course of correcting a set of vertices: right-click, select ....... πŸ˜’
      When I tried the shortcuts they got all mixed up with the standard SU shortcuts ("M" for move, etc.). The manual said that once in VT the shortcuts would not get confused with the standard ones. Not so in my experience.
      This is such a great tool: it's just that I felt like I was wasting a lot of time clicking menues.
      • Bob JamesB
        Bob James
        "You can get to the quick-select (little circle) very quickly by deselecting. Either use the menu item, a shortcut, or just click in empty space."
        (what happened to being able to identify this as a quote?)
        I'm sorry, but I don't understand this at all.
        • Deselect what?
        • Using menu items requires one or more extra clicks
        • Empty space where?: in the icon bar?
          @pbacot said:
          My setup here doesn't have a mouse that works like that, so I got in the habit of just using "O". Didn't know it mattered. Thanks
          The two methods of orbiting works quite differently, the middle mouse button return to the active tool. It's a very quick method of navigating a model - I'd recommend it to anyone that they get a mouse with a third mouse button (mouse wheel). Mouse wheel is the best, because then you zoom and orbit with the wheel.
            @bob james said:
            Deselect what?
            Deselect any selected vertices.
            When in select mode, click anywhere in the viewport where there isn't a vertex. This will clear the selection - like the native selection tool.
            When you pressed M - the native Move tool was activated? Then it sounds like you did not assign the M key to Vertex Tools > Move.
            http://www.thomthom.net/software/vertex_tools/manual/shortcuts
            http://www.thomthom.net/software/vertex_tools/images/PreferencesShortcuts.png
            Did you do this?
            A Gizmo toggle button sounds like a good toolbar button to have. Agree.
            (Meanwhile you can assign a shortcut to the Gizmo toggle.)
            The "little circle" isn't a separate tool. It's just like the native Move tool where you can pick individual vertices if you have nothing selected. The circle is just for an extra visual clue as I felt it was easier to pick vertices. I'd rather not add a separate button that compounds "Select None + Active Move Tool" as I fear it might be confusing people to think it's a separate tool - and it'd add even more visual elements to the screen.
            My own workflow - in Vertex Tools and in native SketchUp is to use keyboard shortcuts to deselect. I use selection functions so often that they are the first shortcuts I set up.
            • PixeroP
              Pixero
              That "Catmull-Clark" menu item sounds intriguing.
              Care to tell us?
                Care to tell us?
                Nothing gets past you guys... πŸ˜’
                I must be careful in my screenshots.
                But in this case I have demonstrated the experiment:
                From this point and onward in this thread:
                http://sketchucation.com/forums/viewtopic.php?f=333&t=47691&start=15#p427396
                • PixeroP
                  Pixero
                  I've totally missed that video presentation. Great work.
                  Now, is there anything we can do to persuade you to finish this and your nurbs plugin sometime soon?
                    I am working on Bezier Surface now that Vertex Tools 1.1 is out. It'll get the main attention until I get something working there. Then I'll see what I do next.
                    • PixeroP
                      Pixero
                      Yes, sorry Bezier Surface was what I meant.
                        smicha
                        I love 1.1.4. Works great! Fantastic plugin.
                        Could you reveal what is "architect tools" for? And when will it be released?
                          It's the updated version of Plan Tools. I've promised to release it very soon - a while ago. 😳
                          • cottyC
                            cotty
                            I'm playing around and want to select only some vertices from the front. I know the options "ignore backfaces" and "select only visible", but I'm not able to achive the desired selection...?
                            vertex_visible.skp
                            my SketchUp gallery
                            • pbacotP
                              I've run across the same thing and wasn't sure what to think about it.
                              • cottyC
                                cotty
                                I've played a little more and noticed, that it depends on the soft radius: 30cm only selects front vertices, with 40cm the back vertices are selected too...
                                my SketchUp gallery
                                • cottyC
                                  cotty
                                  Here are some variations...
                                  my SketchUp gallery
                                    Ah, yes. Soft-selection is affected by proximity of the selected vertices - not connected distance. I have it on my list to implement a soft-selection that acts upon connected distance that would have solved your problems in this particular case. Unfortunately that doesn't help you now. 😞
                                    • panixiaP
                                      panixia
                                      nice! i was here to do the same exact request because i just modeled an hanging cloth and found that having an option of "only connected" for soft selection would be really cool.. i know 3dstudio max has a sort of cloth simulator, but i find 3dsmax is.. how can i say.. a "bit more expensive" than your tool.. πŸ˜„
                                      oh.. and "merge to point" rules!!! go for it!
                                      • opalO
                                        opal
                                        would putting part of the model on a different layer and hiding it help to get only one surface's verts?
                                        • cottyC
                                          cotty
                                          No (urgent) problem because I'm only playing around πŸ˜‰
                                          Should a "Select only visible" does help anyway to reduce the selection?
                                          Yes, a selection with no soft selection (r=0) and grouping these vertices for soft selection is a workaround...
                                          my SketchUp gallery
                                            I was about to say no - but then gave it a second thought and tried it. And yes, it works. Hiding the geometry you don't want affected will prevent them from being affected by soft-selection. πŸ˜„
                                            I think I might have to add that to the FAQ. Nice trick.
                                            No - it would only effect selected vertices - not the soft-selection.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 33
                                            • 34
                                            • 14 / 34
