    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • T
      tulacong
      thank you...thank you ....oh zeeee
      • T
        tak2hata
        Hi,tulacong.
        I am happy for your word!
        Hi,SUMASTER.
        I will improve it and update it after two weeks.
        Thnx. πŸ˜‰
        by TAK2HATA
        • V
          victor hugo
          Hello.
          My MWALL is not working, is on the list but it does not work, has any one had this problem too?
          • T
            tak2hata
            Hello.
            Hi ,HUGO.
            I knew it and "SHAPES" class ,too.
            I have small time ,so I will update in head of next week.
            Please wait.
            by TAK2HATA
            • maxmarjamaaM
              maxmarjamaa
              Thanks you! β˜€
              • T
                tak2hata
                I update to version1.5 in Oct 28,2012.
                Bugfix and Improves.
                1. inference axes.
                2. extending with already selected single entity.
                3. query attributes.
                4. Work well about MWALLS and SHAPES.
                Next update will take more than 2 weeks.
                Thanks.
                by TAK2HATA
                • sumasterS
                  sumaster
                  HI tak2hata,
                  Please chk this . . . .
                  1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
                  http://sketchucation.com/forums/viewtopic.php?t=30508
                  and click APPLY ALL button . . . . .
                  This is the Final Result . . . .
                  another way is you can create the mark button . . .
                  Sketchup File :
                  Align SKP File.skp
                  THanks πŸ‘ πŸ‘
                  Thank you,
                  SUmaster
                  • T
                    tak2hata
                    Hi, Sumaster.
                    @sumaster said:
                    HI tak2hata,
                    [attachment=3:22ix9rqt]<!-- ia3 -->Align - 1.png<!-- ia3 -->[/attachment:22ix9rqt]
                    [attachment=2:22ix9rqt]<!-- ia2 -->Align - 2.png<!-- ia2 -->[/attachment:22ix9rqt]
                    [attachment=1:22ix9rqt]<!-- ia1 -->Align - 3.png<!-- ia1 -->[/attachment:22ix9rqt]
                    Sketchup File :
                    [attachment=0:22ix9rqt]<!-- ia0 -->Align SKP File.skp<!-- ia0 -->[/attachment:22ix9rqt]
                    THanks πŸ‘ πŸ‘
                    Axis is very important for BST entity.
                    So changing it as you like will not be control well by my tool.
                    It is naturally phenomenon.
                    Thanks.
                    by TAK2HATA
                    • sumasterS
                      sumaster
                      Oh. . . . ok . . .
                      can you tell me . . . .
                      when i change wall width / height its re-create base face & push-pull ?
                      Thank you,
                      SUmaster
                      • sumasterS
                        sumaster
                        HI,
                        CHK the Combine each tool not working . . . . .
                        thanks
                        Thank you,
                        SUmaster
                        • T
                          tak2hata
                          @sumaster said:
                          HI,
                          thanks
                          I see it.
                          I will correct it tonight(so means 12 hour later).
                          This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
                          I will add notice about never modifying inner Axis of the BST entities.
                          In your case ,I think modifying the "align" to Center and bottom will almost well.
                          I can not know where you modified the inner axis of BST entity.
                          So there is no best answer.
                          Please do not blame me.
                          by TAK2HATA
                          • T
                            tak2hata
                            Hi, I update to version1.5a in Nov 13,2012.
                            Bugfix:Combine tool.
                            Thanks...ZZZzzz...
                            by TAK2HATA
                            • sumasterS
                              sumaster
                              @tak2hata said:
                              @sumaster said:
                              HI,
                              thanks
                              I see it.
                              Thanks . . . . πŸ‘
                              OK . . . .
                              yes i CHK this "align" to bottom of center radio button πŸ‘
                              No no no . . . .
                              Thank you,
                              SUmaster
                              • V
                                victor hugo
                                I updated the files to version 1.5 and when I check the version under the plugins menu it shows Version=1.4(Oct 14,2012. How do I know if it was updated?
                                Thanks.
                                • T
                                  tak2hata
                                  Thanks.
                                  Hi,Victor.
                                  It is my mistake.
                                  I will correct it strongly in next update. πŸ‘
                                  Thanks.
                                  by TAK2HATA
                                  • sumasterS
                                    sumaster
                                    HI,
                                    Please CHK the draw by clicks tool
                                    its not work in group . . . .
                                    (when draw on plan)
                                    BST - 2.skp
                                    Thank you,
                                    SUmaster
                                    • T
                                      tak2hata
                                      Hi,All.
                                      I update BTS version 1.5c in Dec.04,2012.
                                      Add Showing "About this" and "About History".
                                      Bug fix when Creating Walls in Group.
                                      Thanks.
                                      by TAK2HATA
                                      • sumasterS
                                        sumaster
                                        now BST Tool working GOOD
                                        Thanks Tak2hata . . . . . πŸ˜„ πŸ˜‰
                                        Thank you,
                                        SUmaster
                                        • F
                                          faluchdeviaro
                                          Hy tak2hata I translate the lang.txt file but the plugin remains without translate.
                                          How can I translate it?
                                          • T
                                            tak2hata
                                            Happy New Year 😍
                                            I update this script to v1.6 in Jan 01,2013.
                                            Improve the parts of translater.
                                            So Translate will work fine ,perhaps.
                                            And I add new words to language file.
                                            I create the support script for tranlate file.
                                            This script aims at the creating the corrected language file from older,if you have already created the language file.
                                            Thanks.
                                            by TAK2HATA
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
