    Where does a LayOut Scrapbook save on a Mac?
    layout
    21 Posts 5 Posters 6.4k Views 5 Watching
      I did a quick test and drew this thing which I then saved as a scrapbook called Scrapbook Test.
      It shows up in the User Library as shown below and as wind-borne outlined.
      • wind-borneW
        wind-borne
        @gordon greenwood said:
        All that works, right up until /Layout? its not showing this folder as being there,
        I can go into applications, and Layout is showing as being within the group, I then show package contents, where i can pick up the scrapbooks folder, but there not in there?
        weired
        Thanks for your reply.
        Is the problem an expectation that your Scrapbooks belong within the Application folder rather than the Application Support folder?
        The generic and yours exist side by side when using Layout
        "To read between the lines was easier than to follow the text."OSX 10.11.6
        %(#BF80BF)[SU 8 pro
        • Gordon GreenwoodG
          Gordon Greenwood
          [attachment=0:3glspftp]<!-- ia0 -->LO scrapbook2.png<!-- ia0 -->[/attachment:3glspftp]
          [attachment=1:3glspftp]<!-- ia1 -->LO Scrapbook.png<!-- ia1 -->[/attachment:3glspftp]
          Dave
          I can get into this folder, but it does not show layout there?
            Which folder? What version of Mac OS are you using?
            • Gordon GreenwoodG
              Gordon Greenwood
              Mac OS X Lion 10.7.5
              folders trail
              Mac HD/Library/application support/Google Sketchup8/ then there are only two folders, Sketchup and style builder.
              yet when I go Finder, applications, Google sketch up8 there are the three folders (Layout present) when I show package contents/
              contents/resources/English.lproj ( this is a file within this group)/Scrapbooks(this is a file within this group) it shows the standard layout scrapbooks, mine are not there
                Did you even look at my screenshot? We've been telling you the folder you need is under the User not the Mac HD. That's what my screenshot shows, too. ๐Ÿ˜’
                • Gordon GreenwoodG
                  Gordon Greenwood
                  yep screen shots are great ( i am afraid I do not know how to attach as this would sort things out) the screen shot is exactly the same tree I am following
                  Users are on the HD according to this computer?
                  sorry if it frustrating guys? I have tried putting screen shots on but to no avail?
                    You can attach screenshots by clicking on Upload attachment.
                    The path you indicated is not the same as the one wind-borne typed and what I show in the screen shot.
                    • wind-borneW
                      wind-borne
                      Can you see the difference between the 2 paths and where you need to be?
                      %(#BF80BF)[SU 8 pro
                      • Gordon GreenwoodG
                        Gordon Greenwood
                        Yep,
                        however in my Users Path Application support the only folder is Adobe, and this file has nothing in it?
                          Save some Layout 'scrap' as a new Scrapbook.
                          Give it a unique name - e.g. 'TIGsScrapbookTester'...
                          Afterwards use the 'Finder; to locate this very file by name.
                          This will confirm its path... ๐Ÿ˜• ๐Ÿ˜•
                          • wind-borneW
                            wind-borne
                            Finder is blind to the 'user' Library โ— ๐Ÿ˜’ ,
                            Forklift will find with 'show hidden files' activated ๐Ÿ˜„
                            %(#BF80BF)[SU 8 pro
                              mwm5053
                              I don't know why Apple changed this in Lion maybe they thought people where to stupid to be messing with their computers. IN finder and the user folder open, go to the top tool bar where you see file, edit, view, go, hit the Go tab with mouse hold the mouse button down while hitting option key scroll down till you highlight Library folder. Impossible to do if you've been drinking
                              2011 iMac
                              SU 2015 Pro, 2017 Make
                              V2 Twilight
                              macOS Sierra 10.12.5
                              • Gordon GreenwoodG
                                Gordon Greenwood
                                Hi Tig
                                Thanks for your input on this, forklift found it? problem is.
                                it shows it where it should be, followed your advice and wind-bourn, saved a file followed track,
                                however when I go into USERS (outside of fork lift, the Library file is not there.
                                this is not the end of the world, I just like to know where things are.
                                Gordon
                                ps if i knew how to upload image I could send tree directory
                                  If it's a 'hidden folder' then can't you change it's settings ?
                                  I thought MACs were meant to be easy ๐Ÿ˜’
                                  To upload images [or many other file types] use the 'Upload attachment' tab below the 'reply pane' [TIP: Don't use the simpler 'Quick Reply' option - use the main 'Post a reply' button to get this... or you can also click on the 'Full editor' when within the simpler 'Quick' version to get these extra options]
                                  • Gordon GreenwoodG
                                    Gordon Greenwood
                                    Hi Tig
                                    big mistake (read the book on Steve Jobs whilst on holiday? (cost me a fortune) as I Run AutocadLT13/Artlantis Render4, Still have windows laptop though, just in case.
                                    I think I have attached the tree file to show you, as I say its no big deal,just like to know the workings, Forklift found it straight away.
                                    Gordon
                                    THIS THE TREE
                                      mwm5053
                                      They are easy just gotta know a few tweaks. Still unsure why Google setup LO to be in User and SU and SB to be in MAC HD since most of the team use MAC.
                                      2011 iMac
                                      V2 Twilight
                                      • Gordon GreenwoodG
                                        Gordon Greenwood
                                        Well worth the post, as I now know they drink a lot across the pond, and i now have Fork Lift
                                        many thanks all.
                                        Gordon
