    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
      SUFractal
      I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
      • T
        tak2hata
        Hi,Sufractal.
        In my enviroment,"Steel Column" shown from "North American pflist" no problem.
        Check the line include "##" in the csv file, If you edited it.
        "##STEEL_COLUMN" is needed.
        so, send to me your profile list or upload here it.
        and I will look it.
        Thanks.
        by TAK2HATA
        • sumasterS
          sumaster
          HI ,
          How i fix the color of BST wall . . . ?
          now its get random color . . .
          Thank you,
          SUmaster
            SUFractal
            @tak2hata said:
            Hi,Sufractal.
            and I will look it.
            Thanks.
            i believe I used the correct text in the file?
            • T
              tak2hata
              @sufractal said:
              @tak2hata said:
              Hi,Sufractal.
              and I will look it.
              Thanks.
              I tested it working fine.
              Steel Column shown fine.
              I judge that it is fine by looking only that picture.
              The last advice I say is "Change Profile list path" and select it again.
              The information about this problem is too small.
              Is there anyone had same problem?
              and please reply here.
              Thanks.
              by TAK2HATA
              • H
                hygicell
                excellent tool, but not (yet) working for me:
                I cannot find an installation manual
                nor a user manual
                and where do I put the .csv files?
                please help
                Frank
                • MasterhandM
                  Masterhand
                  Excellent tool. I worked great.
                  Does anyone know if there is a plugin that allows easily verify whether a modulation structure, or structure, if feasible or still standing?.
                  To just have a quick overview or a quick sample of what model can work it without having to do the entire calculation of the structure (which will be done later).
                  So, I mean, for example: look, without calculating it yet, I can show that it may be feasible or holds
                  • T
                    tak2hata
                    nor a user manual
                    please help
                    Frank
                    Hi, hygicell.
                    Please puts ".csv"file to folder you like.but windows special folder is not recommended.
                    The windows special folder is like "C:\program files" "C:\Windows".
                    Mac user do not mind this.
                    After puts it,You must "Change profile list path" from plugins menu.
                    and select the file.
                    Hi,Mastarhand.
                    Me,too.
                    Hi,all.
                    I will update this script after few days.
                    Thanks.
                    by TAK2HATA
                    • T
                      tak2hata
                      I update to version 1.4beta.
                      I add usefull function "Table Editor".
                      and improves.
                      enjoy. πŸ˜„
                      by TAK2HATA
                      • sumasterS
                        sumaster
                        Hello Tak2hata,
                        1st Thank you. Its too good and very useful . . . . πŸ‘ πŸ˜„ πŸ˜„
                        Nice one UPDATE Query Attributes and Table Editor
                        ****** CHK the Axies locking
                        when draw 1st time its work perfectly
                        but 2nd time not working
                        ****** CHK the Grow To Face tool
                        Select the object and use the Grow To Face tool . . .
                        and select the ground NOT WORKING . . . .
                        Here it is SKP File
                        123 .skp
                        Thank you,
                        SUmaster
                        • T
                          tulacong
                          thank you...thank you ....oh zeeee
                          • T
                            tak2hata
                            Hi,tulacong.
                            I am happy for your word!
                            Hi,SUMASTER.
                            I will improve it and update it after two weeks.
                            Thnx. πŸ˜‰
                            by TAK2HATA
                            • V
                              victor hugo
                              Hello.
                              My MWALL is not working, is on the list but it does not work, has any one had this problem too?
                              • T
                                tak2hata
                                Hello.
                                Hi ,HUGO.
                                I knew it and "SHAPES" class ,too.
                                I have small time ,so I will update in head of next week.
                                Please wait.
                                by TAK2HATA
                                • maxmarjamaaM
                                  maxmarjamaa
                                  Thanks you! β˜€
                                  • T
                                    tak2hata
                                    I update to version1.5 in Oct 28,2012.
                                    Bugfix and Improves.
                                    1. inference axes.
                                    2. extending with already selected single entity.
                                    3. query attributes.
                                    4. Work well about MWALLS and SHAPES.
                                    Next update will take more than 2 weeks.
                                    Thanks.
                                    by TAK2HATA
                                    • sumasterS
                                      sumaster
                                      HI tak2hata,
                                      Please chk this . . . .
                                      1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
                                      http://sketchucation.com/forums/viewtopic.php?t=30508
                                      and click APPLY ALL button . . . . .
                                      This is the Final Result . . . .
                                      another way is you can create the mark button . . .
                                      Sketchup File :
                                      Align SKP File.skp
                                      THanks πŸ‘ πŸ‘
                                      Thank you,
                                      SUmaster
                                      • T
                                        tak2hata
                                        Hi, Sumaster.
                                        @sumaster said:
                                        HI tak2hata,
                                        [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
                                        [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
                                        [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
                                        Sketchup File :
                                        [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
                                        THanks πŸ‘ πŸ‘
                                        Axis is very important for BST entity.
                                        So changing it as you like will not be control well by my tool.
                                        It is naturally phenomenon.
                                        Thanks.
                                        by TAK2HATA
                                        • sumasterS
                                          sumaster
                                          Oh. . . . ok . . .
                                          can you tell me . . . .
                                          when i change wall width / height its re-create base face & push-pull ?
                                          Thank you,
                                          SUmaster
                                          • sumasterS
                                            sumaster
                                            HI,
                                            CHK the Combine each tool not working . . . . .
                                            thanks
                                            Thank you,
                                            SUmaster
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
