    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 59.5k Views 12 Watching
      glro
      OK
      yes it helps
      when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
      but i cannot save the parameters (clicking on "OK" doesnt change anything)
      i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
      thank you
        Aerilius
        @glro said:
        yes it helps
        That is good!
        Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
          glro
          when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
          The plugin does take a shot when i click on the button
          but i cannot get the snapshot settings windows on the screen anymore
          it may be because of my computer, if i am the only one to have this problem...
            Aerilius
            I am very sure it's not your computer. I couldn't find anything on my own.
            This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
              glro
              no, nothing in the ruby console
              it is an error message when sketchup loads all the plugins
              no numbers
              erreur chargement
                Aerilius
                Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                load "ae_Snapshot/Snapshot.rb"
                  glro
                  Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                  Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                    Aerilius
                    Thanks!!!
                    I found and fixed the issues!
                      glro
                      sorry to write that i still have an error message
                      string to integer error
                        Aerilius
                        I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                          glro
                          Here is the error message:
                          "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                          (eval):155:in `load'
                          (eval):155"
                          line 319
                            Aerilius
                            (I won't be back until tomorrow.)
                            I just made a quick change, can you test it?
                            Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                              glro
                              i replaced the previous file in the rbz, by this new one, and yes, now it works perfectly
                              a nice tool to keep tracks, and retrieve a lost model
                              thank you
                                driven
                                been playing around with style
                                no need to open, but do the icons download to other computers
                                don't stay stuck when on the file posting, but I want to test if they download
                                This is the Standard horrible mac one
                                it's icon doesn't upload either??
                                • simon le bonS Offline
                                  simon le bon
                                  This last release is impressively highly configurable - And then need to be tamed a bit
                                  The fact is that I'm not easy with the {nr} parameter and the "change digit by" line bellow. 😳
                                  I'm not able to make the incrementation work.
                                  Whatever I test, I obtain something like this: xyz_00**_1-0-0**.png ❓
                                  Need some further explanation 💭 😒
                                  simon
                                    Aerilius
                                    Whatever I test, I obtain something like this: xyz_00_1-0-0.png
                                    That depends on what you want to get (I don't know).
                                    It's the printf format (I didn't need to implement it, otherwise it would be more complicated). You can write any separating characters and %d is replaced by the number.
                                    It should work that for a major version 1, minor version 3, you get
                                    [pre:1z9sy1o8]%d → file_1.skp
                                    %d.%d (or %1d.%1d) → file_1.3.skp (number between %d sets minimum width)
                                    %d.%2d → file_1. 3.skp (minimum width is filled up by spaces)
                                    %d.%02d → file_1.03.skp (with additional 0, it is filled by 0)
                                    %d-%02d → file_1-03.skp
                                    %d_%02d → file_1_03.skp
                                    %02d.%02d → file_01.03.skp
                                    %02d.%03d → file_01.003.skp[/pre:1z9sy1o8]
                                      simon le bon
                                      Ok, thank you! I understand very better now.
                                      But Hum! incrementation still dont work for me. Is it something I'm doing wrong or is it something that don't work with the script ?
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_005.jpg
                                      By pressing my +1 button set as above
                                      a xyz.skp Snapshot should be saved as
                                      and due to "change the 2 digit by 1", I understand that the following +1 button depressed should increment the files by the second digit:
                                      xyz_01_03.png...
                                      But my file is saved as
                                      xyz_01_00.png and instead of increment it , overwrites on itself.
                                      Still need help I guess 😳
                                      Simon.
                                        Aerilius
                                        fixed!
                                          simon le bon
                                          @aerilius said:
                                          fixed!
                                          Hi Ae,
                                          it is not necessarily very comfortable to be tester 😉 😕
                                          It seems that increment still doesn't work...
                                          (that decrements from 1 to 0 and then overwrites)
                                          Cheers,
                                          Simon.
                                          PS:It should certainly be very useful to add the usages of {nr} parameter to the first post
                                            simon le bon
                                            ~~ content outdated --> erased ~~~
                                            • 2 / 4
