    Where does a LayOut Scrapbook save on a Mac?
    layout
    21 Posts 5 Posters 5.8k Views 5 Watching
    • Gordon GreenwoodG Offline
      Gordon Greenwood
      @dave r said:
      @gordon greenwood said:
      Mac HD/Library/application support/Google Sketchup8/ then there are only two folders, Sketchup and style builder.
      Did you even look at my screenshot? We've been telling you the folder you need is under the User not the Mac HD. That's what my screenshot shows, too. πŸ˜’
      yep screen shots are great ( i am afraid I do not know how to attach as this would sort things out) the screen shot is exactly the same tree I am following
      Users are on the HD according to this computer?
      sorry if it frustrating guys? I have tried putting screen shots on but to no avail?
        You can attach screenshots by clicking on Upload attachment.
        The path you indicated is not the same as the one wind-borne typed and what I show in the screen shot.
        • wind-borneW Offline
          wind-borne
          Can you see the difference between the 2 paths and where you need to be?
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
            Gordon Greenwood
            Yep,
            however in my Users Path Application support the only folder is Adobe, and this file has nothing in it?
              Save some Layout 'scrap' as a new Scrapbook.
              Give it a unique name - e.g. 'TIGsScrapbookTester'...
              Afterwards use the 'Finder; to locate this very file by name.
              This will confirm its path... πŸ˜• πŸ˜•
                wind-borne
                Finder is blind to the 'user' Library ❗ πŸ˜’ ,
                Forklift will find with 'show hidden files' activated πŸ˜„
                %(#BF80BF)[SU 8 pro
                  mwm5053
                  I don't know why Apple changed this in Lion maybe they thought people where to stupid to be messing with their computers. IN finder and the user folder open, go to the top tool bar where you see file, edit, view, go, hit the Go tab with mouse hold the mouse button down while hitting option key scroll down till you highlight Library folder. Impossible to do if you've been drinking
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                    Gordon Greenwood
                    Hi Tig
                    Thanks for your input on this, forklift found it? problem is.
                    it shows it where it should be, followed your advice and wind-bourn, saved a file followed track,
                    however when I go into USERS (outside of fork lift, the Library file is not there.
                    this is not the end of the world, I just like to know where things are.
                    Gordon
                    ps if i knew how to upload image I could send tree directory
                      If it's a 'hidden folder' then can't you change it's settings ?
                      I thought MACs were meant to be easy πŸ˜’
                      To upload images [or many other file types] use the 'Upload attachment' tab below the 'reply pane' [TIP: Don't use the simpler 'Quick Reply' option - use the main 'Post a reply' button to get this... or you can also click on the 'Full editor' when within the simpler 'Quick' version to get these extra options]
                        Gordon Greenwood
                        Hi Tig
                        big mistake (read the book on Steve Jobs whilst on holiday? (cost me a fortune) as I Run AutocadLT13/Artlantis Render4, Still have windows laptop though, just in case.
                        I think I have attached the tree file to show you, as I say its no big deal,just like to know the workings, Forklift found it straight away.
                        Gordon
                        THIS THE TREE
                          mwm5053
                          They are easy just gotta know a few tweaks. Still unsure why Google setup LO to be in User and SU and SB to be in MAC HD since most of the team use MAC.
                          2011 iMac
                          V2 Twilight
                            Gordon Greenwood
                            Well worth the post, as I now know they drink a lot across the pond, and i now have Fork Lift
                            many thanks all.
                            Gordon
