    [Plugin] Axes Tools
    63 Posts 20 Posters 94.4k Views 20 Watching
    • utilerU
      utiler
      Rest all I reckon..... πŸ‘
      Just Curious...
      • utilerU
        utiler
        'Re-set' all I meant to say.... 😳
        Just Curious...
        • bac9-flclB
          bac9-flcl
          This plugin is absolutely awesome, thanks a lot! πŸ˜„
          I'm exporting models to CryENGINE3, which is limited with FP16 vertex coordinate precision, so moving the pivot point to the center of a bounding box to utilize the whole range of available values on each axis is a very important thing to do. Your plugin just saved me tons of time otherwise wasted on doing this manually. πŸ˜„
          And yeah, the possibility to disable the centering for vertical axis (and using e.g bottom of the bounding box) is awesome too - especially for more or less flat models where I can sacrifice some excess precision in exchange for ease of object placement. Or also, it's very useful for small props, like furniture or natural clutter, which can be placed in hundreds - digging each object from the ground would have been quite bothersome). πŸ˜„
            πŸ‘ πŸ˜„
              rv1974
              May I request 'add cpoint' feature at the axes origin?
              • FabiazzF
                Fabiazz
                This what my doctor ordered, a full dose of axes tools. When making game model in sketchUp I always adjust the axes to fill the game need but i just can't get it centered on the object fast enough. This plugin sure cured that problem.
                • H
                  haimat
                  Hi, I have created a simple box model in free Sketchup 8 and want to set the origin of the model's bounding box to exactly its center. I tried with this plugin but after running it on my model in Sketchup nothing happens.
                  Is this Axes Tool / Insertion Point Plugin not the correct solution for my needs, or have I missed something here?
                    Are you trying to set the axis of your model or a component?
                    This plugin only changes the axis of selected groups/components - not the model axis.
                    • H
                      haimat
                      Thanks, I managed to get the functionality that I was looking for with this plugin:
                      404 Not Found
                      (sketchucation.com)
                      Cheers!
                        ddflow
                        Thank you sooooo much! πŸ˜„
                          You're sooooo welcome! πŸ˜„
                            samyell77
                            @thomthom said:
                            @rv1974 said:
                            It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
                            Though, it could be made to also rotate the axis to match the current model axis.
                            Hi Thomthom - is the above possible. Used your Axes plugin a lot (thanks) but wonder whether you are able to add this functionality in to it. Being able to align the axis to the model axis would be great. I started a thread here
                            http://sketchucation.com/forums/viewtopic.php?f=15&t=54818
                            but thinking about it this thread is probably a better place for it.
                            Sam
                            SU Pro 2016
                            Dell Precision M4800
                            PC Windows 10
                            Intel Core i7-4900MQ @ 2.80ghz
                            Nvidia Quadro K2100M
                            16gb RAM
                            • T
                              theVonZipper
                              Is there a tool or method that will allow a selection of components to acquire the axis of another component all at once?
                              • E
                                Einstein
                                So simple, so good! Finally I can snap to compo's center when rotating πŸ˜„
                                • gudio83G
                                  gudio83
                                  Hello ThomThom,
                                  can you update the plugin for SU2018 because does not work like on versions before.
                                  • 3 / 4
