    [Plugin] Axes Tools
    63 Posts 20 Posters 94.4k Views 20 Watching
      ...and when I try it again - everything works fine... πŸ˜•
      got a sample model? because I cannot reproduce it again..
      • sdmitchS
        sdmitch
        The attached model contains two not so "simple cubes". The one at the origin is the original cube. The one on the right is a copy which has been made unique and rotated 90 degrees. When the copy is selected, Change Axes show the insertion point of the copy at the back right corner as you would expect. Using your Axis Tool and choosing right,front,bottom does move the insertion point but the axes orientation is un-changed so, when it selected for placement, it appears un-rotated.
        Insertion point and axes orientation
        http://sdmitch.blogspot.com/
        • utilerU
          utiler
          Thom, I've got an idea to add.
          see here:
          http://forums.sketchucation.com/viewtopic.php?f=15&t=43404&p=387027#p387027
          Would be nice to be able to context click on a group or component and reset the Axes orientation to global.....
          I'd be interested to see if it is possible.
          Cheers,
          Andrew
          Just Curious...
            What would expected behavior for nested components be?
            • utilerU
              utiler
              Rest all I reckon..... πŸ‘
              Just Curious...
              • utilerU
                utiler
                'Re-set' all I meant to say.... 😳
                Just Curious...
                • bac9-flclB
                  bac9-flcl
                  This plugin is absolutely awesome, thanks a lot! πŸ˜„
                  I'm exporting models to CryENGINE3, which is limited with FP16 vertex coordinate precision, so moving the pivot point to the center of a bounding box to utilize the whole range of available values on each axis is a very important thing to do. Your plugin just saved me tons of time otherwise wasted on doing this manually. πŸ˜„
                  And yeah, the possibility to disable the centering for vertical axis (and using e.g bottom of the bounding box) is awesome too - especially for more or less flat models where I can sacrifice some excess precision in exchange for ease of object placement. Or also, it's very useful for small props, like furniture or natural clutter, which can be placed in hundreds - digging each object from the ground would have been quite bothersome). πŸ˜„
                    πŸ‘ πŸ˜„
                      rv1974
                      May I request 'add cpoint' feature at the axes origin?
                      • FabiazzF
                        Fabiazz
                        This what my doctor ordered, a full dose of axes tools. When making game model in sketchUp I always adjust the axes to fill the game need but i just can't get it centered on the object fast enough. This plugin sure cured that problem.
                        • H
                          haimat
                          Hi, I have created a simple box model in free Sketchup 8 and want to set the origin of the model's bounding box to exactly its center. I tried with this plugin but after running it on my model in Sketchup nothing happens.
                          Is this Axes Tool / Insertion Point Plugin not the correct solution for my needs, or have I missed something here?
                            Are you trying to set the axis of your model or a component?
                            This plugin only changes the axis of selected groups/components - not the model axis.
                            • H
                              haimat
                              Thanks, I managed to get the functionality that I was looking for with this plugin:
                              404 Not Found
                              (sketchucation.com)
                              Cheers!
                                ddflow
                                Thank you sooooo much! πŸ˜„
                                  You're sooooo welcome! πŸ˜„
                                    samyell77
                                    @thomthom said:
                                    @rv1974 said:
                                    It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
                                    Though, it could be made to also rotate the axis to match the current model axis.
                                    Hi Thomthom - is the above possible. Used your Axes plugin a lot (thanks) but wonder whether you are able to add this functionality in to it. Being able to align the axis to the model axis would be great. I started a thread here
                                    http://sketchucation.com/forums/viewtopic.php?f=15&t=54818
                                    but thinking about it this thread is probably a better place for it.
                                    Sam
                                    SU Pro 2016
                                    Dell Precision M4800
                                    PC Windows 10
                                    Intel Core i7-4900MQ @ 2.80ghz
                                    Nvidia Quadro K2100M
                                    16gb RAM
                                    • T
                                      theVonZipper
                                      Is there a tool or method that will allow a selection of components to acquire the axis of another component all at once?
                                      • E
                                        Einstein
                                        So simple, so good! Finally I can snap to compo's center when rotating πŸ˜„
                                        • gudio83G
                                          gudio83
                                          Hello ThomThom,
                                          can you update the plugin for SU2018 because does not work like on versions before.
                                          • 3 / 4
