    [Plugin] Axes Tools
    63 Posts 20 Posters 94.4k Views 20 Watching
      @dem said:
      Excuse me, how can I create a button with
      "cmd = UI::Command.new () {}", for this tool? 💚
      <span class="syntaxdefault"><br />cmd&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Command</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'Set&nbsp;Insertion&nbsp;Point'</span><span class="syntaxkeyword">)&nbsp;{<br />&nbsp;&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_insertion_point<br /></span><span class="syntaxkeyword">}<br />&nbsp;</span><span class="syntaxdefault"></span>
      • demD
        dem
        @thomthom said:
        <span class="syntaxdefault"><br />cmd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Command</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'Set Insertion Point'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_insertion_point<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"> </span>
        I just tried the same way, but did not work 😢
        <span class="syntaxdefault"><br />cmd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Command</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'Set Insertion Point'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">  self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set_insertion_point<br /></span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">cmd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">small_icon </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"ICONS/axisC_sm.png"<br /></span><span class="syntaxdefault">cmd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">large_icon </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"ICONS/axisC_lg.png"<br /></span><span class="syntaxdefault">cmd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tooltip </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Set Insertion Point"<br /></span><span class="syntaxdefault">toolbar </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> toolbar</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item cmd<br /></span>
        Excuse me, but what I do wrong?
          Does the toolbar appear?
          Do you get any error messages?
          Did you put the code inside the TT::Plugins::AxesTools module? If not, then you must use TT::Plugins::AxesTools.set_insertion_point
          • demD
            dem
            Oh. Thanks!!! Very useful plugin, that saves a lot of time!
            • sdmitchS
              sdmitch
              ThomThom, I have been trying to redefine, from a plugin, the axes of a component instance that has been rotated and made unique to the default left,front,bottom location without any luck. This is an easy manual modification but seemingly impossible from code. Any suggestions would be greatly appreciated.
              http://sdmitch.blogspot.com/
                This plugin won't do it??? 😕
                • sdmitchS
                  sdmitch
                  @thomthom said:
                  This plugin wonæt do it??? 😕
                  I can't seem to come up with any combination that makes it work. I want to be able to copy and rotate a component around one or two axes then make it unique so, when I place it again, it maintains that orientation. Now when the the new component is selected for placement it returns to the orientation that it originally was. Using your Axis Tool doesn't change that no matter where I define the insertion point. Right clicking on the component and doing a Change Axes is the only thing that works but how do you code that?
                    It's exactly what this plugin is suppose to be doing... ...but testing a simple cube now, and there seem to be a bug here...
                      ...and when I try it again - everything works fine... 😕
                      got a sample model? because I cannot reproduce it again..
                      • sdmitchS
                        sdmitch
                        The attached model contains two not so "simple cubes". The one at the origin is the original cube. The one on the right is a copy which has been made unique and rotated 90 degrees. When the copy is selected, Change Axes show the insertion point of the copy at the back right corner as you would expect. Using your Axis Tool and choosing right,front,bottom does move the insertion point but the axes orientation is un-changed so, when it selected for placement, it appears un-rotated.
                        Insertion point and axes orientation
                        • utilerU
                          utiler
                          Thom, I've got an idea to add.
                          see here:
                          http://forums.sketchucation.com/viewtopic.php?f=15&t=43404&p=387027#p387027
                          Would be nice to be able to context click on a group or component and reset the Axes orientation to global.....
                          I'd be interested to see if it is possible.
                          Cheers,
                          Andrew
                          Just Curious...
                            What would expected behavior for nested components be?
                            • utilerU
                              utiler
                              Rest all I reckon..... 👍
                              Just Curious...
                              • utilerU
                                utiler
                                'Re-set' all I meant to say.... 😳
                                Just Curious...
                                • bac9-flclB
                                  bac9-flcl
                                  This plugin is absolutely awesome, thanks a lot! 😄
                                  I'm exporting models to CryENGINE3, which is limited with FP16 vertex coordinate precision, so moving the pivot point to the center of a bounding box to utilize the whole range of available values on each axis is a very important thing to do. Your plugin just saved me tons of time otherwise wasted on doing this manually. 😄
                                  And yeah, the possibility to disable the centering for vertical axis (and using e.g bottom of the bounding box) is awesome too - especially for more or less flat models where I can sacrifice some excess precision in exchange for ease of object placement. Or also, it's very useful for small props, like furniture or natural clutter, which can be placed in hundreds - digging each object from the ground would have been quite bothersome). 😄
                                      rv1974
                                      May I request 'add cpoint' feature at the axes origin?
                                      • FabiazzF
                                        Fabiazz
                                        This what my doctor ordered, a full dose of axes tools. When making game model in sketchUp I always adjust the axes to fill the game need but i just can't get it centered on the object fast enough. This plugin sure cured that problem.
                                        • H
                                          haimat
                                          Hi, I have created a simple box model in free Sketchup 8 and want to set the origin of the model's bounding box to exactly its center. I tried with this plugin but after running it on my model in Sketchup nothing happens.
                                          Is this Axes Tool / Insertion Point Plugin not the correct solution for my needs, or have I missed something here?
                                            Are you trying to set the axis of your model or a component?
                                            This plugin only changes the axis of selected groups/components - not the model axis.
                                            • 3 / 4
