    [Plugin] [$] Artisan (1.2.3) - Feb 28, 2014
    296 Posts 95 Posters 172.5k Views 95 Watching
    • guanjinG
      guanjin
      @guanjin said:
      Why do I install the free 15-day version of the display icon gray, can not be used.
      If I buy genuine worry about will not be displayed? ?
      Normal installation, but can not find the tool。
      I did something wrong
        Have you activated it in Preferences > Extensions ?
        Have you then activated its Toolbar ??
        • guanjinG
          guanjin
          The toolbar nor any option
            Have you 'activated' its Extension ??
            You have not said anything about this...
            • guanjinG
              guanjin
              Expansion which has also activated the 😳
                Does that mean you got it to work?
                Your phrasing does not explain things at all...
                • pbacotP
                  A couple questions--maybe others have these issues (features?).
                  1. When I select with the sculpt select tool, the selection partially disappears (some faces become unselected) during the first sculpt operation. The full selection might be functional during the first operation, but upon completion of the operation only the remaining selection is active. Why doesn't my full selection stay until I change it? I'd like to keep working on the selected faces. [This seems to be faces along the edge of the selection, which become deselected. I find that if I then add them back in, they stay selected better?]
                  2. The sculpt circle and arrow disappears during the operation (often not always).
                  3. Here's an example of something I want to do. I would like to select an area on one side of a hard edge and bring that edge up with the selection. This sort of works, stretching the faces on the opposite side. Is there a plugin or method that would leave those far side faces in place and infill the gap? Such a method could (for example) create a vertical face with breaks top and bottom as the geometry on the selected side is raised.
                  • sicksickisckS
                    sicksickisck
                    knife tool could draw faces at the intersection! 😎 [ of such an option ]
                    • mitcorbM
                      mitcorb
                      @pbacot:
                      Your second item I have also seen. It may have something to do with the tool's focus and sometimes cannot find the face normal?--especially in a busy area. Sometimes zooming in and adjusting the radius has helped me. I have occasionally used -BTM's Sculpt in conjunction with Artisan while in Sketchup v7. I don't know how that one will perform in v8.
                      On your first item, does this have anything to do with the Crease Tool?
                      • pbacotP
                        Thanks for the note, Tim. Never tried Sculpt. I see no pattern to my issues, but I think my new computer's speed is helping. Still they seem pretty common and troublesome--such as the loss of selections in the middle of operations.
                        I have a lot of thoughts for Artisan for shaping terrain, but meanwhile it is still a fantastic and cool tool. And that's just talking about the sculpt side. The SDS side is also mind-boggling.
                        • PixeroP
                          Pixero
                          My one wish for Artisan is that it kept UV coordinates when subdividing and sculpting.
                          Thomthoms Quads perhaps?
                          • W
                            Whaat
                            Sculpting...no
                            Subdividing...yes - is this not working for you?
                            • holmes1977H
                              holmes1977
                              Im working alot more from home so using my Laptop
                              -ASUS G74
                              -i7 CPU @2.00Ghz
                              -8 GB RAM
                              -Win7 64bit
                              SU8 Pro
                              Im having problems with using this pluggin. I draw a simple rectangle, select the rectangle, select Subdivide selection, which divides the rectangle. I again select subdivide selection and I get a bug splat. I have tried this 10 times with the same result every time. Ive uninstalled the Artisan and re installed it, but still with the same result. This problem does not happen on my work computer. Do I need to delete all pluggins and slowly reinstall to see if there is a conflict?
                              Exaggeration makes a dull story better.
                              • mitcorbM
                                mitcorb
                                Hi, holmes:
                                Can this be anything to do with the "physical" size of the rectangle? or scale? Just asking. I don't know if that is relevant.
                                • holmes1977H
                                  holmes1977
                                  @mitcorb said:
                                  Hi, holmes:
                                  The rectangle is randomly about 5m by as 10m. Its really got me beat
                                  • P
                                    pepa
                                    @holmes1977 said:
                                    -ASUS G74
                                    -i7 CPU @2.00Ghz
                                    -8 GB RAM
                                    -Win7 64bit
                                    SU8 Pro
                                    Hi I tried instal new vray 1.6 and started exactly same issue. If are you using new vray try turn it of in extension panel or uninstall it, works for me.. maybe some ruby conflict
                                    http://jsvizualizace.daportfolio.com/
                                    • holmes1977H
                                      holmes1977
                                      @pepa said:
                                      @holmes1977 said:
                                      -ASUS G74
                                      -i7 CPU @2.00Ghz
                                      -8 GB RAM
                                      -Win7 64bit
                                      SU8 Pro
                                      BINGO
                                      You are so right. I turn off Vray4SU 1.6 beta and it works fine. Thanks so much. Im gona post this in the beta forum.
                                        The vRay plugin is notorious for causing conflicts in other plugins.
                                        • cottyC
                                          cotty
                                          There seems to be a problem with this plugin and the new SU2014, any ideas how to solve it?
                                          my SketchUp gallery
                                            Carsten, it works fine for me. Make sure you've got the current version and didn't just move an old version over from an earlier SU version.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
