    [Plugin] Axes Tools
    63 Posts 20 Posters 90.5k Views 20 Watching
      rv1974
      May I request 'add cpoint' feature at the axes origin?
      • FabiazzF Offline
        Fabiazz
        This what my doctor ordered, a full dose of axes tools. When making game model in sketchUp I always adjust the axes to fill the game need but i just can't get it centered on the object fast enough. This plugin sure cured that problem.
        • H Offline
          haimat
          Hi, I have created a simple box model in free Sketchup 8 and want to set the origin of the model's bounding box to exactly its center. I tried with this plugin but after running it on my model in Sketchup nothing happens.
          Is this Axes Tool / Insertion Point Plugin not the correct solution for my needs, or have I missed something here?
            Are you trying to set the axis of your model or a component?
            This plugin only changes the axis of selected groups/components - not the model axis.
            • H Offline
              haimat
              Thanks, I managed to get the functionality that I was looking for with this plugin:
              http://sketchucation.com/forums/viewtopic.php?f=323&t=18691&p=473387#p152438
              Cheers!
                ddflow
                Thank you sooooo much! πŸ˜„
                  You're sooooo welcome! πŸ˜„
                    samyell77
                    @thomthom said:
                    @rv1974 said:
                    It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
                    Though, it could be made to also rotate the axis to match the current model axis.
                    Hi Thomthom - is the above possible. Used your Axes plugin a lot (thanks) but wonder whether you are able to add this functionality in to it. Being able to align the axis to the model axis would be great. I started a thread here
                    http://sketchucation.com/forums/viewtopic.php?f=15&t=54818
                    but thinking about it this thread is probably a better place for it.
                    Sam
                    SU Pro 2016
                    Dell Precision M4800
                    PC Windows 10
                    Intel Core i7-4900MQ @ 2.80ghz
                    Nvidia Quadro K2100M
                    16gb RAM
                      theVonZipper
                      Is there a tool or method that will allow a selection of components to acquire the axis of another component all at once?
                      • E Offline
                        Einstein
                        So simple, so good! Finally I can snap to compo's center when rotating πŸ˜„
                        • gudio83G Offline
                          gudio83
                          Hello ThomThom,
                          can you update the plugin for SU2018 because does not work like on versions before.
                          • 4 / 4
