    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 57.7k Views 12 Watching
      Aerilius
      Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
      load "ae_Snapshot/Snapshot.rb"
        glro
        Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
        Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
          Aerilius
          Thanks!!!
          I found and fixed the issues!
            glro
            sorry to write that i still have an error message
            string to integer error
              Aerilius
              I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                glro
                Here is the error message:
                "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                (eval):155:in `load'
                (eval):155"
                line 319
                  Aerilius
                  (I won't be back until tomorrow.)
                  I just made a quick change, can you test it?
                  Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                    glro
                    i replaced the previous file in the rbz, by this new one, and yes, now it works perfectly
                    a nice tool to keep tracks, and retrieve a lost model
                    thank you
                      driven
                      been playing around with style
                      no need to open, but do the icons download to other computers
                      don't stay stuck when on the file posting, but I want to test if they download
                      This is the Standard horrible mac one
                      it's icon doesn't upload either??
                      • simon le bonS Offline
                        simon le bon
                        This last release is impressively highly configurable - And then need to be tamed a bit
                        The fact is that I'm not easy with the {nr} parameter and the "change digit by" line bellow. 😳
                        I'm not able to make the incrementation work.
                        Whatever I test, I obtain something like this: xyz_00**_1-0-0**.png ❓
                        Need some further explanation 💭 😒
                        simon
                          Aerilius
                          Whatever I test, I obtain something like this: xyz_00_1-0-0.png
                          That depends on what you want to get (I don't know).
                          It's the printf format (I didn't need to implement it, otherwise it would be more complicated). You can write any separating characters and %d is replaced by the number.
                          It should work that for a major version 1, minor version 3, you get
                          [pre:1z9sy1o8]%d → file_1.skp
                          %d.%d (or %1d.%1d) → file_1.3.skp (number between %d sets minimum width)
                          %d.%2d → file_1. 3.skp (minimum width is filled up by spaces)
                          %d.%02d → file_1.03.skp (with additional 0, it is filled by 0)
                          %d-%02d → file_1-03.skp
                          %d_%02d → file_1_03.skp
                          %02d.%02d → file_01.03.skp
                          %02d.%03d → file_01.003.skp[/pre:1z9sy1o8]
                            simon le bon
                            Ok, thank you! I understand very better now.
                            But Hum! incrementation still dont work for me. Is it something I'm doing wrong or is it something that don't work with the script ?
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_005.jpg
                            By pressing my +1 button set as above
                            a xyz.skp Snapshot should be saved as
                            and due to "change the 2 digit by 1", I understand that the following +1 button depressed should increment the files by the second digit:
                            xyz_01_03.png...
                            But my file is saved as
                            xyz_01_00.png and instead of increment it , overwrites on itself.
                            Still need help I guess 😳
                            Simon.
                              Aerilius
                              fixed!
                                simon le bon
                                @aerilius said:
                                fixed!
                                Hi Ae,
                                it is not necessarily very comfortable to be tester 😉 😕
                                It seems that increment still doesn't work...
                                (that decrements from 1 to 0 and then overwrites)
                                Cheers,
                                Simon.
                                PS:It should certainly be very useful to add the usages of {nr} parameter to the first post
                                  simon le bon
                                  ~~ content outdated --> erased ~~~
                                    glro
                                    one step further...
                                    would it be possible to:
                                    scan a folder
                                    open automatically all skp files in the folder
                                    produce the thumbnail and the file shortcut
                                    store them in the specified folder?
                                    Because the plugin is great to keep track of the future skp files, and it would be nice to collect the informations also for the already existing skp files...
                                      driven
                                      Hi Giro,
                                      I just popped in to post another idea and thought I'd use your query to clarify some thoughts, hope you don't mind.
                                      @glro said:
                                      one step further...
                                      scan a folder
                                      'SketchUp Menu' >> File >> Open >> Browse to Folder >> Select All .skp files >> Click 'Select'
                                      on a mac all will open in SketchUp, does it not on a PC?
                                      does it not do this, now? on the mac the 'shortcut's' not needed if you 'apply' the new icon image to the .skp file
                                      This is already a preference, but once they're on the .skp storing a copy [as a material, maybe?] in the model would be more useful [for transferring to another computer or sharing]
                                      You can already use this with old or new files, the problem with batch processing [fully auto] is getting bad views of some models that haven't been optimally positioned when last saved. You could code in a 'Perspective >> Zoom Extents' type event, but what if its a part of a huge scheme or a 2D floorPlan etc...
                                        driven
                                        a hidden editor pops down on hover
                                        allowing you to add all sorts of detail to the icon
                                        Everything is made inside a SU WebDialog [could just be an extra option in this plugin]
                                        I have a hard coded 'proof of principle' plugin that works on a mac and possibly a PC...
                                        You can add your own borders [made in SU]
                                        add logos
                                        add text
                                        can anyone else see any advantages to this concept or should I just finish it for myself and mac only.?
                                          glro
                                          @driven said:
                                          Hi Giro,
                                          @glro said:
                                          one step further...
                                          scan a folder
                                          on my computer this doesn't open all skp files automatically...
                                          i have to open each file manually one by one
                                          but you are right about the snapshot: to make sure it is taken with the model in the right position, it would be better to have a look on it
                                          maybe i can find the code to open automatically all files in a folder, one after the other, and set the zoom coefficient so that the model is visible completely
                                          the only thing to do manually would be to gather all the skp files in a folder and then launch the plugin
                                          i'll work on it soon
                                            glro
                                            this plugin could be a useful addition to ae snapshot, because, as i understand it, it would make possible to add information on the thumbnail
                                            when trying to retrieve a model, you would have the image, and also text, to make sure it is the model you are looking for
                                            • 2 / 4
