    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      @sufractal said:
      I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
      Hi,Sufractal.
      In my enviroment,"Steel Column" shown from "North American pflist" no problem.
      Check the line include "##" in the csv file, If you edited it.
      "##STEEL_COLUMN" is needed.
      so, send to me your profile list or upload here it.
      and I will look it.
      Thanks.
      by TAK2HATA
      • sumasterS
        sumaster
        HI ,
        How i fix the color of BST wall . . . ?
        now its get random color . . .
        Thank you,
        SUmaster
          SUFractal
          @tak2hata said:
          Hi,Sufractal.
          and I will look it.
          Thanks.
          i believe I used the correct text in the file?
          • T
            tak2hata
            @sufractal said:
            @tak2hata said:
            Hi,Sufractal.
            and I will look it.
            Thanks.
            I tested it working fine.
            Steel Column shown fine.
            I judge that it is fine by looking only that picture.
            The last advice I say is "Change Profile list path" and select it again.
            The information about this problem is too small.
            Is there anyone had same problem?
            and please reply here.
            Thanks.
            by TAK2HATA
            • H
              hygicell
              excellent tool, but not (yet) working for me:
              I cannot find an installation manual
              nor a user manual
              and where do I put the .csv files?
              please help
              Frank
              • MasterhandM
                Masterhand
                Excellent tool. I worked great.
                Does anyone know if there is a plugin that allows easily verify whether a modulation structure, or structure, if feasible or still standing?.
                To just have a quick overview or a quick sample of what model can work it without having to do the entire calculation of the structure (which will be done later).
                So, I mean, for example: look, without calculating it yet, I can show that it may be feasible or holds
                • T
                  tak2hata
                  nor a user manual
                  please help
                  Frank
                  Hi, hygicell.
                  Please puts ".csv"file to folder you like.but windows special folder is not recommended.
                  The windows special folder is like "C:\program files" "C:\Windows".
                  Mac user do not mind this.
                  After puts it,You must "Change profile list path" from plugins menu.
                  and select the file.
                  Hi,Mastarhand.
                  Me,too.
                  Hi,all.
                  I will update this script after few days.
                  Thanks.
                  by TAK2HATA
                  • T
                    tak2hata
                    I update to version 1.4beta.
                    I add usefull function "Table Editor".
                    and improves.
                    enjoy. πŸ˜„
                    by TAK2HATA
                    • sumasterS
                      sumaster
                      Hello Tak2hata,
                      1st Thank you. Its too good and very useful . . . . πŸ‘ πŸ˜„ πŸ˜„
                      Nice one UPDATE Query Attributes and Table Editor
                      ****** CHK the Axies locking
                      when draw 1st time its work perfectly
                      but 2nd time not working
                      ****** CHK the Grow To Face tool
                      Select the object and use the Grow To Face tool . . .
                      and select the ground NOT WORKING . . . .
                      Here it is SKP File
                      123 .skp
                      Thank you,
                      SUmaster
                      • T
                        tulacong
                        thank you...thank you ....oh zeeee
                        • T
                          tak2hata
                          Hi,tulacong.
                          I am happy for your word!
                          Hi,SUMASTER.
                          I will improve it and update it after two weeks.
                          Thnx. πŸ˜‰
                          by TAK2HATA
                          • V
                            victor hugo
                            Hello.
                            My MWALL is not working, is on the list but it does not work, has any one had this problem too?
                            • T
                              tak2hata
                              Hello.
                              Hi ,HUGO.
                              I knew it and "SHAPES" class ,too.
                              I have small time ,so I will update in head of next week.
                              Please wait.
                              by TAK2HATA
                              • maxmarjamaaM
                                maxmarjamaa
                                Thanks you! β˜€
                                • T
                                  tak2hata
                                  I update to version1.5 in Oct 28,2012.
                                  Bugfix and Improves.
                                  1. inference axes.
                                  2. extending with already selected single entity.
                                  3. query attributes.
                                  4. Work well about MWALLS and SHAPES.
                                  Next update will take more than 2 weeks.
                                  Thanks.
                                  by TAK2HATA
                                  • sumasterS
                                    sumaster
                                    HI tak2hata,
                                    Please chk this . . . .
                                    1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
                                    http://sketchucation.com/forums/viewtopic.php?t=30508
                                    and click APPLY ALL button . . . . .
                                    This is the Final Result . . . .
                                    another way is you can create the mark button . . .
                                    Sketchup File :
                                    Align SKP File.skp
                                    THanks πŸ‘ πŸ‘
                                    Thank you,
                                    SUmaster
                                    • T
                                      tak2hata
                                      Hi, Sumaster.
                                      @sumaster said:
                                      HI tak2hata,
                                      [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
                                      [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
                                      [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
                                      Sketchup File :
                                      [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
                                      THanks πŸ‘ πŸ‘
                                      Axis is very important for BST entity.
                                      So changing it as you like will not be control well by my tool.
                                      It is naturally phenomenon.
                                      Thanks.
                                      by TAK2HATA
                                      • sumasterS
                                        sumaster
                                        Oh. . . . ok . . .
                                        can you tell me . . . .
                                        when i change wall width / height its re-create base face & push-pull ?
                                        Thank you,
                                        SUmaster
                                        • sumasterS
                                          sumaster
                                          HI,
                                          CHK the Combine each tool not working . . . . .
                                          thanks
                                          Thank you,
                                          SUmaster
                                          • T
                                            tak2hata
                                            @sumaster said:
                                            HI,
                                            thanks
                                            I see it.
                                            I will correct it tonight(so means 12 hour later).
                                            This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
                                            I will add notice about never modifying inner Axis of the BST entities.
                                            In your case ,I think modifying the "align" to Center and bottom will almost well.
                                            I can not know where you modified the inner axis of BST entity.
                                            So there is no best answer.
                                            Please do not blame me.
                                            by TAK2HATA
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
