    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 544.9k Views 108 Watching
      SUFractal
      @tak2hata said:
      @sufractal said:
      I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
      Hi,Sufractal.
      In my enviroment,"Steel Column" shown from "North American pflist" no problem.
      Check the line include "##" in the csv file, If you edited it.
      "##STEEL_COLUMN" is needed.
      so, send to me your profile list or upload here it.
      and I will look it.
      Thanks.
      i believe I used the correct text in the file?
      • T
        tak2hata
        @sufractal said:
        @tak2hata said:
        Hi,Sufractal.
        and I will look it.
        Thanks.
        I tested it working fine.
        Steel Column shown fine.
        I judge that it is fine by looking only that picture.
        The last advice I say is "Change Profile list path" and select it again.
        The information about this problem is too small.
        Is there anyone had same problem?
        and please reply here.
        Thanks.
        by TAK2HATA
        • H
          hygicell
          excellent tool, but not (yet) working for me:
          I cannot find an installation manual
          nor a user manual
          and where do I put the .csv files?
          please help
          Frank
          • MasterhandM
            Masterhand
            Excellent tool. I worked great.
            Does anyone know if there is a plugin that allows easily verify whether a modulation structure, or structure, if feasible or still standing?.
            To just have a quick overview or a quick sample of what model can work it without having to do the entire calculation of the structure (which will be done later).
            So, I mean, for example: look, without calculating it yet, I can show that it may be feasible or holds
            • T
              tak2hata
              nor a user manual
              please help
              Frank
              Hi, hygicell.
              Please puts ".csv"file to folder you like.but windows special folder is not recommended.
              The windows special folder is like "C:\program files" "C:\Windows".
              Mac user do not mind this.
              After puts it,You must "Change profile list path" from plugins menu.
              and select the file.
              Hi,Mastarhand.
              Me,too.
              Hi,all.
              I will update this script after few days.
              Thanks.
              by TAK2HATA
              • T
                tak2hata
                I update to version 1.4beta.
                I add usefull function "Table Editor".
                and improves.
                enjoy. πŸ˜„
                by TAK2HATA
                • sumasterS
                  sumaster
                  Hello Tak2hata,
                  1st Thank you. Its too good and very useful . . . . πŸ‘ πŸ˜„ πŸ˜„
                  Nice one UPDATE Query Attributes and Table Editor
                  ****** CHK the Axies locking
                  when draw 1st time its work perfectly
                  but 2nd time not working
                  ****** CHK the Grow To Face tool
                  Select the object and use the Grow To Face tool . . .
                  and select the ground NOT WORKING . . . .
                  Here it is SKP File
                  123 .skp
                  Thank you,
                  SUmaster
                  • T
                    tulacong
                    thank you...thank you ....oh zeeee
                    • T
                      tak2hata
                      Hi,tulacong.
                      I am happy for your word!
                      Hi,SUMASTER.
                      I will improve it and update it after two weeks.
                      Thnx. πŸ˜‰
                      by TAK2HATA
                      • V
                        victor hugo
                        Hello.
                        My MWALL is not working, is on the list but it does not work, has any one had this problem too?
                        • T
                          tak2hata
                          Hello.
                          Hi ,HUGO.
                          I knew it and "SHAPES" class ,too.
                          I have small time ,so I will update in head of next week.
                          Please wait.
                          by TAK2HATA
                          • maxmarjamaaM
                            maxmarjamaa
                            Thanks you! β˜€
                            • T
                              tak2hata
                              I update to version1.5 in Oct 28,2012.
                              Bugfix and Improves.
                              1. inference axes.
                              2. extending with already selected single entity.
                              3. query attributes.
                              4. Work well about MWALLS and SHAPES.
                              Next update will take more than 2 weeks.
                              Thanks.
                              by TAK2HATA
                              • sumasterS
                                sumaster
                                HI tak2hata,
                                Please chk this . . . .
                                1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
                                http://sketchucation.com/forums/viewtopic.php?t=30508
                                and click APPLY ALL button . . . . .
                                This is the Final Result . . . .
                                another way is you can create the mark button . . .
                                Sketchup File :
                                Align SKP File.skp
                                THanks πŸ‘ πŸ‘
                                Thank you,
                                SUmaster
                                • T
                                  tak2hata
                                  Hi, Sumaster.
                                  @sumaster said:
                                  HI tak2hata,
                                  [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
                                  [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
                                  [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
                                  Sketchup File :
                                  [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
                                  THanks πŸ‘ πŸ‘
                                  Axis is very important for BST entity.
                                  So changing it as you like will not be control well by my tool.
                                  It is naturally phenomenon.
                                  Thanks.
                                  by TAK2HATA
                                  • sumasterS
                                    sumaster
                                    Oh. . . . ok . . .
                                    can you tell me . . . .
                                    when i change wall width / height its re-create base face & push-pull ?
                                    Thank you,
                                    SUmaster
                                    • sumasterS
                                      sumaster
                                      HI,
                                      CHK the Combine each tool not working . . . . .
                                      thanks
                                      Thank you,
                                      SUmaster
                                      • T
                                        tak2hata
                                        @sumaster said:
                                        HI,
                                        thanks
                                        I see it.
                                        I will correct it tonight(so means 12 hour later).
                                        This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
                                        I will add notice about never modifying inner Axis of the BST entities.
                                        In your case ,I think modifying the "align" to Center and bottom will almost well.
                                        I can not know where you modified the inner axis of BST entity.
                                        So there is no best answer.
                                        Please do not blame me.
                                        by TAK2HATA
                                        • T
                                          tak2hata
                                          Hi, I update to version1.5a in Nov 13,2012.
                                          Bugfix:Combine tool.
                                          Thanks...ZZZzzz...
                                          by TAK2HATA
                                          • sumasterS
                                            sumaster
                                            @tak2hata said:
                                            @sumaster said:
                                            HI,
                                            thanks
                                            I see it.
                                            Thanks . . . . πŸ‘
                                            OK . . . .
                                            yes i CHK this "align" to bottom of center radio button πŸ‘
                                            No no no . . . .
                                            Thank you,
                                            SUmaster
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
