    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 61.0k Views 12 Watching
    • simon le bonS Offline
      simon le bon
      Sorry to disturb the coding discussion 😕
      Ae_Snapshot tested with Su7 : love this plug 👍 👍
      (Png transparent background option still don't work - - )
      simonlebon
        Aerilius
        I forgot to mention: the transparent png option has only been added to SketchUp 8.
        I'm working on a new version!
          glro
          @glro said:
          @aerilius said:
          @driven said:
          @glro said:
          is it possible to create a shortcut to a file using ruby?
          That might be a the easiest solution! I'll try it!
          i added some code to yours at the end of "self.save_as(filepath)" method
          > filepath2 = (filepath.split("/")[0..-2]).join("/")
          > nom_model = m.title
          > # name of the text file to put the shortcut in
          > nom_bat = filepath2 + "/" + nom_model + ".bat"
          > #open this file
          > aFile = File.new(nom_bat,"w")
          > pathmodel = m.path
          > #write the file shortcut
          > aFile.puts("call "+pathmodel)
          > aFile.puts("end")
          > aFile.close
          a black cmd window is opened... must be closed manually, unless you embed the .bat file in a .js file...
          it is basic but it works...
          Doesn't work if there is a white space in the file address
          additional code is needed
          nom_bat2 = nom_bat.to_s
          if nom_bat2.count(nom_bat2, " ") != 0
          UI.messagebox("no white space in the file address")
          fail
            Aerilius
            I updated the plugin. I think it will now fit all your needs because you can now make your own buttons 😉
            @glro, can you test if the shortcuts work as expected?
              glro
              i tested, but there might be a problem
              no box is opened on my scree when i check "ae snapshot" in the menu
              it might come from the html file
              in the pop up windows you show in the first message of this thread, i read "create a shortcut"
              but when i click on the html file in "ae_snapshot" folder, i don't see the same things
              html settings differences
                Aerilius
                I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
                You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
                Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
                  glro
                  yes, the setting dialog does not appear;
                  the gear icon does'nt appear either...
                  just a small reactangle where i cannot click ...
                  how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
                  my guess is that it is linked to the problem
                  snapshot icon
                  • srxS Offline
                    srx
                    Very useful! Thank you very much.
                    www.saurus.rs
                      Aerilius
                      @glro: Does " Sketchup.write_default("Plugins_ae", "Snapshot", "{}")" on the Ruby Console and restarting help?
                      (There are no relevant differences in the htm file.)
                      (By the way, you don't need quote the message, I know it's on the same page one above 😉 )
                        glro
                        OK
                        yes it helps
                        when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
                        but i cannot save the parameters (clicking on "OK" doesnt change anything)
                        i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
                        thank you
                          Aerilius
                          @glro said:
                          yes it helps
                          That is good!
                          Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
                            glro
                            when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
                            The plugin does take a shot when i click on the button
                            but i cannot get the snapshot settings windows on the screen anymore
                            it may be because of my computer, if i am the only one to have this problem...
                              Aerilius
                              I am very sure it's not your computer. I couldn't find anything on my own.
                              This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
                                glro
                                no, nothing in the ruby console
                                it is an error message when sketchup loads all the plugins
                                no numbers
                                erreur chargement
                                  Aerilius
                                  Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                                  load "ae_Snapshot/Snapshot.rb"
                                    glro
                                    Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                                    Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                                      Aerilius
                                      Thanks!!!
                                      I found and fixed the issues!
                                        glro
                                        sorry to write that i still have an error message
                                        string to integer error
                                          Aerilius
                                          I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                                            glro
                                            Here is the error message:
                                            "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                                            (eval):155:in `load'
                                            (eval):155"
                                            line 319
                                            • 2 / 4
