    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 61.0k Views 12 Watching
      glro
      when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
      The plugin does take a shot when i click on the button
      but i cannot get the snapshot settings windows on the screen anymore
      it may be because of my computer, if i am the only one to have this problem...
        Aerilius
        I am very sure it's not your computer. I couldn't find anything on my own.
        This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
          glro
          no, nothing in the ruby console
          it is an error message when sketchup loads all the plugins
          no numbers
          erreur chargement
            Aerilius
            Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
            load "ae_Snapshot/Snapshot.rb"
              glro
              Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
              Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                Aerilius
                Thanks!!!
                I found and fixed the issues!
                  glro
                  sorry to write that i still have an error message
                  string to integer error
                    Aerilius
                    I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                      glro
                      Here is the error message:
                      "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                      (eval):155:in `load'
                      (eval):155"
                      line 319
                        Aerilius
                        (I won't be back until tomorrow.)
                        I just made a quick change, can you test it?
                        Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                          glro
                          i replaced the previous file in the rbz, by this new one, and yes, now it works perfectly
                          a nice tool to keep tracks, and retrieve a lost model
                          thank you
                            driven
                            been playing around with style
                            no need to open, but do the icons download to other computers
                            don't stay stuck when on the file posting, but I want to test if they download
                            This is the Standard horrible mac one
                            it's icon doesn't upload either??
                            • simon le bonS Offline
                              simon le bon
                              This last release is impressively highly configurable - And then need to be tamed a bit
                              The fact is that I'm not easy with the {nr} parameter and the "change digit by" line bellow. 😳
                              I'm not able to make the incrementation work.
                              Whatever I test, I obtain something like this: xyz_00**_1-0-0**.png ❓
                              Need some further explanation 💭 😒
                              simon
                                Aerilius
                                Whatever I test, I obtain something like this: xyz_00_1-0-0.png
                                That depends on what you want to get (I don't know).
                                It's the printf format (I didn't need to implement it, otherwise it would be more complicated). You can write any separating characters and %d is replaced by the number.
                                It should work that for a major version 1, minor version 3, you get
                                [pre:1z9sy1o8]%d → file_1.skp
                                %d.%d (or %1d.%1d) → file_1.3.skp (number between %d sets minimum width)
                                %d.%2d → file_1. 3.skp (minimum width is filled up by spaces)
                                %d.%02d → file_1.03.skp (with additional 0, it is filled by 0)
                                %d-%02d → file_1-03.skp
                                %d_%02d → file_1_03.skp
                                %02d.%02d → file_01.03.skp
                                %02d.%03d → file_01.003.skp[/pre:1z9sy1o8]
                                  simon le bon
                                  Ok, thank you! I understand very better now.
                                  But Hum! incrementation still dont work for me. Is it something I'm doing wrong or is it something that don't work with the script ?
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Aerilius_Snapshot_005.jpg
                                  By pressing my +1 button set as above
                                  a xyz.skp Snapshot should be saved as
                                  and due to "change the 2 digit by 1", I understand that the following +1 button depressed should increment the files by the second digit:
                                  xyz_01_03.png...
                                  But my file is saved as
                                  xyz_01_00.png and instead of increment it , overwrites on itself.
                                  Still need help I guess 😳
                                  Simon.
                                    Aerilius
                                    fixed!
                                      simon le bon
                                      @aerilius said:
                                      fixed!
                                      Hi Ae,
                                      it is not necessarily very comfortable to be tester 😉 😕
                                      It seems that increment still doesn't work...
                                      (that decrements from 1 to 0 and then overwrites)
                                      Cheers,
                                      Simon.
                                      PS:It should certainly be very useful to add the usages of {nr} parameter to the first post
                                        simon le bon
                                        ~~ content outdated --> erased ~~~
                                          glro
                                          one step further...
                                          would it be possible to:
                                          scan a folder
                                          open automatically all skp files in the folder
                                          produce the thumbnail and the file shortcut
                                          store them in the specified folder?
                                          Because the plugin is great to keep track of the future skp files, and it would be nice to collect the informations also for the already existing skp files...
                                            driven
                                            Hi Giro,
                                            I just popped in to post another idea and thought I'd use your query to clarify some thoughts, hope you don't mind.
                                            @glro said:
                                            one step further...
                                            scan a folder
                                            'SketchUp Menu' >> File >> Open >> Browse to Folder >> Select All .skp files >> Click 'Select'
                                            on a mac all will open in SketchUp, does it not on a PC?
                                            does it not do this, now? on the mac the 'shortcut's' not needed if you 'apply' the new icon image to the .skp file
                                            This is already a preference, but once they're on the .skp storing a copy [as a material, maybe?] in the model would be more useful [for transferring to another computer or sharing]
                                            You can already use this with old or new files, the problem with batch processing [fully auto] is getting bad views of some models that haven't been optimally positioned when last saved. You could code in a 'Perspective >> Zoom Extents' type event, but what if its a part of a huge scheme or a 2D floorPlan etc...
                                            • 2 / 4
