    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 61.0k Views 12 Watching
      Aerilius
      I updated the plugin. I think it will now fit all your needs because you can now make your own buttons 😉
      @glro, can you test if the shortcuts work as expected?
        glro
        i tested, but there might be a problem
        no box is opened on my scree when i check "ae snapshot" in the menu
        it might come from the html file
        in the pop up windows you show in the first message of this thread, i read "create a shortcut"
        but when i click on the html file in "ae_snapshot" folder, i don't see the same things
        html settings differences
          Aerilius
          I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
          You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
          Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
            glro
            yes, the setting dialog does not appear;
            the gear icon does'nt appear either...
            just a small reactangle where i cannot click ...
            how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
            my guess is that it is linked to the problem
            snapshot icon
            • srxS Offline
              srx
              Very useful! Thank you very much.
              www.saurus.rs
                Aerilius
                @glro: Does " Sketchup.write_default("Plugins_ae", "Snapshot", "{}")" on the Ruby Console and restarting help?
                (There are no relevant differences in the htm file.)
                (By the way, you don't need quote the message, I know it's on the same page one above 😉 )
                  glro
                  OK
                  yes it helps
                  when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
                  but i cannot save the parameters (clicking on "OK" doesnt change anything)
                  i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
                  thank you
                    Aerilius
                    @glro said:
                    yes it helps
                    That is good!
                    Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
                      glro
                      when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
                      The plugin does take a shot when i click on the button
                      but i cannot get the snapshot settings windows on the screen anymore
                      it may be because of my computer, if i am the only one to have this problem...
                        Aerilius
                        I am very sure it's not your computer. I couldn't find anything on my own.
                        This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
                          glro
                          no, nothing in the ruby console
                          it is an error message when sketchup loads all the plugins
                          no numbers
                          erreur chargement
                            Aerilius
                            Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                            load "ae_Snapshot/Snapshot.rb"
                              glro
                              Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                              Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                                Aerilius
                                Thanks!!!
                                I found and fixed the issues!
                                  glro
                                  sorry to write that i still have an error message
                                  string to integer error
                                    Aerilius
                                    I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                                      glro
                                      Here is the error message:
                                      "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                                      (eval):155:in `load'
                                      (eval):155"
                                      line 319
                                        Aerilius
                                        (I won't be back until tomorrow.)
                                        I just made a quick change, can you test it?
                                        Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                                          glro
                                          i replaced the previous file in the rbz, by this new one, and yes, now it works perfectly
                                          a nice tool to keep tracks, and retrieve a lost model
                                          thank you
                                            driven
                                            been playing around with style
                                            no need to open, but do the icons download to other computers
                                            don't stay stuck when on the file posting, but I want to test if they download
                                            This is the Standard horrible mac one
                                            it's icon doesn't upload either??
                                            • 2 / 4
