    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tak2hata
      Hello.
      My MWALL is not working, is on the list but it does not work, has any one had this problem too?
      Hi ,HUGO.
      I knew it and "SHAPES" class ,too.
      I have small time ,so I will update in head of next week.
      Please wait.
      by TAK2HATA
      • maxmarjamaaM
        maxmarjamaa
        Thanks you! β˜€
        • T
          tak2hata
          I update to version1.5 in Oct 28,2012.
          Bugfix and Improves.
          1. inference axes.
          2. extending with already selected single entity.
          3. query attributes.
          4. Work well about MWALLS and SHAPES.
          Next update will take more than 2 weeks.
          Thanks.
          by TAK2HATA
          • sumasterS
            sumaster
            HI tak2hata,
            Please chk this . . . .
            1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
            http://sketchucation.com/forums/viewtopic.php?t=30508
            and click APPLY ALL button . . . . .
            This is the Final Result . . . .
            another way is you can create the mark button . . .
            Sketchup File :
            Align SKP File.skp
            THanks πŸ‘ πŸ‘
            Thank you,
            SUmaster
            • T
              tak2hata
              Hi, Sumaster.
              @sumaster said:
              HI tak2hata,
              [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
              [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
              [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
              Sketchup File :
              [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
              THanks πŸ‘ πŸ‘
              Axis is very important for BST entity.
              So changing it as you like will not be control well by my tool.
              It is naturally phenomenon.
              Thanks.
              by TAK2HATA
              • sumasterS
                sumaster
                Oh. . . . ok . . .
                can you tell me . . . .
                when i change wall width / height its re-create base face & push-pull ?
                Thank you,
                SUmaster
                • sumasterS
                  sumaster
                  HI,
                  CHK the Combine each tool not working . . . . .
                  thanks
                  Thank you,
                  SUmaster
                  • T
                    tak2hata
                    @sumaster said:
                    HI,
                    thanks
                    I see it.
                    I will correct it tonight(so means 12 hour later).
                    This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
                    I will add notice about never modifying inner Axis of the BST entities.
                    In your case ,I think modifying the "align" to Center and bottom will almost well.
                    I can not know where you modified the inner axis of BST entity.
                    So there is no best answer.
                    Please do not blame me.
                    by TAK2HATA
                    • T
                      tak2hata
                      Hi, I update to version1.5a in Nov 13,2012.
                      Bugfix:Combine tool.
                      Thanks...ZZZzzz...
                      by TAK2HATA
                      • sumasterS
                        sumaster
                        @tak2hata said:
                        @sumaster said:
                        HI,
                        thanks
                        I see it.
                        Thanks . . . . πŸ‘
                        OK . . . .
                        yes i CHK this "align" to bottom of center radio button πŸ‘
                        No no no . . . .
                        Thank you,
                        SUmaster
                        • V
                          victor hugo
                          I updated the files to version 1.5 and when I check the version under the plugins menu it shows Version=1.4(Oct 14,2012. How do I know if it was updated?
                          Thanks.
                          • T
                            tak2hata
                            Thanks.
                            Hi,Victor.
                            It is my mistake.
                            I will correct it strongly in next update. πŸ‘
                            Thanks.
                            by TAK2HATA
                            • sumasterS
                              sumaster
                              HI,
                              Please CHK the draw by clicks tool
                              its not work in group . . . .
                              (when draw on plan)
                              BST - 2.skp
                              Thank you,
                              SUmaster
                              • T
                                tak2hata
                                Hi,All.
                                I update BTS version 1.5c in Dec.04,2012.
                                Add Showing "About this" and "About History".
                                Bug fix when Creating Walls in Group.
                                Thanks.
                                by TAK2HATA
                                • sumasterS
                                  sumaster
                                  now BST Tool working GOOD
                                  Thanks Tak2hata . . . . . πŸ˜„ πŸ˜‰
                                  Thank you,
                                  SUmaster
                                  • F
                                    faluchdeviaro
                                    Hy tak2hata I translate the lang.txt file but the plugin remains without translate.
                                    How can I translate it?
                                    • T
                                      tak2hata
                                      Happy New Year 😍
                                      I update this script to v1.6 in Jan 01,2013.
                                      Improve the parts of translater.
                                      So Translate will work fine ,perhaps.
                                      And I add new words to language file.
                                      I create the support script for tranlate file.
                                      This script aims at the creating the corrected language file from older,if you have already created the language file.
                                      Thanks.
                                      by TAK2HATA
                                      • T
                                        tak2hata
                                        @hcltw1963 said:
                                        I have found that your BST script is very helpful and potential. It's the beginning of the BIM in SKP. I think it might be useful for wood structure either, so I omit 'RC' keyword in the script. Here's the language translation of the traditional Chinese.
                                        [attachment=0:3nwkabke]<!-- ia0 -->lang_zh_16.txt<!-- ia0 -->[/attachment:3nwkabke]
                                        Hi,hcltw1963.
                                        I'm glad to your translation! πŸ˜„
                                        I add the link to here from the top of thread.
                                        by TAK2HATA
                                        • OxerO
                                          Oxer
                                          Hi and thanks for the plugin!!
                                          Spanish translation file.
                                          lang_es.txt
                                          There are some phrases that I can't translate for example these:
                                          I have added some lines to the end of the lang_es.txt file with the phrases without translation.
                                          • T
                                            tak2hata
                                            Hi,All.
                                            I update to v1.6a in Jan 05,2013.
                                            Add translation words to lang file.
                                            Add the menu about Athors of Translations.
                                            I add link to translations in top of thread.
                                            Thanks chon!
                                            Thanks oxer!
                                            I am very happy. πŸ˜„
                                            by TAK2HATA
